VSCODE ESP-IDF Plugin Debug Problem
su-Koch
Postby su-Koch » Mon Sep 14, 2020 8:06 pm
hei Guys,
I'm facing some issues with the Debugger of the VisualStudioCode ESP-IDF Estension.
I installed my Debugger Shield and the according Driver. OpenOCD Server can be started using the user interface.
Hitting F5 (to launch the default esp-idf debugger configuration)
I receive the following error code:
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\command_processor.py", line 50, in __call__
    on_request(protocol_message)
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\command_processor.py", line 87, in on_initialize_request
    self.da.adapter_init()
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_adapter.py", line 290, in adapter_init
    self.start_gdb()
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_adapter.py", line 511, in start_gdb
    raise e
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_adapter.py", line 506, in start_gdb
    remote_target=(not self.state.openocd_skip_connection)
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_backend\debug_backend\hw_spec_tools.py", line 97, in get_gdb
    remote_port=remote_port, **kwargs)
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_backend\debug_backend\hw_specific\Esp32.py", line 35, in __init__
    top_defaults=self.config, **kwargs)
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_backend\debug_backend\hw_specific\Esp.py", line 36, in __init__
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_backend\debug_backend\hw_specific\Xtensa.py", line 80, in __init__
  File "c:\Users\dev\.vscode\extensions\espressif.esp-idf-extension-0.4.0\esp_debug_adapter\debug_adapter\debug_backend\debug_backend\gdb.py", line 54, in __init__
    self._gdbmi = GdbController(gdb_path=gdb_path)
TypeError: __init__() got an unexpected keyword argument 'gdb_path'
Can you tell me whats the error?
Using the C/C++ Extension OpenOCD Debugger I do not receive errors but it seems like the debugging session is not connected and also no breakpoints are not hit.
ESP IDF Extension v4.0 was installed via the VisualStudioCode Extension Setuo Guide in the Userinterface of VSCode. Alos the espressif tools where installed this way.
Hope someone can help me.
Manuel
ESP_Soumesh
Re: VSCODE ESP-IDF Plugin Debug Problem
Postby ESP_Soumesh » Tue Sep 15, 2020 1:33 am
For debugging using our ESP-IDF debug adapter please follow this guide
https://github.com/espressif/vscode-esp ... ug-adapter
AndreiGramakov
Contact:
Postby AndreiGramakov » Tue Sep 15, 2020 10:37 am
Hi!
It seems, it is because of breaking changes in pygdbmi package that used by our debugging system. You can check it running from PowerShell at you IDF folder (it is C:\Users\YOUR_USER_NAME\esp-idf if you installed it with the extension's defaults):
. ./export.ps1
pip list -l
I expect to see there pygdbmi 0.10.x.x
If so, we will prepare fix for this, now you can fix it manually for your machine. Open your IDF folder in PowerShell and then:
. ./export.ps1
pip install 'pygdbmi==0.9.0.2'
Please drop here several words if it helped
Embedded Sofware Engineer @ Espressif Systems
su-Koch
Postby su-Koch » Tue Sep 15, 2020 1:55 pm
This is so awesome. Switching to 0.9.0.2. helped.
As a note: I wasn't able to solve that via powershell but solved it in the command line running the python commands
Thank you very much.
Manuel
su-Koch
Postby su-Koch » Tue Sep 15, 2020 2:25 pm
Debugging works now but the behaviour is strange.
The Debugger Stopps execution on lines where no breakpoints are and doesn't stop on breakpoints.
What the debugger does and what i was expecting is to stop on the beginning of main.
Any Suggestions to solve this issu?
Manuel
AndreiGramakov
Contact:
Postby AndreiGramakov » Wed Sep 23, 2020 1:15 pm
su-Koch, could it be that you forgot to flash the rom after the modification? If it is not the case, please provide some extra info: in which situation it is happening and with which setup (idf version, esp32 board, used debugger, etc.). I will try to reproduce it.
Thank you
Users browsing this forum: No registered users and 40 guests
