Hello everyone,
i am new with esp32. I tried to setup eclipse under this Link https://github.com/espressif/idf-eclipse-plugin
Build is failed and following messages appeared.
FAILED: bootloader-prefix/src/bootloader-stamp/bootloader-build bootloader/bootloader.elf bootloader/bootloader.bin bootloader/bootloader.map
cmd.exe /C "cd /D "C:\Workspace\Workspace Eclipse\test1\build\bootloader" && C:\Users\vanng\.espressif\tools\cmake\3.13.4\bin\cmake.exe --build ."
[1/2] Linking C executable bootloader.elf
FAILED: bootloader.elf
Could you please have me to solve it!? Many thanks in advance!
Best regards
Han
Eclipse build failed
- elipse_esp32.png (197.54 KiB) Viewed 14394 times
Re: Eclipse build failed
Could you please provide the global build log as per the instructions. https://github.com/espressif/idf-eclips ... -build-log
Also provide PATH value from the CDT build preferences. That will help us to see whether any path variable is missing
For example, PATH value looks like this https://github.com/espressif/idf-eclipse-plugin#path so check if anything is missing
Preferences > C/C++ Build > Environment
Hello kondalkolipaka,
you can see in Attachment the Picture of Espressif IDF Tools Console .
In which I saw the message
"Executing C:\Program Files\Python\python.exe C:\Workspace\esp-idf-v4.0\tools\idf_tools.py install-python-env
Creating a new Python environment in C:\Users\vanng\.espressif\python_env\idf4.0_py3.7_env"
I checked the folder \.espressif and I did not found the python_env folder, maybe is something wrong here?
PATH value from Build Enviroment is
C:\Users\vanng\.espressif\tools\xtensa-esp32-elf\esp-2019r2-8.2.0\xtensa-esp32-elf\bin;
C:\Users\vanng\.espressif\tools\esp32ulp-elf\2.28.51.20170517\esp32ulp-elf-binutils\bin;
C:\Users\vanng\.espressif\tools\cmake\3.13.4\bin;
C:\Users\vanng\.espressif\tools\openocd-esp32\v0.10.0-esp32-20190313\openocd-esp32\bin;
C:\Users\vanng\.espressif\tools\mconf\v4.6.0.0-idf-20190628\;
C:\Users\vanng\.espressif\tools\ninja\1.9.0\;
C:\Users\vanng\.espressif\tools\idf-exe\1.0.1\;
C:\Users\vanng\.espressif\tools\ccache\3.7\;
C:\Workspace\esp-idf-v4.0\tools;
C:/Program Files/Java/jre1.8.0_241/bin/server;
C:/Program Files/Java/jre1.8.0_241/bin;
C:/Program Files/Java/jre1.8.0_241/lib/amd64;
C:\Program Files (x86)\Common Files\Oracle\Java\javapath;
C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;
C:\Windows\System32\WindowsPowerShell\v1.0\;
C:\Windows\System32\OpenSSH\;C:\Program Files\dotnet\;
C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;
C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;
C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility;
C:\Program Files\TortoiseSVN\bin;C:\Program Files\doxygen\bin;
C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;
C:\Program Files\Java\jdk-13.0.2\bin;
C:\Program Files\Git\bin;
C:\Program Files\Python;C:\Users\vanng\AppData\Local\Microsoft\WindowsApps;
C:\Users\vanng\Downloads\eclipse-cpp-2019-09-R-win32-x86_64\eclipse
Thanks you for your effort!
Best regards
Han
Best regards
Han
- esp32_1.png (39.25 KiB) Viewed 14312 times
- esp32_2.png (25.27 KiB) Viewed 14312 times
At least I don't see any issue with the PATH environment variable.
Could you run the below command from the terminal and see what happens?
Does it show any error? Is it able to install the required python version for the selected idf?
As you pointed out, python path might be causing an issue.
I could see below entry in the PATH environment variable and which is missing in your case.
C:\Users\kondalk\.espressif\python_env\idf4.1_py3.8_env\Scripts;
Now it works for me.
I deleted all related Folders and did the installation from beginning.
The different was I made clone ESP-IDF Folder instead of Zip download as previously.
Now I can see the missing python_env Folder in .espressif Folder
Many thanks for your supports.
Best regards
Han
Best regards
Han
Hi
I may find a solution that can solve the problem.
I'm was also tormented by this problem and I'm using VS code. The problem occurs with different means of installation, which leads me to believe that it is not a problem with the installation. I check the Official Documents of ESPIDE. It says here that the name of your file path cannot contain any spaces and I noticed that your file path is contain with spaces.
SO check you file path , make sure no such problems. Is should be fine.
Users browsing this forum: No registered users and 29 guests
