Espressif-IDE Installer for Windows OS (All-in-one Package)
ESP_kondalkolipaka
Postby ESP_kondalkolipaka » Tue Feb 15, 2022 10:02 am
Hello All,
Happy to announce Espressif-IDE Installer for Windows OS. Espressif-IDE Installer (All-in-one) is an offline installer and it comes with all the required components to work with the ESP-IDF Application development.
The installer deploys the following components:
  • Embedded Python
  • Cross-compilers
  • OpenOCD
  • CMake and Ninja build tools
  • ESP-IDF
  • Espressif-IDE based on Eclipse CDT
  • Amazon Corretto OpenJDK
As Installer bundles all the required components and tools including stable esp-idf so people behind corporate firewalls can use the whole solution out-of-box. This also configures all the required build environment variables and tool paths as you launch the IDE. All you could do is get started with your project directly without manually configuring a lot of stuff. This will give you a big boost to your productivity!
You could find Espressif-IDE Installer for Windows OS downloads here
Please find the tools installation instructions here. This document also applies to the Espressif-IDE Installer.
Espressif-IDE Download Section
https://github.com/espressif/idf-eclips ... #downloads
Thank you!
Users browsing this forum: No registered users and 7 guests
