returning to ESP32-land; encountering build errors
mzimmers
Postby mzimmers » Wed May 11, 2022 3:30 pm
Hi all -
After a several month hiatus, I'm back on an ESP32-based project. We're using VS Code, which I installed along with the ESP extension. I set up the IDF using the "EXPRESS" option, and it appeared to work correctly. But when I try to build, I almost immediately get the "Something went wrong..." message. I can't remember what causes this, or where to find details on what went wrong. Can someone please refresh my memory?
Thanks...
mzimmers
Re: returning to ESP32-land; encountering build errors
Postby mzimmers » Fri May 13, 2022 2:42 pm
BTT: anyone?
Thanks...
EDIT:
This is my current build error:
[0/1] Re-running CMake...
FAILED: build.ninja
C:\.espressif\tools\xtensa-esp32-elf\esp-2021r2-patch3-8.4.0\xtensa-esp32-elf\bin\tools\cmake\3.20.3\bin\cmake.exe --regenerate-during-build -SC:\Users\Michael.Zimmers\GitHub\iQPump-ESP32\fw -BC:\Users\Michael.Zimmers\GitHub\iQPump-ESP32\fw\build
CreateProcess failed: The system cannot find the file specified.
ninja: error: rebuilding 'build.ninja': subcommand failed
The terminal process "C:\windows\System32\WindowsPowerShell\v1.0\powershell.exe -Command ninja " terminated with exit code: 1.
Users browsing this forum: No registered users and 43 guests
