I am running VSC 1.56.2 and ESP-IDF extension v1.0.3 on my Linux mint machine. I hadn`t done anything with ESP for a while but now when I am trying to run the graphical SDK Configuration editor it just stucks on "ESP-IDF: Menuconfig: Loading initial values..." and never opens it. Am I the only one with such a problem?
VSC does not open SDK Configuration editor
Re: VSC does not open SDK Configuration editor
Did you configure the extension before running the GUI SDK Configuration editor ?
Install tutorial
If your extension is already configured, there might be an error somewhere. Run the `ESP-IDF: Doctor Command` and paste the result here or take a look at the output (Menu View -> Output) in ESP-IDF and SDK Configuration Editor
Install tutorial
Users browsing this forum: No registered users and 48 guests
