错误代码:
Executing action: menuconfig
Running cmake in directory /home/esp/esp/station/build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=0 /home/esp/esp/station"...
-- Found Git: /usr/bin/git (found version "2.30.2")
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Found assembler: /home/esp/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Check for working C compiler: /home/esp/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc - skipped
-- Check for working CXX compiler: /home/esp/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ - skipped
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
Cannot parse CMake requirements line: __component_set_property(___idf_LinkSDK REQUIRES "mbedtls;cxx;newlib;freertos;esp_hw_support;heap;log;lwip;soc;hal;esp_rom;esp_common;esp_system;esp32")
CMake Error at /home/esp/esp/esp-idf/tools/cmake/component.cmake:243 (message):
/home/esp/esp/esp-idf/tools/cmake/build.cmake:487 (__component_get_requirements)
/home/esp/esp/esp-idf/tools/cmake/project.cmake:361 (idf_build_process)
CMakeLists.txt:6 (project)
See also "/home/esp/esp/station/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1
LinkSDK的CMakeLists.txt
9 idf_component_register(SRCS "core/*.c"
8 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "core/utils/*.c"
7 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "core/sysdep/*.c"
6 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "portfiles/aiot_port/*.c"
5 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "external/*.c"
4 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊INCLUDE_DIRS core
3 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊INCLUDE_DIRS core/sysdep
2 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊INCLUDE_DIRS core/utils
1 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊REQUIRES mbedtls)
10
tree
├── ChangeLog.md
├── CMakeLists.txt
├── components
│ ├── bootstrap
│ │ ├── aiot_bootstrap_api.c
│ │ ├── aiot_bootstrap_api.h
│ │ ├── bootstrap_private.h
│ │ └── README.md
│ ├── data-model
│ │ ├── aiot_dm_api.c
│ │ ├── aiot_dm_api.h
│ │ ├── dm_private.h
│ │ └── README.md
│ ├── devinfo
│ │ ├── aiot_devinfo_api.c
│ │ ├── aiot_devinfo_api.h
│ │ ├── devinfo_private.h
│ │ └── README.md
│ ├── diag
│ │ ├── aiot_diag_api.c
│ │ ├── aiot_diag_api.h
│ │ ├── diag_private.h
│ │ └── README.md
│ ├── logpost
│ │ ├── aiot_logpost_api.c
│ │ ├── aiot_logpost_api.h
│ │ ├── logpost_private.h
│ │ └── README.md
│ ├── ntp
│ │ ├── aiot_ntp_api.c
│ │ ├── aiot_ntp_api.h
│ │ ├── ntp_private.h
│ │ └── README.md
│ ├── ota
│ │ ├── aiot_ota_api.c
│ │ ├── aiot_ota_api.h
│ │ ├── ota_md5.c
│ │ ├── ota_md5.h
│ │ ├── ota_private.h
│ │ └── README.md
│ ├── remote-access
│ │ ├── aiot_ra_api.c
│ │ ├── aiot_ra_api.h
│ │ ├── aiot_ra_private.h
│ │ ├── COPYING
│ │ ├── NOTICE
│ │ └── src
│ │ ├── nopoll
│ │ │ ├── include
│ │ │ │ ├── nopoll_config.h
│ │ │ │ ├── nopoll_conn.h
│ │ │ │ ├── nopoll_conn_opts.h
│ │ │ │ ├── nopoll_ctx.h
│ │ │ │ ├── nopoll_decl.h
│ │ │ │ ├── nopoll.h
│ │ │ │ ├── nopoll_handlers.h
│ │ │ │ ├── nopoll_log.h
│ │ │ │ ├── nopoll_msg.h
│ │ │ │ └── nopoll_private.h
│ │ │ ├── library
│ │ │ │ ├── nopoll.c
│ │ │ │ ├── nopoll_conn.c
│ │ │ │ ├── nopoll_conn_opts.c
│ │ │ │ ├── nopoll_ctx.c
│ │ │ │ ├── nopoll_decl.c
│ │ │ │ ├── nopoll_log.c
│ │ │ │ └── nopoll_msg.c
│ │ │ └── makefile
│ │ ├── ra_buffer_mgr.c
│ │ ├── ra_buffer_mgr.h
│ │ ├── ra_proxy_channel.c
│ │ ├── ra_proxy_channel.h
│ │ ├── ra_proxy_protocol.c
│ │ ├── ra_proxy_protocol.h
│ │ ├── ra_proxy_thread.c
│ │ ├── ra_proxy_thread.h
│ │ ├── ra_proxy_trans.c
│ │ ├── ra_proxy_trans.h
│ │ ├── ra_session_mgr.c
│ │ └── ra_session_mgr.h
│ ├── shadow
│ │ ├── aiot_shadow_api.c
│ │ ├── aiot_shadow_api.h
│ │ ├── README.md
│ │ └── shadow_private.h
│ ├── subdev
│ │ ├── aiot_subdev_api.c
│ │ ├── aiot_subdev_api.h
│ │ ├── cJSON.c
│ │ ├── cJSON.h
│ │ ├── README.md
│ │ └── subdev_private.h
│ └── task
│ ├── aiot_task_api.c
│ ├── aiot_task_api.h
│ ├── README.md
│ └── task_private.h
├── core
│ ├── aiot_http_api.h
│ ├── aiot_mqtt_api.c
│ ├── aiot_mqtt_api.h
│ ├── aiot_state_api.c
│ ├── aiot_state_api.h
│ ├── aiot_sysdep_api.h
│ ├── README.md
│ ├── sysdep
│ │ ├── core_adapter.c
│ │ ├── core_adapter.h
│ │ ├── core_stdinc.h
│ │ ├── core_sysdep.c
│ │ └── core_sysdep.h
│ └── utils
│ ├── core_auth.c
│ ├── core_auth.h
│ ├── core_diag.c
│ ├── core_diag.h
│ ├── core_global.c
│ ├── core_global.h
│ ├── core_http.c
│ ├── core_http.h
│ ├── core_list.h
│ ├── core_log.c
│ ├── core_log.h
│ ├── core_mqtt.h
│ ├── core_sha256.c
│ ├── core_sha256.h
│ ├── core_string.c
│ └── core_string.h
├── external
│ ├── ali_ca_cert.c
│ ├── mbedtls
│ │ ├── include
│ │ │ └── mbedtls
│ │ │ ├── aes.h
│ │ │ ├── asn1.h
│ │ │ ├── base64.h
│ │ │ ├── bignum.h
│ │ │ ├── bn_mul.h
│ │ │ ├── check_config.h
│ │ │ ├── cipher.h
│ │ │ ├── cipher_internal.h
│ │ │ ├── config.h
│ │ │ ├── ctr_drbg.h
│ │ │ ├── debug.h
│ │ │ ├── des.h
│ │ │ ├── ecp.h
│ │ │ ├── entropy.h
│ │ │ ├── entropy_poll.h
│ │ │ ├── error.h
│ │ │ ├── md5.h
│ │ │ ├── md.h
│ │ │ ├── md_internal.h
│ │ │ ├── net.h
│ │ │ ├── net_sockets.h
│ │ │ ├── oid.h
│ │ │ ├── pem.h
│ │ │ ├── pk.h
│ │ │ ├── pk_internal.h
│ │ │ ├── platform.h
│ │ │ ├── rsa.h
│ │ │ ├── sha1.h
│ │ │ ├── sha256.h
│ │ │ ├── ssl_ciphersuites.h
│ │ │ ├── ssl_cookie.h
│ │ │ ├── ssl.h
│ │ │ ├── ssl_internal.h
│ │ │ ├── timing.h
│ │ │ ├── x509_crl.h
│ │ │ ├── x509_crt.h
│ │ │ └── x509.h
│ │ └── library
│ │ ├── aes.c
│ │ ├── asn1parse.c
│ │ ├── base64.c
│ │ ├── bignum.c
│ │ ├── cipher.c
│ │ ├── cipher_wrap.c
│ │ ├── ctr_drbg.c
│ │ ├── debug.c
│ │ ├── entropy.c
│ │ ├── entropy_poll.c
│ │ ├── error.c
│ │ ├── md.c
│ │ ├── md_wrap.c
│ │ ├── net_sockets.c
│ │ ├── oid.c
│ │ ├── pem.c
│ │ ├── pk.c
│ │ ├── pkparse.c
│ │ ├── pk_wrap.c
│ │ ├── platform.c
│ │ ├── rsa.c
│ │ ├── sha1.c
│ │ ├── sha256.c
│ │ ├── ssl_ciphersuites.c
│ │ ├── ssl_cli.c
│ │ ├── ssl_cookie.c
│ │ ├── ssl_tls.c
│ │ ├── timing.c
│ │ ├── x509.c
│ │ └── x509_crt.c
│ └── README.md
├── Makefile
└── portfiles
├── aiot_port
│ ├── posix_port.c
│ └── posix_port.c(8266)
└── README.md
移植阿里云esp32 C_SDK 出现的问题idf4.4
Re: 移植阿里云esp32 C_SDK 出现的问题idf4.4
你可以参考 https://github.com/espressif/esp-aliyun 来做,估计是 CMakeLists.txt 没写太正确。或者你把你当前的 sample project 推到 github 或 gitee。
解决了吗,我基于阿里云官方的移植方法也报错
建议先按照官方提供的版本进行移植,保证官方的方法是有效的。如果还是不行,可以提交代码至github或者 gitee,我们帮忙分析。
Users browsing this forum: No registered users and 63 guests
