Unable to buid VS Code
asgardee
Postby asgardee » Wed Mar 24, 2021 6:01 am
I followed the youtube video series (viewtopic.php?f=40&t=18468) which is a quick start guide for developing programs for the ESP32 using VS Code; however, when I try to build my program the following errors show up in the VS Code terminal:
idf_versions.txt has (1) KB
idf_versions.txt progress: 100.00% (0.08 / 0.08) KB
The following Python requirements are not satisfied:
pyserial>=3.0
future>=0.15.2
cryptography>=2.1.4
pyparsing>=2.0.3,<2.4.0
pyelftools>=0.22
gdbgui==0.13.2.0
reedsolo>=1.5.3,<=1.5.4
bitstring>=3.1.6
ecdsa>=0.16.0
esp-windows-curses; sys_platform == 'win32'
To install the missing packages, please run "C:\Users\asgar\esp\esp-idf\install.bat"
Diagnostic information:
    IDF_PYTHON_ENV_PATH: C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env
    Python interpreter used: C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe
Command failed: "C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe" "C:\Users\asgar\esp\esp-idf\tools\check_python_dependencies.py" -r "C:\Users\asgar\esp\esp-idf\requirements.txt"
I have checked my python installation and I have these extensions downloaded. These extensions should have also been downloaded during the setup, but I made sure to pip install them again just to be sure. I tried running the .bat file but several problems arose causing me to use pip install instead. This didn't fix anything but I think the "idf_versions.txt" file may be the issue. I was unable to find this file in my temp directory or the esp directory on my local system. Any help would be greatly appreciated.
ESP_bignacio
Re: Unable to buid VS Code
Postby ESP_bignacio » Thu Mar 25, 2021 8:05 am
Can you provide additional information of your setup ?
**Environment (please complete the following information):**
- OS Name & Version: [e.g. MacOS X 10.14.5]
- VSCode Version: [e.g. 1.35.1]
- ESP-IDF Version: [e.g. v3.2.2]
- Python Version: [e.g. 2.7.10]
You can use the "ESP-IDF: Doctor command" to generate a report of your configuration that already provide everything below.
Logs
If applicable, please share the log file which can be obtained from
- Windows: `%USERPROFILE%\.vscode\extensions\espressif.esp-idf-extension-VERSION\esp_idf_vsc_ext.log`
- Linux & MacOSX: `$HOME/.vscode/extensions/espressif.esp-idf-extension-VERSION/esp_idf_vsc_ext.log`
Extension Configuration settings
Open Command Palette (F1) and type `Preferences: Open Settings (JSON)` or use {CURRENT_PROJECT}/.vscode/settings.json to get the following extension configuration settings value:
- idf.espIdfPath (MacOS or Linux) or `idf.espIdfPathWin` (Windows) also called `Path to locate ESP-IDF framework (IDF_PATH)` in `Preferences: Open Settings (UI)`.
- idf.pythonBinPath (MacOS or Linux) or idf.pythonBinPathWin (Windows) also called `Python absolute binary path used to execute ESP-IDF Python Scripts` in `Preferences: Open Settings (UI)`.
- idf.openOcdConfigs also called `List of configuration files inside OpenOCD Scripts directory` in `Preferences: Open Settings (UI)`.
- idf.customExtraPaths also called `Paths to be appended to PATH` in `Preferences: Open Settings (UI)`.
- idf.customExtraVars also called `Variables to be added to system environment variables` in `Preferences: Open Settings (UI)`.
- idf.adapterTargetName also called `Target name for ESP-IDF Debug Adapter` in `Preferences: Open Settings (UI)`.
- idf.customAdapterTargetName is used when idf.adapterTargetName is set to `custom`.
asgardee
Postby asgardee » Thu Mar 25, 2021 7:22 pm
Hello ESP_bignacio,
Thanks for your support. The requested information can be found below:
OS Name & Version: Windows 10 Pro version 20H2 (taken from 'about pc')
VSCode Version: 1.54.3 (taken from 'help/about' in vscode)
ESP-IDF Version: v4.2 (from 'C:\Users\asgar\esp')
Python Version: 3.7.4 (cmd 'python --version')
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS win32 x64 10.0.19042
System environment variable PATH
C:\Program Files (x86)\Microsoft Visual Studio\Shared\Python37_64\Scripts\;C:\Program Files (x86)\Microsoft Visual Studio\Shared\Python37_64\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Microsoft MPI\Bin\;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Users\asgar\Anaconda3;C:\Users\asgar\Anaconda3\Scripts;C:\Softwares\cmake-3.15.0-win64-x64\bin;C:\Users\asgar\.cargo\bin;C:\Users\asgar\AppData\Local\Microsoft\WindowsApps;;C:\Program Files\JetBrains\PyCharm 2018.3\bin;;C:\Users\asgar\AppData\Local\Programs\Microsoft VS Code\bin
Visual Studio Code version 1.0.1
Visual Studio Code language en
Visual Studio Code shell C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe
ESP-IDF Extension version 1.54.3
---------------------------------------------------- Extension configuration settings ------------------------------------------------------
ESP-IDF Path (idf.espIdfPath) C:\Users\asgar\esp\esp-idf
Custom extra paths (idf.customExtraPaths) C:\Users\asgar\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin;C:\Users\asgar\.espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin;C:\Users\asgar\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin;C:\Users\asgar\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin;C:\Users\asgar\.espressif\tools\cmake\3.16.4\bin;C:\Users\asgar\.espressif\tools\openocd-esp32\v0.10.0-esp32-20200709\openocd-esp32\bin;C:\Users\asgar\.espressif\tools\ninja\1.10.0;C:\Users\asgar\.espressif\tools\idf-exe\1.0.1;C:\Users\asgar\.espressif\tools\ccache\3.7;C:\Users\asgar\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
Custom extra vars (idf.customExtraVars) {"OPENOCD_SCRIPTS":"C:\\Users\\asgar\\.espressif\\tools\\openocd-esp32\\v0.10.0-esp32-20200709/openocd-esp32/share/openocd/scripts","IDF_CCACHE_ENABLE":"1"}
Virtual env Python Path (idf.pythonBinPath) C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe
Serial port (idf.port) /dev/ttyUSB1
OpenOCD Configs (idf.openOcdConfigs) interface/ftdi/esp32_devkitj_v1.cfg,board/esp32-wrover.cfg
ESP-IDF Tools Path (idf.toolsPath) ${env:IDF_TOOLS_PATH}
-------------------------------------------------------- Configurations access -------------------------------------------------------------
Access to ESP-IDF Path (idf.espIdfPath) true
Access to ESP-IDF Custom extra paths
Access to C:\Users\asgar\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin: true
Access to C:\Users\asgar\.espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin: true
Access to C:\Users\asgar\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin: true
Access to C:\Users\asgar\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin: true
Access to C:\Users\asgar\.espressif\tools\cmake\3.16.4\bin: true
Access to C:\Users\asgar\.espressif\tools\openocd-esp32\v0.10.0-esp32-20200709\openocd-esp32\bin: true
Access to C:\Users\asgar\.espressif\tools\ninja\1.10.0: true
Access to C:\Users\asgar\.espressif\tools\idf-exe\1.0.1: true
Access to C:\Users\asgar\.espressif\tools\ccache\3.7: true
Access to C:\Users\asgar\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64: true
Access to Virtual env Python Path (idf.pythonBinPath) true
Access to CMake in environment PATH undefined
Access to Ninja in environment PATH undefined
Access to ESP-IDF Tools Path (idf.toolsPath) false
----------------------------------------------------------- Executables Versions -----------------------------------------------------------
Git version 2.21.0.windows.1
ESP-IDF version 4.2
Python version 3.7.4
Python's pip version 19.0.3
-------------------------------------------------- Python packages in idf.pythonBinPath ----------------------------------------------------
certifi version: 2020.12.5
chardet version: 4.0.0
click version: 7.1.2
gcovr version: 4.2
idna version: 2.10
Jinja2 version: 2.11.3
lxml version: 4.6.3
MarkupSafe version: 1.1.1
pip version: 19.0.3
psutil version: 5.8.0
pygdbmi version: 0.9.0.2
pywin32 version: 300
requests version: 2.25.1
setuptools version: 40.8.0
six version: 1.15.0
urllib3 version: 1.26.4
websocket-client version: 0.58.0
wheel version: 0.36.2
xmlrunner version: 1.7.7
---------------------------------------------------- Check ESP-IDF python requirements.txt -------------------------------------------------
Check ESP-IDF Python packages undefined
---------------------------------------------------- Check extension requirements.txt ------------------------------------------------------
Check Extension Python packages undefined
---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------
Check Debug AdapterPython packages undefined
----------------------------------------------------------- Latest error -----------------------------------------------------------------
Latest error at Command failed: C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe C:\Users\asgar\esp\esp-idf\tools\check_python_dependencies.py -r "C:\Users\asgar\esp\esp-idf\requirements.txt"
ESP_bignacio
Postby ESP_bignacio » Mon Mar 29, 2021 4:23 am
Based on Doctor command output I assume something failed while installing Python packages for ESP-IDF in your setup.
In any terminal in your system do:
C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe -m pip install -r "C:\Users\asgar\esp\esp-idf\requirements.txt"
C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe -m pip install -r "C:\Users\asgar\.vscode\extensions\espressif.esp-idf-extension-1.0.1\requirements.txt"
C:\Users\asgar\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe -m pip install -r "C:\Users\asgar\.vscode\extensions\espressif.esp-idf-extension-1.0.1\esp_debug_adapter\requirements.txt"
I'm just assuming the location of the extension here, please verify C:\Users\asgar\.vscode\extensions\espressif.esp-idf-extension-1.0.1 is the extension directory.
qballza
Postby qballza » Fri Sep 24, 2021 10:38 am
i am having endless nightmares in trying to get the esp-prog to debug. it was working fine a few days ago but something changed and i have struggled since to the point of losing my mind. i am using a ttgolorav1 and esp-prog.
everytime i try debug now it gives me:
"failed to launch gdb: .pioinit:11: error in sourced command file:
remote communication error. target disconnectd.: no error. (from interpreter-exec console "source.pioinit")
my output from esp-idf: doctor is as follows.
PLEASE assist if possible. thank you
System environment variable IDF_PYTHON_ENV_PATH
undefined
C:\Python 3.7\Scripts\;C:\Python 3.7\;I:\Python 3.7\Scripts\;I:\Python 3.7\;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Intuit\QBPOSSDKRuntime;C:\laragon\bin\php\php-7.1.19-nts-Win32-VC14-x86;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\dotnet\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\laragon\bin;C:\laragon\bin\apache\Apache24\bin;C:\laragon\bin\composer;C:\laragon\bin\git\bin;C:\laragon\bin\git\cmd;C:\laragon\bin\git\mingw64\bin;C:\laragon\bin\git\usr\bin;C:\la;C:\WINDOWS\SysWOW64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\ProgramData\chocolatey\bin;C:\Program Files (x86)\Common Files\Acronis\SnapAPI\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Microsoft\Web Platform Installer\;D:\March 2020 Download\Microchip\xc16\v1.70\bin;C:\Program Files\nodejs\;C:\Program Files\PuTTY\;D:\MpLabX\XC16\bin;D:\MpLabX\XC8\bin;C:\Program Files\Git\cmd;";C:\Users\quintin\esp\esp-idf\tools";C:\Users\quintin\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\quintin\AppData\Local\Programs\Python\Python39\;C:\laragon\bin;C:\laragon\bin\apache\Apache24\bin;C:\laragon\bin\composer;C:\laragon\bin\git\bin;C:\laragon\bin\git\cmd;C:\laragon\bin\git\mingw64\bin;C:\laragon\bin\git\usr\bin;C:\laragon\bin\laragon\utils;C:\laragon\bin\mysql\mysql-5.7.19-winx64\bin;C:\laragon\bin\nginx\nginx-1.12.0;C:\laragon\bin\ngrok;C:\laragon\bin\nodejs\node-v8;C:\laragon\bin\notepad++;C:\laragon\bin\php\php-7.1.19-nts-Win32-VC14-x86;C:\laragon\bin\putty;C:\laragon\bin\redis\redis-x64-3.2.100;C:\laragon\bin\telnet;C:\laragon\bin\yarn\bin;C:\laragon\usr\bin;C:\Users\quintin\AppData\Local\Yarn\config\global\node_modules\.bin;C:\Users\quintin\AppData\Local\Microsoft\WindowsApps;C:\Users\quintin\AppData\Local\Google\Cloud SDK\google-cloud-sdk\bin;C:\Users\quintin\AppData\Local\atom\bin;C:\Users\quintin\AppData\Local\Microsoft\WindowsApps;C:\src\flutter\bin;C:\Gradle\gradle-6.4.1\bin;C:\tools\dart-sdk\bin;C:\Users\quintin\AppData\Roaming\Pub\Cache\bin;;C:\Program Files\JetBrains\PhpStorm 2021.1.4\bin;;C:\Users\quintin\AppData\Roaming\npm;C:\Users\quintin\AppData\Local\Programs\Microsoft VS Code\bin
System environment variable PYTHON
undefined
Visual Studio Code version 1.60.2
ESP-IDF Extension version 1.2.0
ESP-ADF Path (idf.espAdfPath) ${env:ADF_PATH}
ESP-IDF Path (idf.espIdfPath) ${env:IDF_PATH}
ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH}
Virtual env Python Path (idf.pythonBinPath) python
Serial port (idf.port) COM1
OpenOCD Configs (idf.openOcdConfigs) board/esp32c3-ftdi.cfg
Git Path (idf.gitPath) git
Access to ESP-ADF Path (idf.espAdfPath) false
Access to ESP-IDF Path (idf.espIdfPath) false
Access to ESP-MDF Path (idf.espMdfPath) false
Access to Virtual env Python Path (idf.pythonBinPath) false
Git version 2.33.0.windows.2
ESP-IDF version Not found
Python version 3.9.7
Python's pip version 21.2.3
certifi version: 2021.5.30
charset-normalizer version: 2.0.4
dnspython version: 1.16.0
docopt version: 0.6.2
docutils version: 0.17.1
fett version: 0.3.2
idna version: 3.2
networkx version: 2.6.2
pip version: 21.2.3
pymongo version: 3.11.4
python-jsonrpc-server version: 0.3.4
PyYAML version: 5.4.1
requests version: 2.26.0
setuptools version: 57.4.0
snooty-lextudio version: 1.11.4.dev0
toml version: 0.10.2
typing-extensions version: 3.10.0.2
urllib3 version: 1.26.6
watchdog version: 1.0.2
Check ESP-IDF Python packages Error
Check Extension Python packages Error
Check Debug AdapterPython packages Error
---------------------------------------------------- Visual Studio Code launch.json --------------------------------------------------------
// AUTOMATICALLY GENERATED FILE. PLEASE DO NOT MODIFY IT MANUALLY
// PIO Unified Debugger
// Documentation: https://docs.platformio.org/page/plus/debugging.html
// Configuration: https://docs.platformio.org/page/projec ... debug.html
"version": "0.2.0",
"configurations": [
"type": "platformio-debug",
"request": "launch",
"name": "PIO Debug",
"executable": "C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/.pio/build/ttgo-lora32-v1/firmware.elf",
"projectEnvName": "ttgo-lora32-v1",
"toolchainBinDir": "C:/Users/quintin/.platformio/packages/toolchain-xtensa32/bin",
"internalConsoleOptions": "openOnSessionStart",
"preLaunchTask": {
"type": "PlatformIO",
"task": "Pre-Debug"
"name": "PIO Debug (skip Pre-Debug)",
---------------------------------------------------- Visual Studio Code c_cpp_properties.json ----------------------------------------------
// !!! WARNING !!! AUTO-GENERATED FILE!
// PLEASE DO NOT MODIFY IT AND USE "platformio.ini":
// https://docs.platformio.org/page/projec ... uild-flags
"configurations": [
"name": "PlatformIO",
"includePath": [
"C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/include",
"C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src",
"C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/.pio/libdeps/ttgo-lora32-v1/Adafruit SSD1306",
"C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/.pio/libdeps/ttgo-lora32-v1/Adafruit GFX Library",
"C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/.pio/libdeps/ttgo-lora32-v1/Adafruit BusIO",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/Wire/src",
"C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/.pio/libdeps/ttgo-lora32-v1/ArduinoUniqueID/src",
"C:/Users/quintin/Documents/PlatformIO/Projects/ElectrifEye_LoRaMesh_v0.1/.pio/libdeps/ttgo-lora32-v1/RadioHead",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/SPI/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/efuse",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_server",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_websocket_client",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/espcoredump",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/unity",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/cores/esp32",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/variants/ttgo-lora32-v1",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/ArduinoOTA/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/AsyncUDP/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/AzureIoT/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/BLE/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/BluetoothSerial/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/DNSServer/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/ESP32/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/ESPmDNS/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/FFat/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/FS/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/HTTPClient/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/HTTPUpdate/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/HTTPUpdateServer/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/NetBIOS/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/Preferences/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/SD/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/SD_MMC/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/SPIFFS/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/SimpleBLE/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/Ticker/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/Update/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/WebServer/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/WiFiClientSecure/src",
"C:/Users/quintin/.platformio/packages/framework-arduinoespressif32/libraries/WiFiProv/src",
"C:/Users/quintin/.platformio/packages/tool-unity",
"browse": {
"limitSymbolsToIncludedHeaders": true,
"path": [
"defines": [
"PLATFORMIO=50201",
"ARDUINO_TTGO_LoRa32_V1",
"ESP32",
"ESP_PLATFORM",
"F_CPU=240000000L",
"HAVE_CONFIG_H",
"MBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"",
"ARDUINO=10805",
"ARDUINO_ARCH_ESP32",
"ARDUINO_VARIANT=\"ttgo-lora32-v1\"",
"ARDUINO_BOARD=\"TTGO LoRa32-OLED V1\"",
"cStandard": "c99",
"cppStandard": "c++11",
"compilerPath": "C:/Users/quintin/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc.exe",
"compilerArgs": [
"-mlongcalls",
"version": 4
Latest error at Command failed: python ${env:IDF_PATH}\tools\check_python_dependencies.py -r "c:\Users\quintin\.vscode\extensions\espressif.esp-idf-extension-1.2.0\esp_debug_adapter\requirements.txt"
python: can't open file 'c:\Users\quintin\.vscode\extensions\espressif.esp-idf-extension-1.2.0\${env:IDF_PATH}\tools\check_python_dependencies.py': [Errno 22] Invalid argument
Users browsing this forum: No registered users and 56 guests
