Using BluFi
banjoluck
Using BluFi
Postby banjoluck » Thu Aug 11, 2022 9:27 pm
Greetings,
We have seen that there are commands in the ESP AT command set to activate BluFi. We enabled this feature and could see that the ESP32 was advertising the correct service. We were not able to get the Android APP to connect to the module.
Do you have instructions for testing this feature? How do we connect to the ESP32 from the APP? The APP asked for a QR code, but we do not know how to generate this code.
Cheers
ESP_Sun
Re: Using BluFi
Postby ESP_Sun » Mon Aug 15, 2022 4:13 am
You can use ESPBLUFI APP to test the BLUFI function of AT, APP download link: https://www.espressif.com/zh-hans/support/download/apps, if you want to use other APP to test this function, you may need your APP adapts it.
banjoluck
Re: Using BluFi
Postby banjoluck » Tue Aug 16, 2022 10:17 pm
We are seeing an error when we attempt to configure:
We cannot configure a 2.4GHz network with a phone that is connected to a 5GHz network.
Users browsing this forum: No registered users and 22 guests
