Hi Espressif team.
my name is Alfredo, I am just trying to start to work with ESP32 board.
I have donwloaded the esp-idf-tools-setup-online-2.23.exe from Esspressif site and it was installed.
Picture Nª 1
Everything look fine until when a new project is created (Create a new EspressIf IDF pfroject), IDE reports an issue, Please, see the next picture : Picture Nª2
so, I pressed YES, set manually and the next Popup box is display: Picture Nª3
after setup the first dialoge box, putting Path where EspressIf is installed, the follwing error is repoted: Picture 4 and 5.
Can you help to fix this issue, please, I have tryed using Eclipse and EspressIf Toolchain, when a new project is created, same issue happened.
Br
Alfredo
esp-idf Version: 2.9.1, configuration issues when a project is created it
Re: esp-idf Version: 2.9.1, configuration issues when a project is created it
Hi Alfredo,
Looks like you've selected the wrong esp-idf directly, could you please cross check?
Make sure selected esp-idf directory has tools folder in it.
If you are a windows user I would recommend using espressif-ide installer instead of esp-idf-tools-setup-online.
You can find more details about Espressif-IDE Windows Offline Installer here
Users browsing this forum: No registered users and 86 guests
