Issue with changing the sleep mode
ggeorge
Postby ggeorge » Tue May 17, 2022 1:03 pm
By default when querying with AT+SLEEP? it shows 2. I want to make it to 0. How should I do that?
ESP_Sun
Re: Issue with changing the sleep mode
Postby ESP_Sun » Fri May 20, 2022 3:52 am
Which version is this? Execute AT+SLEEP? Is the default value not 1?
ggeorge
Postby ggeorge » Fri May 20, 2022 6:28 am
Yes when querying after AT+RESTORE, it shows as 1. How do I make it to 0? I suspect my module is going to sleep, that is why it is disconnecting.
ESP_Sun
Postby ESP_Sun » Fri May 20, 2022 7:11 am
You can execute AT+SLEEP=0 command, but disabling sleep mode will increase power consumption.
ggeorge
Postby ggeorge » Fri May 20, 2022 7:40 am
How do I execute that? It doesn't take that command generally. Should I give any other configuration before giving that?
ESP_Sun
Postby ESP_Sun » Fri May 20, 2022 8:15 am
No other configuration is required.
ggeorge
Postby ggeorge » Fri May 20, 2022 9:11 am
Okay thanks. It worked.
Users browsing this forum: No registered users and 26 guests
