Xtensa compiler doesn't work in CLion
ReyMagos
Postby ReyMagos » Thu May 20, 2021 1:49 pm
Hello! I'm new at ESP-IDF and just started to setup idf environment in CLion.
Firstly I cloned idf repository via
git clone --recursive https://github.com/espressif/esp-idf.git
Next step I installed MSYS2 according to https://docs.espressif.com/projects/esp ... setup.html
In Preferencs/Build, Execution, Deployment/Toolchains In CLion I setted compilers (Screenshot_1)
There was this error in CMake log:
-- The C compiler identification is GNU 8.2.0
-- Detecting C compiler ABI info - failed
-- Check for working C compiler: C:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe - broken
CMake Error at C:/Program Files/JetBrains/CLion 2020.3.3/bin/cmake/win/share/cmake-3.19/Modules/CMakeTestCCompiler.cmake:66 (message):
  The C compiler
    "C:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe"
  is not able to compile a simple test program.
  It fails with the following output:
    Change Dir: C:/Users/User/Desktop/esp32/test/cmake-build-debug/CMakeFiles/CMakeTmp
    Run Build Command(s):C:/msys32/usr/bin/make.exe cmTC_b9276/fast && /usr/bin/make  -f CMakeFiles\cmTC_b9276.dir\build.make CMakeFiles/cmTC_b9276.dir/build
     make: *** [Makefile:139: cmTC_b9276/fast] Error 1
  CMake will not be able to correctly generate this project.
  CMakeLists.txt:2 (project)
See also "C:/Users/User/Desktop/esp32/test/cmake-build-debug/CMakeFiles/CMakeOutput.log".
See also "C:/Users/User/Desktop/esp32/test/cmake-build-debug/CMakeFiles/CMakeError.log".
[Finished]
And I don't understand how to fix this problem. Any ideas? I will be grateful for any help.
ESP_bignacio
Re: Xtensa compiler doesn't work in CLion
Postby ESP_bignacio » Fri May 21, 2021 8:28 am
You need to add the Xtensa toolchain to the environment variable PATH, either globally in your system or in the CLion environment variables.
ReyMagos
Postby ReyMagos » Fri May 21, 2021 12:40 pm
I added to PATH next values:
C:\msys32\mingw32\bin
C:\msys32\opt\xtensa-esp32-elf\bin
C:\msys32\usr\bin
After in log except old message new appeared: make: cmd.exe: No such file or directory
I added C:\Windows\system32 to PATH and now log is same as old.
ReyMagos
Postby ReyMagos » Mon May 24, 2021 1:05 pm
Problem solved by adding in CMake options: -DCMAKE_SYSTEM_NAME=Generic
Thank you!
Users browsing this forum: No registered users and 41 guests
