ESP-IDF can't find Arduino components
lg.lindstrom
Postby lg.lindstrom » Fri Sep 17, 2021 4:29 pm
Hi
I have installed ESP-IDF addon on VsCode.
Then I select ESP-IDF create new project.
VsCode show a form asking for project name, location etc.
After filling the form I click on "chose template"
I select Extensions and select "arduino-as-component"
When the project is created I follow this instruction: https://docs.espressif.com/projects/ard ... onent.html
As I have said in another thread,, idf.py menuconfig don't work form me.
After setup is finished I compile my newly created project.
It compiles with a minor error that is easy to fix.
I slightly modifies the code so it looks like this.
#include "Arduino.h"
#include "WiFi.h"
static WiFi wifi  ;
extern "C" void app_main()
    initArduino();
    pinMode(4, OUTPUT);
    digitalWrite(4, HIGH);
    // Do your own thing
Then I compile again and get the following error
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/main.cpp.obj
 ../main/main.cpp
../main/main.cpp:4:8: error: 'WiFi' does not name a type
 static WiFi wifi  ;
So,, which "step" am I missing ??? (As far I know, WiFi should be a valid component)
chegewara
Re: ESP-IDF can't find Arduino components
Postby chegewara » Sun Sep 19, 2021 5:58 am
Who told you idf.py menuconfig wont work? Maybe it is misunderstanding and it was about plain arduino project?
The idf.py menuconfig has some Arduino options.
On Autostart Arduino setup and loop on boot.
If you enable these options, your main.cpp should be formated like any other sketch.
https://docs.espressif.com/projects/ard ... stallation
I am not using VS code extension, i prefer full manual configuration, but instruction seems to be easy and complete to start with arduino as component.
EDIT from your other topic i can see that you can run menuconfig in arduino as component project
Users browsing this forum: No registered users and 24 guests
