I am presently working on making my device (ESP32) to be controlled over google voice assistant. As mentioned on [b]https://rainmaker.espressif.com/docs ... html [/b] this 3rd party integration with esp-rainmaker documentation regarding GVA integration available only for switch and light_bulb example, I was trying to find how switch/light_bulb parameters are mapped with GVA and I am not able to get my answers by myself. I am working on making my fan device to be controlled over Google voice assistant so I am looking forward for guidance on this particular topic.
Thank you
Parameter mapping to enable GVA controlled device.
Re: Parameter mapping to enable GVA controlled device.
The documents have not been updated for some time, but Fan is already supported for both, Alexa and GVA. You can use the default fan example in esp-rainmaker for that.
We will update the documents soon with details of all the device and parameter types supported and their mappings with Alexa/GVA.
Hi Piyush,
Thank you for responding quickly, I used the same fan example from esp-rainmaker it's just that I have added few thing on that example as per my application requirement, so when I link Esp-rainmaker with google home there pops up a screen saying "No device found on esp-rainmaker" instead my device is already connected to rainmaker and working fine when controlled via rainmaker app and Alexa. Then I tried switch and light_bulb examples to find out the problem with google voice assistant but those examples worked with GVA, can you guide me that why fan program is not working with GVA, below I have attached the screenshots of GVA screen pop up. I am looking forward for help.
Thanking You
By_jinjuriki
Thanking You
By_jinjuriki
- Device setup on rainmaker
- IMG_20210924_120023.jpg (59.5 KiB) Viewed 16587 times
- Message screen of google home
- IMG_20210924_120009.jpg (244.99 KiB) Viewed 16587 times
I tried the default fan example and it's not supporting GVA. I have sent the error message in my last post, still I didn't get any help. Kindly guide me over that.
Thanking You
Thanking You
After checking internally , I found out that the fan support wasn't pushed out to production because the fan speed control from GVA was not as straightforward as a range controller for Alexa. We will check how this can be supported and add it asap.
Users browsing this forum: No registered users and 25 guests
