Basically the question is in the title: Is it possible to use an existing video stream from a CCTV surveillance system instead of camera and implement facial detection on it using ESP-WHO?
Thank you for your time.
Regards,
Luke
Is it possible to use the video stream from a CCTV surveillance system instead of camera?
Re: Is it possible to use the video stream from a CCTV surveillance system instead of camera?
Theoretically, yes! You may try input surveillance images (RGB888 or RGB565) to the interface of face detection model.
But maybe you need to check image quality first, if it's wide-view/high-resolution, the detection performance might be affected, e.g. delay might be long.
Users browsing this forum: No registered users and 28 guests
