ES32-S3上电无法启动esp_core_dump_flash
lex505260007
Postby lex505260007 » Mon Mar 27, 2023 2:00 pm
上电串口打印信息 无法启动,不知道哪里的问题,好心人解答下
ELF file SHA256: 5b8e7b8cba2a208c
E (765) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
Rebooting...
f﨓SP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x2a (SPI_FAST_FLASH_BOOT)
Saved PC:0x40376bdc
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x1654
load:0x403b6000,len:0xed4
load:0x403ba000,len:0x32dc
entry 0x403b632c
[0;32mI (29) boot: ESP-IDF v4.4.1-405-g6c5fb29c2c 2nd stage bootloader[0m
[0;32mI (29) boot: compile time 04:22:20[0m
[0;32mI (29) boot: chip revision: 0[0m
[0;32mI (32) qio_mode: Enabling default flash chip QIO[0m
[0;32mI (38) boot.esp32s3: Boot SPI Speed : 80MHz[0m
[0;32mI (42) boot.esp32s3: SPI Mode : QIO[0m
[0;32mI (47) boot.esp32s3: SPI Flash Size : 8MB[0m
[0;32mI (52) boot: Enabling RNG early entropy source...[0m
[0;32mI (57) boot: Partition Table:[0m
[0;32mI (61) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (68) boot: 0 nvs WiFi data 01 02 00009000 00005000[0m
[0;32mI (75) boot: 1 otadata OTA data 01 00 0000e000 00002000[0m
[0;32mI (83) boot: 2 ota_0 OTA app 00 10 00010000 00200000[0m
[0;32mI (90) boot: 3 ota_1 OTA app 00 11 00210000 00200000[0m
[0;32mI (98) boot: 4 uf2 factory app 00 00 00410000 00040000[0m
[0;32mI (105) boot: 5 ffat Unknown data 01 81 00450000 003b0000[0m
[0;32mI (113) boot: End of partition table[0m
[0;32mI (617) esp_image: segment 0: paddr=00010020 vaddr=3c030020 size=0be9ch ( 48796) map[0m
[0;32mI (625) esp_image: segment 1: paddr=0001bec4 vaddr=3fc91100 size=03e9ch ( 16028) load[0m
[0;32mI (628) esp_image: segment 2: paddr=0001fd68 vaddr=40374000 size=002b0h ( 688) load[0m
[0;32mI (631) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=25f64h (155492) map[0m
[0;32mI (663) esp_image: segment 4: paddr=00045f8c vaddr=403742b0 size=0ce48h ( 52808) load[0m
[0;32mI (679) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (679) boot: Disabling RNG early entropy source...[0m
E (696) spi_flash: Detected size(4096k) smaller than the size in the binary image header(8192k). Probe failed.
assert failed: do_core_init startup.c:326 (flash_ret == ESP_OK)
Backtrace: 0x40376fce:0x3fceb170 0x40379689:0x3fceb190 0x4037f52d:0x3fceb1b0 0x4200882e:0x3fceb2e0 0x4037693d:0x3fceb310 0x403bb428:0x3fceb340 0x403bb891:0x3fceb380 0x403b63de:0x3fceb4b0 0x40045c01:0x3fceb570 |<-CORRUPTED
yake827
Re: ES32-S3上电无法启动esp_core_dump_flash
Postby yake827 » Wed Mar 29, 2023 12:21 am
打印信息已经明确给你指明了问题
“E (696) spi_flash: Detected size(4096k) smaller than the size in the binary image header(8192k). Probe failed.”
你在配置项 “Serial flasher config → Flash size” 中选择的 flash 是 8MB 的,但是实际运行时检查是 4MB的,你只需要在配置项改为 4MB重新编译运行即可
Users browsing this forum: No registered users and 16 guests
