IDF V4.4
ADF 2.4,
skainet master下载版本
单独编译skainet的examples下的例子,能够编译通过,能够正常运行。
当前在这些例子的Cmakefile.txt中增加一行:
include($ENV{ADF_PATH}/CMakeLists.txt)
后,编译报错,我想在一个工程中同时使用ADF和skainet,有什么办法?
FAILED: esp-idf/display_service/CMakeFiles/__idf_display_service.dir/led_bar/led_bar_ws2812.c.obj
ccache D:\Espressif\tools\xtensa-esp32s3-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32s3-elf\bin\xtensa-esp32s3-elf-gcc.exe -DADF_VER=\"v0.3.0-141-gbab2e2d\" -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -Iconfig -ID:/deng/esp32/esp-adf-master/components/display_service/include -ID:/deng/esp32/esp-adf-master/components/display_service/led_indicator/include -ID:/deng/esp32/esp-adf-master/components/display_service/led_bar/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/newlib/platform_include -ID:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/esp_additions/freertos -ID:/Espressif/frameworks/esp-idf-v4.4/components/freertos/port/xtensa/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/esp_additions -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include/soc -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include/soc/esp32s3 -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/port/esp32s3/. -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/port/esp32s3/private_include -ID:/Espressif/frameworks/esp-idf-v4.4/components/heap/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/log/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/lwip/include/apps -ID:/Espressif/frameworks/esp-idf-v4.4/components/lwip/include/apps/sntp -ID:/Espressif/frameworks/esp-idf-v4.4/components/lwip/lwip/src/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/lwip/port/esp32/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/lwip/port/esp32/include/arch -ID:/Espressif/frameworks/esp-idf-v4.4/components/soc/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/soc/esp32s3/. -ID:/Espressif/frameworks/esp-idf-v4.4/components/soc/esp32s3/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/hal/esp32s3/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/hal/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/hal/platform_port/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/include/esp32s3 -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32s3 -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_common/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/soc -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/public_compat -ID:/Espressif/frameworks/esp-idf-v4.4/components/xtensa/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/xtensa/esp32s3/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/driver/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/driver/esp32s3/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_pm/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_ringbuf/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/efuse/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/efuse/esp32s3/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/vfs/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_wifi/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_event/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_netif/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_eth/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/tcpip_adapter/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy/esp32s3/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_ipc/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/app_trace/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_timer/include -ID:/deng/esp32/esp-adf-master/components/audio_sal/include -ID:/deng/esp32/esp-adf-master/components/audio_board/include -ID:/deng/esp32/esp-adf-master/components/audio_hal/include -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es8388 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es8374 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es8311 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es8156 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es7243 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es7148 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es7210 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/es7243e -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/tas5805m -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/zl38063 -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/zl38063/api_lib -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/zl38063/example_apps -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/zl38063/firmware -ID:/deng/esp32/esp-adf-master/components/audio_hal/driver/include -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/include -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/adc_button -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/gpio_isr -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/button -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/blufi -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/IS31FL3216 -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/aw2013 -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/tca9554 -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/driver/i2c_bus -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/sdcard -ID:/deng/esp32/esp-adf-master/components/esp_peripherals/lib/touch -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_adc_cal/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/diskio -ID:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/vfs -ID:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/src -ID:/Espressif/frameworks/esp-idf-v4.4/components/wear_levelling/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/spi_flash/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/sdmmc/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/console -ID:/deng/esp32/esp-adf-master/components/audio_pipeline/include -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/esp_audio/include -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/esp_codec/include/codec -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/esp_codec/include/processing -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/media_lib_sal/include -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/media_lib_sal/include/port -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/recorder_engine/include -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/audio_misc/include -ID:/deng/esp32/esp-adf-master/components/esp-adf-libs/esp_media_protocols/include -ID:/deng/work/skainet/git/esp-skainet/examples/cn_speech_commands_recognition_test02/components/esp-sr/src/include -ID:/deng/work/skainet/git/esp-skainet/examples/cn_speech_commands_recognition_test02/components/esp-sr/esp-tts/esp_tts_chinese/include -ID:/deng/work/skainet/git/esp-skainet/examples/cn_speech_commands_recognition_test02/components/esp-sr/include/esp32s3 -ID:/Espressif/frameworks/esp-idf-v4.4/components/json/cJSON -ID:/Espressif/frameworks/esp-idf-v4.4/components/spiffs/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/nghttp/port/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/nghttp/nghttp2/lib/includes -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls/esp-tls-crypto -ID:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/port/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/mbedtls/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/esp_crt_bundle/include -ID:/deng/esp32/esp-adf-master/components/esp_dispatcher/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/nvs_flash/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/port/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/esp_supplicant/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd/include -ID:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd/interface -mlongcalls -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fmacro-prefix-map=D:/deng/work/skainet/git/esp-skainet/examples/cn_speech_commands_recognition_test02=. -fmacro-prefix-map=D:/Espressif/frameworks/esp-idf-v4.4=IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.4-dirty\" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -MD -MT esp-idf/display_service/CMakeFiles/__idf_display_service.dir/led_bar/led_bar_ws2812.c.obj -MF esp-idf\display_service\CMakeFiles\__idf_display_service.dir\led_bar\led_bar_ws2812.c.obj.d -o esp-idf/display_service/CMakeFiles/__idf_display_service.dir/led_bar/led_bar_ws2812.c.obj -c D:/deng/esp32/esp-adf-master/components/display_service/led_bar/led_bar_ws2812.c
D:/deng/esp32/esp-adf-master/components/display_service/led_bar/led_bar_ws2812.c:27:10: fatal error: board.h: No such file or directory
#include "board.h"
compilation terminated.
skainet和ADF能在一个工程中同时使用不
Re: skainet和ADF能在一个工程中同时使用不
编译可能是有一些问题,ADF 针对唤醒词/命令词也有提供一个 demo :
https://github.com/espressif/esp-adf/tr ... nition/wwe
您看是否可以满足您的需求
您看是否可以满足您的需求
wwe必须要唤醒词才能工作,不能满足要求,所以才切换到skainet的。
目前 WWE 不支持无唤醒词操作(预计下个版本才能支持),ADF 直接用可能会有一些编译问题,这个就得 case by case 看了...
Users browsing this forum: No registered users and 34 guests
