1)芯片选的是内置的8M版本,初始化过程显示发现8M,程序运行后打印出来缺不到1M。加了几个应用之后,现在连lcd单buf都分配不到
I (3923) LCD_panel: Initialize RGB panel
I (3923) MEM: Biggest / Free / Total
SRAM : [ 249856 / 350923 / 653747]
PSRAM : [ 966656 / 979936 / 983040]
I (3923) LCD_panel: esp_lcd_new_rgb_panel
D (3943) intr_alloc: Connected src 24 to int 19 (cpu 0)
D (3943) gdma: new pair (0,1) at 0x3c7f1c84
D (3943) gdma: new tx channel (0,1) at 0x3c781444
D (3943) gdma: tx channel (0,1), (4:64) bytes aligned, burst enabled
D (3943) lcd_panel.rgb: start gpio config...
D (3943) lcd_panel.rgb: in lcd_rgb_panel_configure_gpio
D (3943) lcd_panel.rgb: in esp_lcd_new_rgb_panel
D (3943) lcd_panel.rgb: new rgb panel(0) @0x3fc9c07c, fb0 @0x3c710c40, fb1 @0x3c781480, fb_size=460800, bb0 @0x0, bb1 @0x0, bb_size=0
D (3943) lcd_panel.rgb: rgb_panel
D (3943) lcd_hal: n=8,a=9,b=8,mo=1
D (3943) lcd_hal: hal->dev: 60041000
D (3953) lcd_panel.rgb: rgb panel(0) start, pclk=18000000Hz
I (3953) LCD_panel: esp_lcd_new_rgb_panel success
D (3953) ledc: Using clock source 1 (in slow mode), divisor: 0x1f4
D (3953) ledc: In slow speed mode, global clk set: 1
D (3953) ledc: LEDC_PWM CHANNEL 0|GPIO 45|Duty 0100|Time 0
D (3953) HMI_ESP32_B_V10: ledc_initialized!
assert failed: lvgl_port_display_init bsp_lv_port.c:209 (buf1)
Backtrace: 0x403760d2:0x3fcf3bd0 0x4037bb61:0x3fcf3bf0 0x4038151e:0x3fcf3c10 0x4200d251:0x3fcf3d30 0x42007c68:0x3fcf3d80 0x4205f5cf:0x3fcf3db0
W (1536) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version.
D (1547) MSPI Timing: tuning success, best point is index 5
I (1552) esp_psram: Found 8MB PSRAM device
I (1556) esp_psram: Speed: 80MHz
I (1601) mmu_psram: Instructions copied and mapped to SPIRAM
I (2293) mmu_psram: Read only data copied and mapped to SPIRAM
I (2294) cpu_start: Pro cpu up.
I (2294) cpu_start: Starting app cpu, entry point is 0x403754e0
2)下载程序总是识别,bin文件大一点的总是失败,三分之一的时间都用在下载程序了。为什么这个口下载这么慢,有没有usb模式
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x00730fff...
Compressed 20576 bytes to 13101...
Writing at 0x00000000... (100 %)
Wrote 20576 bytes (13101 compressed) at 0x00000000 in 0.4 seconds (effective 395.7 kbit/s)...
Hash of data verified.
Compressed 7473328 bytes to 3031089...
Writing at 0x00010000... (0 %)
Writing at 0x0001a0ea... (1 %)
Writing at 0x00028116... (1 %)
Writing at 0x00038773... (2 %)
File "runpy.py", line 194, in _run_module_as_main
File "runpy.py", line 87, in _run_code
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\__main__.py", line 11, in <module>
esptool._main()
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\__init__.py", line 1026, in _main
main()
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\__init__.py", line 826, in main
operation_func(esp, args)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\cmds.py", line 556, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 109, in inner
return func(*args, **kwargs)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 991, in flash_defl_block
self.check_command(
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 407, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 376, in command
p = self.read()
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 308, in read
return next(self._slip_reader)
Writing at 0x004926da... (68 %)
Writing at 0x004b08f9... (69 %)
Writing at 0x004b9368... (69 %)
Writing at 0x004c40d2... (70 %)
Writing at 0x004d0562... (70 %)
esptool._main()
main()
Writing at 0x005321df... (74 %)
Writing at 0x0054cf2d... (75 %)
Writing at 0x0056b873... (75 %)
esptool._main()
main()
esp32s3各种问题,希望有技术人员关注以下
Re: esp32s3各种问题,希望有技术人员关注以下
您好:
1、软件使用的 Flash 大小取决于工程使用的分区表设置和软件配置中的 Flash Size 设置。如下:
Serial flasher config → Flash size
esp-idf SDK 中对应的系统分区表文件参见:https://github.com/espressif/esp-idf/tr ... tion_table
如下: 每个工程都有对应的分区表文件设置,在 menuconfig 的 Partition Table → Partition Table 路径下,如下:
2、 ESP32-S3 支持使用 UART 或 USB 管脚下载固件,对应说明参见:https://blog.csdn.net/Marchtwentytwo/ar ... /121169467?
如果使用 ESP32-S3 的 UART0 管脚下载固件固件速度慢的话,可以尝试增加下载波特率,例如使用如下指令:
idf.py -p COM3 -b 921600 flash monitor
Users browsing this forum: No registered users and 40 guests
