ESP-IDF Eclipse Plugin v2.10.0 Released!
ESP_kondalkolipaka
Postby ESP_kondalkolipaka » Fri Jun 09, 2023 5:27 pm
Improvements/New Features
Added esp32c6 support
Added default user workspace on launch of IDE
Configured Java 17 as a prerequisite to launch IDE
Added support for Eclipse 2023-03
In the Debugger Configuration, the hardware-watchpoint-limit will be based on the selection of the target
Added Serial Port selection improvements
Created /latest links to the espressf-ide downloads for each release version
Bug Fixes
IEP-934: idf.py confserver always runs in default build folder
IEP-858: Incorrect target change notification after eclipse restart
IEP-927: JTAG and Debugging for Custom Build Folder doesn't work
IEP-931: espressif-ide:couldn't open after changing the language config
Fix: Compatible fixes with Eclipse 2023-03 JGIT plugin
IEP-926: GH [#740](#740): An internal error occurred during: "Updating ESP-IDF master..."
CI: Build with the latest available Eclipse
IEP-937: Update GH runners to Java 17 and move from adopt to temurin
IEP-956: JGIT EGIT failing to load due to missing slf4j with latest release
IEP-950 Variables... button doesn't work for Arguments group
IEP-951: MESSAGE Error:... "configuration" is null when restart eclipse
IEP-837: Adding the IDF env vars to the launch configs
IEP-966: openocd server always has default timeout 25 seconds
IEP-965: Bug fix for serial port exception
IEP-952: Espressif IDE popup for old tool versions popping up after installing tools via IDE
How to get the latest version?
Installing IDF Plugins using the Update site URL:
https://dl.espressif.com/dl/idf-eclipse ... es/latest/
Installing IDF Plugins using the local archive file:
https://dl.espressif.com/dl/idf-eclipse ... 2.10.0.zip
Espressif IDE
https://dl.espressif.com/dl/idf-eclipse ... 2.10.0.dmg
https://dl.espressif.com/dl/idf-eclipse ... x86_64.zip
https://dl.espressif.com/dl/idf-eclipse ... _64.tar.gz
Users browsing this forum: No registered users and 37 guests
