Re: ESP32-S2 USB Host CDC问题
Posted: Tue Jul 20, 2021 2:08 pm
I just updated usb component in that repository and now it builds, please try again.
still build error
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c: In function 'cdc_create_pipe':
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c:129:40: error: 'USB_XFER_TYPE_INTR' undeclared (first use in this function); did you mean 'USB_TRANSFER_TYPE_INTR'?
if(USB_DESC_EP_GET_XFERTYPE(ep) == USB_XFER_TYPE_INTR){
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c:129:40: note: each undeclared identifier is reported only once for each function it appears in
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c:132:47: error: 'USB_XFER_TYPE_BULK' undeclared (first use in this function); did you mean 'USB_TRANSFER_TYPE_BULK'?
} else if(USB_DESC_EP_GET_XFERTYPE(ep) == USB_XFER_TYPE_BULK && USB_DESC_EP_GET_EP_DIR(ep)){
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c: In function 'usbh_set_address_cb':
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c:99:18: error: implicit declaration of function 'hcd_pipe_update'; did you mean 'hcd_pipe_update_mps'? [-Werror=implicit-function-declaration]
if(ESP_OK != hcd_pipe_update(ctrl_pipe_hdl, DEVICE_ADDR, bMaxPacketSize0)) ESP_LOGE("", "failed to update ctrl pipe");
hcd_pipe_update_mps
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c: In function 'usbh_port_connection_cb':
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c:145:22: warning: unused variable 'state' [-Wunused-variable]
hcd_port_state_t state;
