VS Code Extension, includes missing, menuconfig not showing up [IDFGH-3001]
su-Koch
Postby su-Koch » Sat Jan 25, 2020 2:35 pm
Hello Guys,
I' struggling with vs code extension and this is so annoying.
I'm using python 3.8 32-Bit Version and git 2.21.0 for windows.
Setting up esp-idf and tools is working well.
I'm using following esp-idf tools setup:
xtensa-esp32-elf: esp32-2019r1-8.2.0
xtensa-esp32s2-elf: esp32s2-dev-4-g3a626e93-8.2.0
esp32ulp-elf: 2.28.51.20170517
cmake: 3.13.4
openocd-esp32: v0.10.0-esp32-20190708
ninja: 1.9.0
idf-exe: 1.0.1
ccache: 3.7
Checking Python requirements using python
Python requirements from c:\APPL\esp-idf\requirements.txt are satisfied.
VS Code Extension GUI Setup Guide guides me through installation and everthing seams to be ok.
After i selected one of the demo projects "blink" it opened it fine, and it build fine. But there are still red squiggles for all the #includes.
Also, when I click on menuconfig i just get a pop window saying "ESP-IDF: Menuconfig: Loading initial values..." and it never does anything.
I know there is at least one other user in this forum (@username) who has the same problems.
It has cost me hours of time know and it is really anoying. Even reinstallation did not help. Using esp-idf v4.0 also did not help. Any suggestions how to solve this problems?
Why do I use the new VS Code plugin? Because I had exactly the same issues with eclipse plugin :oops: :evil: :twisted: :twisted: :twisted:
I hope anyone can help me out here.
Manuel
boarchuz
Re: VS Code Extension, includes missing, menuconfig not showing up
Postby boarchuz » Sun Jan 26, 2020 8:50 pm
Squiggles: You need to set up Intellisense. Instructions here: https://github.com/espressif/vscode-esp ... URATION.md
Menuconfig: Close VS Code, delete your project's build folder, launch VS Code and try again.
su-Koch
Postby su-Koch » Mon Mar 30, 2020 9:07 pm
posted this in wrong thread, please delete
ESP_Alvin
Re: VS Code Extension, includes missing, menuconfig not showing up [IDFGH-3001]
Postby ESP_Alvin » Tue Mar 31, 2020 2:04 am
Moderator's note: edit the topic title for issue tracking, thanks.
kondalkolipaka
Postby kondalkolipaka » Tue Mar 31, 2020 5:55 am
Please check this thread https://github.com/espressif/idf-eclips ... -557410081
I hope this helps
