esp32-s3 的 ble_hid 示例与苹果手机连接错误
seacaptain
Postby seacaptain » Thu Oct 19, 2023 10:56 am
1. 使用 esp-idf 5.1 稳定版
2. 使用 ble_hid_device_demo 示例,未做任何修改。
问题: 第一次苹果13是能正确连接上设备的,并且断开之后也能正常自动重连。慢速的开关苹果手机蓝牙也使能自动重连的。快速的开关几次手机蓝牙之后,发现不会自动重连,手动重连也不行。必须要重新绑定之后才能进行连接。
I (22) boot: ESP-IDF v5.1 2nd stage bootloader
I (23) boot: compile time Oct 19 2023 17:18:34
I (23) boot: Multicore bootloader
I (26) boot: chip revision: v0.1
I (29) boot.esp32s3: Boot SPI Speed : 80MHz
I (34) boot.esp32s3: SPI Mode       : DIO
I (39) boot.esp32s3: SPI Flash Size : 2MB
I (44) boot: Enabling RNG early entropy source...
I (49) boot: Partition Table:
I (53) boot: ## Label            Usage          Type ST Offset   Length
I (60) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (67) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (75) boot:  2 factory          factory app      00 00 00010000 00100000
I (82) boot: End of partition table
I (86) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=20c00h (134144) map
I (119) esp_image: segment 1: paddr=00030c28 vaddr=3fc96d00 size=03f58h ( 16216) load
I (123) esp_image: segment 2: paddr=00034b88 vaddr=40374000 size=0b490h ( 46224) load
I (135) esp_image: segment 3: paddr=00040020 vaddr=42000020 size=785a0h (492960) map
I (224) esp_image: segment 4: paddr=000b85c8 vaddr=4037f490 size=07774h ( 30580) load
I (239) boot: Loaded app from partition at offset 0x10000
I (239) boot: Disabling RNG early entropy source...
I (250) cpu_start: Multicore app
I (251) cpu_start: Pro cpu up.
I (251) cpu_start: Starting app cpu, entry point is 0x4037541c
0x4037541c: call_start_cpu1 at /home/navi/esp/esp-idf/components/esp_system/port/cpu_start.c:154
I (0) cpu_start: App cpu up.
I (269) cpu_start: Pro cpu start user code
I (269) cpu_start: cpu freq: 160000000 Hz
I (269) cpu_start: Application information:
I (272) cpu_start: Project name:     hidd_demos
I (277) cpu_start: App version:      1
I (282) cpu_start: Compile time:     Oct 19 2023 17:18:28
I (288) cpu_start: ELF file SHA256:  69e3ecd8510776e7...
I (294) cpu_start: ESP-IDF:          v5.1
I (298) cpu_start: Min chip rev:     v0.0
I (303) cpu_start: Max chip rev:     v0.99
I (308) cpu_start: Chip rev:         v0.1
I (313) heap_init: Initializing. RAM available for dynamic allocation:
I (320) heap_init: At 3FC9ED20 len 0004A9F0 (298 KiB): DRAM
I (326) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM
I (333) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (339) heap_init: At 600FE010 len 00001FF0 (7 KiB): RTCRAM
I (346) spi_flash: detected chip: gd
I (349) spi_flash: flash io: dio
W (353) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (367) sleep: Configure to isolate all GPIO pins in sleep state
I (373) sleep: Enable automatic switching of GPIO sleep configuration
I (380) coexist: coex firmware version: ebddf30
I (386) coexist: coexist rom version e7ae62f
I (391) app_start: Starting scheduler on CPU0
I (396) app_start: Starting scheduler on CPU1
I (396) main_task: Started on CPU0
I (406) main_task: Calling app_main()
I (416) BLE_INIT: BT controller compile version [85b425c]
I (416) phy_init: phy_version 601,fe52df4,May 10 2023,17:26:54
I (466) BLE_INIT: Bluetooth MAC: f4:12:fa:83:1d:e2
W (486) BT_BTM: BTM_BleWriteAdvData, Partial data write into ADV
I (496) HID_LE_PRF: esp_hidd_prf_cb_hdl(), start added the hid service to the stack database. incl_handle = 40
I (496) HID_LE_PRF: hid svc handle = 2d
I (506) main_task: Returned from app_main()
I (59516) HID_LE_PRF: HID connection establish, conn_id = 0
I (59516) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (61626) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (61626) HID_DEMO: address type = 1
I (61626) HID_DEMO: pair status = success
I (63506) HID_DEMO: Send the volume
I (71506) HID_DEMO: Send the volume
W (71526) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (71526) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (74436) HID_LE_PRF: HID connection establish, conn_id = 0
I (74436) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (74746) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (74746) HID_DEMO: address type = 1
I (74746) HID_DEMO: pair status = success
I (79506) HID_DEMO: Send the volume
W (79836) BT_GATT: gatt_ind_ack_timeout send ack now
I (87506) HID_DEMO: Send the volume
I (95506) HID_DEMO: Send the volume
W (97836) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (97836) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (100936) HID_LE_PRF: HID connection establish, conn_id = 0
I (100936) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (101236) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (101236) HID_DEMO: address type = 1
I (101236) HID_DEMO: pair status = success
I (103506) HID_DEMO: Send the volume
W (106286) BT_GATT: gatt_ind_ack_timeout send ack now
I (111506) HID_DEMO: Send the volume
W (117036) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (117036) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (122996) HID_LE_PRF: HID connection establish, conn_id = 0
I (123006) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (123406) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (123406) HID_DEMO: address type = 1
I (123406) HID_DEMO: pair status = success
I (123506) HID_DEMO: Send the volume
W (128446) BT_GATT: gatt_ind_ack_timeout send ack now
I (131506) HID_DEMO: Send the volume
W (133296) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (133296) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (136866) HID_LE_PRF: HID connection establish, conn_id = 0
I (136866) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (137226) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (137226) HID_DEMO: address type = 1
I (137226) HID_DEMO: pair status = success
I (139506) HID_DEMO: Send the volume
W (142266) BT_GATT: gatt_ind_ack_timeout send ack now
I (147506) HID_DEMO: Send the volume
I (155506) HID_DEMO: Send the volume
I (163506) HID_DEMO: Send the volume
W (166966) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (166966) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
W (171286) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x3e
I (172436) HID_LE_PRF: HID connection establish, conn_id = 0
I (172436) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (172736) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (172736) HID_DEMO: address type = 1
I (172736) HID_DEMO: pair status = success
I (173506) HID_DEMO: Send the volume
W (173936) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (173936) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (177066) HID_LE_PRF: HID connection establish, conn_id = 0
I (177066) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (177366) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (177366) HID_DEMO: address type = 1
I (177366) HID_DEMO: pair status = success
W (180016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (180016) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (183126) HID_LE_PRF: HID connection establish, conn_id = 0
I (183126) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (183436) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (183436) HID_DEMO: address type = 1
I (183436) HID_DEMO: pair status = success
I (183506) HID_DEMO: Send the volume
W (188126) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (188126) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (191056) HID_LE_PRF: HID connection establish, conn_id = 0
I (191056) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (191366) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (191366) HID_DEMO: address type = 1
I (191366) HID_DEMO: pair status = success
I (191506) HID_DEMO: Send the volume
W (196406) BT_GATT: gatt_ind_ack_timeout send ack now
I (199506) HID_DEMO: Send the volume
W (203056) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (203056) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (219256) HID_LE_PRF: HID connection establish, conn_id = 0
I (219256) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (221926) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (221926) HID_DEMO: address type = 1
I (221926) HID_DEMO: pair status = success
I (223506) HID_DEMO: Send the volume
W (228756) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (228756) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (250916) HID_LE_PRF: HID connection establish, conn_id = 0
I (250916) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (251556) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (251566) HID_DEMO: address type = 1
I (251566) HID_DEMO: pair status = success
I (253506) HID_DEMO: Send the volume
W (256016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (256016) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (259146) HID_LE_PRF: HID connection establish, conn_id = 0
I (259146) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (259596) HID_DEMO: remote BD_ADDR: 542e4b0c8dba
I (259596) HID_DEMO: address type = 1
I (259596) HID_DEMO: pair status = success
I (261506) HID_DEMO: Send the volume
W (264646) BT_GATT: gatt_ind_ack_timeout send ack now
I (269506) HID_DEMO: Send the volume
I (277506) HID_DEMO: Send the volume
I (285506) HID_DEMO: Send the volume
I (293506) HID_DEMO: Send the volume
I (301506) HID_DEMO: Send the volume
I (309506) HID_DEMO: Send the volume
I (317506) HID_DEMO: Send the volume
I (325506) HID_DEMO: Send the volume
I (333506) HID_DEMO: Send the volume
I (338096) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVT
I (338096) HID_DEMO: 00
I (341506) HID_DEMO: Send the volume
I (342196) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVT
I (342196) HID_DEMO: 00
I (349506) HID_DEMO: Send the volume
I (357506) HID_DEMO: Send the volume
I (359096) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVT
I (359096) HID_DEMO: 00
I (365506) HID_DEMO: Send the volume
I (373506) HID_DEMO: Send the volume
I (375896) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVT
I (375896) HID_DEMO: 00
I (381506) HID_DEMO: Send the volume
I (389506) HID_DEMO: Send the volume
I (397506) HID_DEMO: Send the volume
I (405506) HID_DEMO: Send the volume
I (413506) HID_DEMO: Send the volume
I (421506) HID_DEMO: Send the volume
I (429506) HID_DEMO: Send the volume
I (437506) HID_DEMO: Send the volume
I (445506) HID_DEMO: Send the volume
I (453506) HID_DEMO: Send the volume
I (461506) HID_DEMO: Send the volume
I (469506) HID_DEMO: Send the volume
I (477506) HID_DEMO: Send the volume
I (485506) HID_DEMO: Send the volume
I (493506) HID_DEMO: Send the volume
I (501506) HID_DEMO: Send the volume
I (505486) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVT
I (505486) HID_DEMO: 00
I (509506) HID_DEMO: Send the volume
I (517506) HID_DEMO: Send the volume
I (525506) HID_DEMO: Send the volume
I (533506) HID_DEMO: Send the volume
I (541506) HID_DEMO: Send the volume
I (549506) HID_DEMO: Send the volume
I (557506) HID_DEMO: Send the volume
I (565506) HID_DEMO: Send the volume
I (573506) HID_DEMO: Send the volume
I (581506) HID_DEMO: Send the volume
I (589506) HID_DEMO: Send the volume
I (597506) HID_DEMO: Send the volume
I (605506) HID_DEMO: Send the volume
I (613506) HID_DEMO: Send the volume
I (621506) HID_DEMO: Send the volume
I (629506) HID_DEMO: Send the volume
I (637506) HID_DEMO: Send the volume
I (645506) HID_DEMO: Send the volume
I (653506) HID_DEMO: Send the volume
I (661506) HID_DEMO: Send the volume
I (669506) HID_DEMO: Send the volume
I (677506) HID_DEMO: Send the volume
I (685506) HID_DEMO: Send the volume
I (693506) HID_DEMO: Send the volume
I (701506) HID_DEMO: Send the volume
I (709506) HID_DEMO: Send the volume
I (711326) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVT
I (711336) HID_DEMO: 00
I (717506) HID_DEMO: Send the volume
I (725506) HID_DEMO: Send the volume
W (728376) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (728386) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (901156) HID_LE_PRF: HID connection establish, conn_id = 0
I (901156) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (902806) BT_GATT: gatts_write_attr_perm_check - GATT_INSUF_AUTHENTICATION
I (903806) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (903806) HID_DEMO: address type = 1
I (903806) HID_DEMO: pair status = success
I (905506) HID_DEMO: Send the volume
I (913506) HID_DEMO: Send the volume
W (913826) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (913826) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (917866) HID_LE_PRF: HID connection establish, conn_id = 0
I (917866) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (917866) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (917876) HID_DEMO: address type = 1
I (917876) HID_DEMO: pair status = success
I (921506) HID_DEMO: Send the volume
W (925006) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (925006) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (927136) HID_LE_PRF: HID connection establish, conn_id = 0
I (927136) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (927136) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (927146) HID_DEMO: address type = 1
I (927146) HID_DEMO: pair status = success
I (929506) HID_DEMO: Send the volume
W (929626) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (929626) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (932026) HID_LE_PRF: HID connection establish, conn_id = 0
I (932026) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (932026) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (932026) HID_DEMO: address type = 1
I (932036) HID_DEMO: pair status = success
W (933466) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (933466) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
W (935566) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (935566) BT_HCI: CC evt: op=0x2022, status=0x2
I (935566) HID_LE_PRF: HID connection establish, conn_id = 0
I (935566) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (935576) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (935586) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (938776) HID_LE_PRF: HID connection establish, conn_id = 0
I (938776) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (938776) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (938776) HID_DEMO: address type = 1
I (938786) HID_DEMO: pair status = success
I (939506) HID_DEMO: Send the volume
W (943096) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (943096) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (945226) HID_LE_PRF: HID connection establish, conn_id = 0
I (945226) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (945226) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (945226) HID_DEMO: address type = 1
I (945236) HID_DEMO: pair status = success
W (946726) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (946726) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (948436) HID_LE_PRF: HID connection establish, conn_id = 0
I (948436) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (948676) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (948676) HID_DEMO: address type = 1
I (948676) HID_DEMO: pair status = success
W (949186) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (949186) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (950866) HID_LE_PRF: HID connection establish, conn_id = 0
I (950866) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (951106) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (951106) HID_DEMO: address type = 1
I (951106) HID_DEMO: pair status = success
I (951506) HID_DEMO: Send the volume
W (952696) BT_L2CAP: le con upd: err_stat=0x13
W (952696) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (952696) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (953836) HID_LE_PRF: HID connection establish, conn_id = 0
I (953836) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (954136) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (954136) HID_DEMO: address type = 1
I (954136) HID_DEMO: pair status = success
W (955666) BT_L2CAP: le con upd: err_stat=0x13
W (955666) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (955666) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (957466) HID_LE_PRF: HID connection establish, conn_id = 0
I (957466) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (957706) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (957706) HID_DEMO: address type = 1
I (957706) HID_DEMO: pair status = success
W (958936) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (958936) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (960646) HID_LE_PRF: HID connection establish, conn_id = 0
I (960646) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (960886) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (960886) HID_DEMO: address type = 1
I (960886) HID_DEMO: pair status = success
I (961506) HID_DEMO: Send the volume
W (962326) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (962326) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (964126) HID_LE_PRF: HID connection establish, conn_id = 0
I (964126) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (964126) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (964126) HID_DEMO: address type = 1
I (964136) HID_DEMO: pair status = success
W (965806) BT_L2CAP: le con upd: err_stat=0x13
W (965806) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (965806) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (966886) HID_LE_PRF: HID connection establish, conn_id = 0
I (966886) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (967126) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (967126) HID_DEMO: address type = 1
I (967126) HID_DEMO: pair status = success
W (967636) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (967636) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (969226) HID_LE_PRF: HID connection establish, conn_id = 0
I (969226) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (969226) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (969226) HID_DEMO: address type = 1
I (969236) HID_DEMO: pair status = success
W (969286) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (969286) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (970696) HID_LE_PRF: HID connection establish, conn_id = 0
I (970696) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (970906) BT_BTM: Device not found
W (970906) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (970906) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (970956) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (970956) HID_DEMO: address type = 1
I (970956) HID_DEMO: pair status = fail
E (970956) HID_DEMO: fail reason = 0x66
I (971506) HID_DEMO: Send the volume
I (972406) HID_LE_PRF: HID connection establish, conn_id = 0
I (972406) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (972586) BT_BTM: Device not found
W (972586) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (972586) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (972596) HID_DEMO: remote BD_ADDR: 76b2f9e913d8
I (972596) HID_DEMO: address type = 1
I (972596) HID_DEMO: pair status = fail
E (972606) HID_DEMO: fail reason = 0x66
W (972886) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (972886) BT_HCI: CC evt: op=0x2022, status=0x2
I (972886) HID_LE_PRF: HID connection establish, conn_id = 0
I (972886) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (972896) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (972896) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (973846) HID_LE_PRF: HID connection establish, conn_id = 0
I (973846) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (973996) BT_BTM: Device not found
W (973996) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (973996) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (974006) HID_DEMO: remote BD_ADDR: 54965ef97e35
I (974006) HID_DEMO: address type = 1
I (974006) HID_DEMO: pair status = fail
E (974016) HID_DEMO: fail reason = 0x66
W (974296) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (974296) BT_HCI: CC evt: op=0x2022, status=0x2
I (974296) HID_LE_PRF: HID connection establish, conn_id = 0
I (974296) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (974306) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (974306) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (975856) HID_LE_PRF: HID connection establish, conn_id = 0
I (975856) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (976036) BT_BTM: Device not found
W (976036) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (976036) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (976046) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (976046) HID_DEMO: address type = 1
I (976046) HID_DEMO: pair status = fail
E (976056) HID_DEMO: fail reason = 0x66
I (976246) HID_LE_PRF: HID connection establish, conn_id = 0
I (976246) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (976426) BT_BTM: Device not found
W (976426) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (976426) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (976436) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (976436) HID_DEMO: address type = 1
I (976436) HID_DEMO: pair status = fail
E (976446) HID_DEMO: fail reason = 0x66
W (976696) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (976696) BT_HCI: CC evt: op=0x2022, status=0x2
I (976696) HID_LE_PRF: HID connection establish, conn_id = 0
I (976696) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (976706) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (976706) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (977086) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (977086) BT_HCI: CC evt: op=0x2022, status=0x2
I (977086) HID_LE_PRF: HID connection establish, conn_id = 0
I (977086) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (977096) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (977096) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (977296) HID_LE_PRF: HID connection establish, conn_id = 0
I (977296) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (977476) BT_BTM: Device not found
W (977476) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (977476) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (977486) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (977486) HID_DEMO: address type = 1
I (977486) HID_DEMO: pair status = fail
E (977496) HID_DEMO: fail reason = 0x66
W (978136) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (978136) BT_HCI: CC evt: op=0x2022, status=0x2
I (978136) HID_LE_PRF: HID connection establish, conn_id = 0
I (978136) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (978146) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (978146) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (979216) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (979216) BT_HCI: CC evt: op=0x2022, status=0x2
I (979216) HID_LE_PRF: HID connection establish, conn_id = 0
I (979216) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (979226) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (979226) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (979426) HID_LE_PRF: HID connection establish, conn_id = 0
I (979426) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (979576) BT_BTM: Device not found
W (979576) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (979576) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (979586) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (979586) HID_DEMO: address type = 1
I (979586) HID_DEMO: pair status = fail
E (979596) HID_DEMO: fail reason = 0x66
I (980176) HID_LE_PRF: HID connection establish, conn_id = 0
I (980176) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (980356) BT_BTM: Device not found
W (980356) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (980356) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (980366) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (980366) HID_DEMO: address type = 1
I (980366) HID_DEMO: pair status = fail
E (980376) HID_DEMO: fail reason = 0x66
I (980536) HID_LE_PRF: HID connection establish, conn_id = 0
I (980536) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (980716) BT_BTM: Device not found
W (980716) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (980716) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (980726) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (980726) HID_DEMO: address type = 1
I (980726) HID_DEMO: pair status = fail
E (980736) HID_DEMO: fail reason = 0x66
W (981166) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (981166) BT_HCI: CC evt: op=0x2022, status=0x2
I (981166) HID_LE_PRF: HID connection establish, conn_id = 0
I (981166) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (981176) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (981176) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (981376) HID_LE_PRF: HID connection establish, conn_id = 0
I (981376) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (981556) BT_BTM: Device not found
W (981556) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (981556) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (981566) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (981566) HID_DEMO: address type = 1
I (981566) HID_DEMO: pair status = fail
E (981576) HID_DEMO: fail reason = 0x66
I (983506) HID_DEMO: Send the volume
W (983716) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (983716) BT_HCI: CC evt: op=0x2022, status=0x2
I (983716) HID_LE_PRF: HID connection establish, conn_id = 0
I (983716) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (983726) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (983726) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (984016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (984016) BT_HCI: CC evt: op=0x2022, status=0x2
I (984016) HID_LE_PRF: HID connection establish, conn_id = 0
I (984016) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (984026) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (984026) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (984616) HID_LE_PRF: HID connection establish, conn_id = 0
I (984616) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (984796) BT_BTM: Device not found
W (984796) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (984796) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (984806) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (984806) HID_DEMO: address type = 1
I (984806) HID_DEMO: pair status = fail
E (984816) HID_DEMO: fail reason = 0x66
W (985096) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (985096) BT_HCI: CC evt: op=0x2022, status=0x2
I (985096) HID_LE_PRF: HID connection establish, conn_id = 0
I (985096) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (985106) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (985106) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (985486) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (985486) BT_HCI: CC evt: op=0x2022, status=0x2
I (985486) HID_LE_PRF: HID connection establish, conn_id = 0
I (985486) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (985496) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (985496) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (985786) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (985786) BT_HCI: CC evt: op=0x2022, status=0x2
I (985786) HID_LE_PRF: HID connection establish, conn_id = 0
I (985786) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (985796) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (985796) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (986086) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (986086) BT_HCI: CC evt: op=0x2022, status=0x2
I (986086) HID_LE_PRF: HID connection establish, conn_id = 0
I (986086) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (986096) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (986096) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (986566) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (986566) BT_HCI: CC evt: op=0x2022, status=0x2
I (986566) HID_LE_PRF: HID connection establish, conn_id = 0
I (986566) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (986576) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (986576) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (986776) HID_LE_PRF: HID connection establish, conn_id = 0
I (986776) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (986986) BT_BTM: Device not found
W (986986) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (986986) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (986996) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (986996) HID_DEMO: address type = 1
I (986996) HID_DEMO: pair status = fail
E (987006) HID_DEMO: fail reason = 0x66
W (987256) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (987256) BT_HCI: CC evt: op=0x2022, status=0x2
I (987256) HID_LE_PRF: HID connection establish, conn_id = 0
I (987256) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (987266) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (987266) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (987646) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (987646) BT_HCI: CC evt: op=0x2022, status=0x2
I (987646) HID_LE_PRF: HID connection establish, conn_id = 0
I (987646) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (987656) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (987656) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (987946) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (987946) BT_HCI: CC evt: op=0x2022, status=0x2
I (987946) HID_LE_PRF: HID connection establish, conn_id = 0
I (987946) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (987956) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (987956) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (988186) HID_LE_PRF: HID connection establish, conn_id = 0
I (988186) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (988396) BT_BTM: Device not found
W (988396) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (988396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (988406) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (988406) HID_DEMO: address type = 1
I (988406) HID_DEMO: pair status = fail
E (988416) HID_DEMO: fail reason = 0x66
I (988906) HID_LE_PRF: HID connection establish, conn_id = 0
I (988906) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (989086) BT_BTM: Device not found
W (989086) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (989086) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (989096) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (989096) HID_DEMO: address type = 1
I (989096) HID_DEMO: pair status = fail
E (989106) HID_DEMO: fail reason = 0x66
W (989386) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (989386) BT_HCI: CC evt: op=0x2022, status=0x2
I (989386) HID_LE_PRF: HID connection establish, conn_id = 0
I (989386) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (989396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (989396) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (989596) HID_LE_PRF: HID connection establish, conn_id = 0
I (989596) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (989776) BT_BTM: Device not found
W (989776) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (989776) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (989786) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (989786) HID_DEMO: address type = 1
I (989786) HID_DEMO: pair status = fail
E (989796) HID_DEMO: fail reason = 0x66
W (990076) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (990076) BT_HCI: CC evt: op=0x2022, status=0x2
I (990076) HID_LE_PRF: HID connection establish, conn_id = 0
I (990076) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (990086) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (990086) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (990316) HID_LE_PRF: HID connection establish, conn_id = 0
I (990316) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (990526) BT_BTM: Device not found
W (990526) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (990526) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (990536) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (990536) HID_DEMO: address type = 1
I (990536) HID_DEMO: pair status = fail
E (990546) HID_DEMO: fail reason = 0x66
I (991216) HID_LE_PRF: HID connection establish, conn_id = 0
I (991216) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (991396) BT_BTM: Device not found
W (991396) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (991396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (991406) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (991406) HID_DEMO: address type = 1
I (991406) HID_DEMO: pair status = fail
E (991416) HID_DEMO: fail reason = 0x66
I (991506) HID_DEMO: Send the volume
I (993136) HID_LE_PRF: HID connection establish, conn_id = 0
I (993136) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (993316) BT_BTM: Device not found
W (993316) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (993316) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (993326) HID_DEMO: remote BD_ADDR: 7aedae8c7576
I (993326) HID_DEMO: address type = 1
I (993326) HID_DEMO: pair status = fail
E (993326) HID_DEMO: fail reason = 0x66
W (993376) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (999506) HID_DEMO: Send the volume
I (1007506) HID_DEMO: Send the volume
I (1015506) HID_DEMO: Send the volume
I (1021866) HID_LE_PRF: HID connection establish, conn_id = 0
I (1021876) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (1022046) BT_BTM: Device not found
W (1022056) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (1022056) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (1022056) HID_DEMO: remote BD_ADDR: 7da5d335b282
I (1022066) HID_DEMO: address type = 1
I (1022066) HID_DEMO: pair status = fail
E (1022066) HID_DEMO: fail reason = 0x66
W (1022376) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1022386) BT_HCI: CC evt: op=0x2022, status=0x2
I (1022386) HID_LE_PRF: HID connection establish, conn_id = 0
I (1022386) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1022396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1022396) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (1022586) HID_LE_PRF: HID connection establish, conn_id = 0
I (1022586) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (1022766) BT_BTM: Device not found
W (1022776) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (1022776) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (1022776) HID_DEMO: remote BD_ADDR: 7da5d335b282
I (1022786) HID_DEMO: address type = 1
I (1022786) HID_DEMO: pair status = fail
E (1022786) HID_DEMO: fail reason = 0x66
I (1023506) HID_DEMO: Send the volume
W (1023816) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1023826) BT_HCI: CC evt: op=0x2022, status=0x2
I (1023826) HID_LE_PRF: HID connection establish, conn_id = 0
I (1023826) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1023836) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1023836) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1024146) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1024156) BT_HCI: CC evt: op=0x2022, status=0x2
I (1024156) HID_LE_PRF: HID connection establish, conn_id = 0
I (1024156) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1024166) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1024166) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1024536) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1024546) BT_HCI: CC evt: op=0x2022, status=0x2
I (1024546) HID_LE_PRF: HID connection establish, conn_id = 0
I (1024546) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1024556) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1024556) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1024896) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1024906) BT_HCI: CC evt: op=0x2022, status=0x2
I (1024906) HID_LE_PRF: HID connection establish, conn_id = 0
I (1024906) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1024916) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1024916) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (1025076) HID_LE_PRF: HID connection establish, conn_id = 0
I (1025076) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (1025256) BT_BTM: Device not found
W (1025266) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (1025266) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (1025266) HID_DEMO: remote BD_ADDR: 7da5d335b282
I (1025276) HID_DEMO: address type = 1
I (1025276) HID_DEMO: pair status = fail
E (1025276) HID_DEMO: fail reason = 0x66
W (1025916) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1025926) BT_HCI: CC evt: op=0x2022, status=0x2
I (1025926) HID_LE_PRF: HID connection establish, conn_id = 0
I (1025926) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1025936) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1025936) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1026336) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1026346) BT_HCI: CC evt: op=0x2022, status=0x2
I (1026346) HID_LE_PRF: HID connection establish, conn_id = 0
I (1026346) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1026356) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1026356) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (1026756) HID_LE_PRF: HID connection establish, conn_id = 0
I (1026756) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (1026966) BT_BTM: Device not found
W (1026976) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (1026976) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (1026976) HID_DEMO: remote BD_ADDR: 7da5d335b282
I (1026986) HID_DEMO: address type = 1
I (1026986) HID_DEMO: pair status = fail
E (1026986) HID_DEMO: fail reason = 0x66
W (1027236) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1027246) BT_HCI: CC evt: op=0x2022, status=0x2
I (1027246) HID_LE_PRF: HID connection establish, conn_id = 0
I (1027246) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1027256) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1027256) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (1027446) HID_LE_PRF: HID connection establish, conn_id = 0
I (1027446) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (1027626) BT_BTM: Device not found
W (1027636) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (1027636) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (1027636) HID_DEMO: remote BD_ADDR: 7da5d335b282
I (1027646) HID_DEMO: address type = 1
I (1027646) HID_DEMO: pair status = fail
E (1027646) HID_DEMO: fail reason = 0x66
W (1027926) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1027936) BT_HCI: CC evt: op=0x2022, status=0x2
I (1027936) HID_LE_PRF: HID connection establish, conn_id = 0
I (1027936) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1027946) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1027946) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
I (1028856) HID_LE_PRF: HID connection establish, conn_id = 0
I (1028856) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
E (1029036) BT_BTM: Device not found
W (1029046) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
I (1029046) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
I (1029046) HID_DEMO: remote BD_ADDR: 7da5d335b282
I (1029056) HID_DEMO: address type = 1
I (1029056) HID_DEMO: pair status = fail
E (1029056) HID_DEMO: fail reason = 0x66
W (1029636) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1029646) BT_HCI: CC evt: op=0x2022, status=0x2
I (1029646) HID_LE_PRF: HID connection establish, conn_id = 0
I (1029646) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1029656) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1029656) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1029796) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1029796) BT_HCI: CC evt: op=0x2022, status=0x2
I (1029796) HID_LE_PRF: HID connection establish, conn_id = 0
I (1029796) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1029806) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1029806) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1042566) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1042576) BT_HCI: CC evt: op=0x2022, status=0x2
I (1042576) HID_LE_PRF: HID connection establish, conn_id = 0
I (1042576) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1042586) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1042586) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1043016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1043026) BT_HCI: CC evt: op=0x2022, status=0x2
I (1043026) HID_LE_PRF: HID connection establish, conn_id = 0
I (1043026) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1043036) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1043036) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
W (1043496) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13
E (1043506) BT_HCI: CC evt: op=0x2022, status=0x2
I (1043506) HID_LE_PRF: HID connection establish, conn_id = 0
I (1043506) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECT
I (1043516) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECT
E (1043516) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error
Users browsing this forum: No registered users and 147 guests
