I installed the esp-idf extension in vscode and ran the extension to install esp-idf.
At very end of install process I get error message "Incorrect version of esp-idf"
What can I do to fix this? I selected the release version 4.2 (same as I did when setting up on another machine).
Error with esp-idf extension
Re: Error with esp-idf extension
Run the `ESP-IDF: Doctor Command` and paste the result here or take a look at the output (Menu View -> Output) in ESP-IDF to see what is happening
Result from doctor command
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS win32 x64 10.0.19041
System environment variable PATH
C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\nodejs\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Git\cmd;C:\Users\david\.espressif\tools;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Users\david\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\david\AppData\Local\Programs\Python\Python39\;;C:\Users\david\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\david\.dotnet\tools
Visual Studio Code version 1.57.0
Visual Studio Code language en
Visual Studio Code shell C:\WINDOWS\System32\cmd.exe
ESP-IDF Extension version 1.1.0
---------------------------------------------------- Extension configuration settings ------------------------------------------------------
ESP-ADF Path (idf.espAdfPath) ${env:ADF_PATH}
ESP-IDF Path (idf.espIdfPath) c:\esp\esp-idf
ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH}
Custom extra paths (idf.customExtraPaths) C:\Users\david\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin;C:\Users\david\.espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin;C:\Users\david\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin;C:\Users\david\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin;C:\Users\david\.espressif\tools\cmake\3.16.4\bin;C:\Users\david\.espressif\tools\openocd-esp32\v0.10.0-esp32-20200709\openocd-esp32\bin;C:\Users\david\.espressif\tools\ninja\1.10.0;C:\Users\david\.espressif\tools\idf-exe\1.0.1;C:\Users\david\.espressif\tools\ccache\3.7;C:\Users\david\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
Custom extra vars (idf.customExtraVars) {"OPENOCD_SCRIPTS":"C:\\Users\\david\\.espressif\\tools\\openocd-esp32\\v0.10.0-esp32-20200709/openocd-esp32/share/openocd/scripts","IDF_CCACHE_ENABLE":"1"}
Virtual env Python Path (idf.pythonBinPath) C:\Users\david\.espressif\python_env\idf4.2_py3.9_env\Scripts\python.exe
Serial port (idf.port) COM1
OpenOCD Configs (idf.openOcdConfigs) interface/ftdi/esp32_devkitj_v1.cfg,board/esp32-wrover.cfg
ESP-IDF Tools Path (idf.toolsPath) ${env:IDF_TOOLS_PATH}
Git Path (idf.gitPath) git
-------------------------------------------------------- Configurations access -------------------------------------------------------------
Access to ESP-ADF Path (idf.espIdfPath) false
Access to ESP-IDF Path (idf.espIdfPath) true
Access to ESP-MDF Path (idf.espIdfPath) false
Access to ESP-IDF Custom extra paths
Access to C:\Users\david\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin: true
Access to C:\Users\david\.espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin: true
Access to C:\Users\david\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin: true
Access to C:\Users\david\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin: true
Access to C:\Users\david\.espressif\tools\cmake\3.16.4\bin: true
Access to C:\Users\david\.espressif\tools\openocd-esp32\v0.10.0-esp32-20200709\openocd-esp32\bin: true
Access to C:\Users\david\.espressif\tools\ninja\1.10.0: true
Access to C:\Users\david\.espressif\tools\idf-exe\1.0.1: true
Access to C:\Users\david\.espressif\tools\ccache\3.7: true
Access to C:\Users\david\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64: true
Access to Virtual env Python Path (idf.pythonBinPath) true
Access to CMake in environment PATH undefined
Access to Ninja in environment PATH undefined
Access to ESP-IDF Tools Path (idf.toolsPath) false
----------------------------------------------------------- Executables Versions -----------------------------------------------------------
Git version 2.30.2.windows.1
ESP-IDF version 4.2
Python version 3.9.2
Python's pip version 20.2.3
-------------------------------------------------- Python packages in idf.pythonBinPath ----------------------------------------------------
bidict version: 0.21.2
bitstring version: 3.1.7
Brotli version: 1.0.9
certifi version: 2020.12.5
cffi version: 1.14.5
chardet version: 4.0.0
click version: 7.1.2
contextlib2 version: 0.6.0.post1
cryptography version: 3.4.6
ecdsa version: 0.16.1
esp-windows-curses version: 0.1
Flask version: 0.12.5
Flask-Compress version: 1.9.0
Flask-SocketIO version: 2.9.6
future version: 0.18.2
gcovr version: 4.2
gdbgui version: 0.13.2.0
gevent version: 1.5.0
greenlet version: 1.0.0
idf-component-manager version: 0.2.1a1
idna version: 2.10
itsdangerous version: 1.1.0
Jinja2 version: 2.11.3
lxml version: 4.6.3
MarkupSafe version: 1.1.1
pip version: 20.2.3
psutil version: 5.8.0
pycparser version: 2.20
pyelftools version: 0.27
pygdbmi version: 0.9.0.2
Pygments version: 2.8.1
pyparsing version: 2.3.1
pyserial version: 3.5
python-engineio version: 4.0.1
python-socketio version: 5.1.0
pywin32 version: 300
PyYAML version: 5.4.1
reedsolo version: 1.5.4
requests version: 2.25.1
requests-toolbelt version: 0.9.1
schema version: 0.7.4
semantic-version version: 2.8.5
setuptools version: 49.2.1
six version: 1.15.0
tqdm version: 4.60.0
urllib3 version: 1.26.4
websocket-client version: 0.58.0
Werkzeug version: 0.16.1
wheel version: 0.36.2
windows-curses version: 2.2.0
xmlrunner version: 1.7.7
---------------------------------------------------- Check ESP-IDF python requirements.txt -------------------------------------------------
Check ESP-IDF Python packages Python requirements from c:\esp\esp-idf\requirements.txt are satisfied.
---------------------------------------------------- Check extension requirements.txt ------------------------------------------------------
Check Extension Python packages Python requirements from c:\Users\david\.vscode\extensions\espressif.esp-idf-extension-1.1.0\requirements.txt are satisfied.
---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------
Check Debug AdapterPython packages Python requirements from c:\Users\david\.vscode\extensions\espressif.esp-idf-extension-1.1.0\esp_debug_adapter\requirements.txt are satisfied.
---------------------------------------------------- Visual Studio Code launch.json --------------------------------------------------------
"version": "0.2.0",
"configurations": [
"type": "espidf",
"name": "Launch",
"request": "launch"
---------------------------------------------------- Visual Studio Code c_cpp_properties.json ----------------------------------------------
"configurations": [
"name": "ESP-IDF",
"compilerPath": "C:\\Users\\david\\.espressif\\tools\\xtensa-esp32-elf\\esp-2020r3-8.4.0\\xtensa-esp32-elf\\bin\\xtensa-esp32-elf-gcc.exe",
"cStandard": "c11",
"cppStandard": "c++17",
"includePath": [
"${config:idf.espIdfPath}/components/**",
"${config:idf.espIdfPathWin}/components/**",
"${config:idf.espAdfPath}/components/**",
"${config:idf.espAdfPathWin}/components/**",
"${workspaceFolder}/**"
"browse": {
"path": [
"${config:idf.espIdfPath}/components",
"${config:idf.espIdfPathWin}/components",
"${workspaceFolder}"
"limitSymbolsToIncludedHeaders": false
"version": 4
ESP-IDF version 4.2
gcovr version: 4.2
idna version: 2.10
lxml version: 4.6.3
pip version: 20.2.3
six version: 1.15.0
"version": "0.2.0",
"configurations": [
"type": "espidf",
"name": "Launch",
"request": "launch"
"configurations": [
"name": "ESP-IDF",
"cStandard": "c11",
"includePath": [
"browse": {
"path": [
"version": 4
Based on your doctor command seems that your extension should be configured already.
