Extension v1.0.3 installed itself in VScode and none of my projects compile without reinstalling esp-df all over again
Err output below.
CMake Error at C:/esp/esp-idf/tools/cmake/project.cmake:205 (message):
C:\esp\tools\.espressif\python_env\idf4.2_py3.9_env\Scripts\python.exe:
Error while finding module specification for
'idf_component_manager.prepare_components' (ModuleNotFoundError: No module
named 'idf_component_manager')
C:/esp/esp-idf/tools/cmake/project.cmake:292 (__project_init)
CMakeLists.txt:9 (project)
See also "D:/Firmware/Cab/CAB_ROLEC_ESP_PCB0325_G/build/CMakeFiles/CMakeOutput.log".
The terminal process "C:\WINDOWS\System32\cmd.exe /d /c cmake -G Ninja .." terminated with exit code: 1
vscode extension 1.0.3 "breaks" compiler
Re: vscode extension 1.0.3 "breaks" compiler
Why you duplicate your own posts?
viewtopic.php?f=13&t=20630
I could not find the vscode extension forum so posted in the general forum but later found the specific forum.
Can you help or just commenting about policy at the moment?
I don't know why it does that but I can confirm that it does.
This morning I opened my project that I had been working on yesterday and without making any change to it I simply tried to build it and it failed as described by "orbitcoms".
After reading about version 1.0.3 I checked my version of the Espressif IDF exntension and sure enough it was version 1.0.3.
I reverted back to version 1.0.2 and everything works perfectly again so there is no need to reinstall ESP-IDF.
This post is duplicated as our friend chegewara mentioned.
I'll lock this post and we can continue this discussion at: viewtopic.php?f=13&t=20630
Users browsing this forum: No registered users and 30 guests
