ESP_LOGI and ESP_ERROR_CHECK issues in C++
greycon
Postby greycon » Sun Nov 26, 2023 3:06 pm
Hi, I've been chasking this for a while. It's not an issue that affects generated code, but rather produces lots of annoying "errors" in the IDE. I've narrowed it down to a trivial main.cpp program:
This program (Without the extern "C") does not show any IDE errors when written as main.c
#include "esp_log.h"
#include "esp_err.h"
#include "nvs_flash.h"
extern "C" {
void app_main(void) {
	ESP_LOGI("XXX", "YYY");
    ESP_ERROR_CHECK(nvs_flash_init());
The ESP_LOGI macro shows a simple "Syntax Error" in the IDE.
The ESP_ERROR_CHECK shows an "Invalid Argumements" error, or sometimes in a bigger program an error that "__ASSERT not found"
I don't mind re-codeing the logging macro to:
esp_log_write(ESP_LOG_INF", "Blah","Blah");
But I can't find a way around the ERROR check macro, and it's used a lot in sample code, and I would like to keep this. Anyone know a workaround?
ESP_kondalkolipaka
Re: ESP_LOGI and ESP_ERROR_CHECK issues in C++
Postby ESP_kondalkolipaka » Mon Nov 27, 2023 2:24 am
To verify further, could you please share more details on what IDE are you referring to - Eclipse or VSCode?
Please share an IDE version and a sample project to test this scenario.
ESP_kondalkolipaka
Postby ESP_kondalkolipaka » Mon Nov 27, 2023 4:58 am
I could reproduce this problem with Eclipse IDE.
I see this "syntax error" marker on ESP_LOGI() in Eclipse (with only .cpp files). I think this is something to do with "extern" syntax and how Indexer is building https://bugs.eclipse.org/bugs/show_bug.cgi?id=258292
Let me see if I can find something on this.
greycon
Postby greycon » Sat Dec 02, 2023 3:43 pm
Sorry, I should have been clear - I am usign the Eclipse IDF plugin. And if you do happen to find some workaround for the indexer issue, that would be great, thanks for your time.
Users browsing this forum: No registered users and 59 guests
