Technical Reference I2S Clock config section is confusing
WiFive
Re: Technical Reference I2S Clock config section is confusing
Postby WiFive » Sat Jul 22, 2017 7:44 pm
Yes, but none of those start with FUNC, the register layout is different, and you are passing a shift where a value is expected.
RoyceP
Postby RoyceP » Sat Jul 29, 2017 4:00 pm
It would appear that you were correct.
PIN_FUNC_SELECT(PIN_CTRL, CLK_OUT1_S);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
netted me a 40Mhz clock on GPIO0. The DAC was not working with that clock. The documentation for the DAC indicated that the clock for 256x 44.1kHz ought to be 11.2896Mhz.
I replaced the above with:
REG_WRITE(PIN_CTRL, 0b111111110000);
and got the desired frequency. The DAC began outputting analog data, seemingly happy with the corrected master clock speed.
I agree that the documentation should be updated to reflect the full bit string required in each configuration.
Users browsing this forum: No registered users and 75 guests
