Hi folks,
The ESP32-PICO-V3-ZERO is a module that is based on ESP32-PICO-V3, a System-in-Package (SiP) device. It
provides complete Wi-Fi and Bluetooth® functionalities. The module integrates a 4 MB SPI flash.
At the core of this module is the ESP32 chip, which is a single 2.4 GHz Wi-Fi and Bluetooth combo chip designed
with TSMC’s 40 nm low-power technology. ESP32-PICO-V3-ZERO integrates all peripheral components seam-
lessly, including a crystal oscillator, flash, filter capacitors and RF matching links in one single package. Module
assembly and testing are already done at SiP level. As such, ESP32-PICO-V3-ZERO reduces the complexity of
supply chain and improves control efficiency.
With its ultra-small size, robust performance and low-energy consumption, ESP32-PICO-V3-ZERO is well suited
for any space-limited or battery-operated applications, such as wearable electronics, medical equipment, sensors
and other IoT products.
ESP32-PICO-V3-ZERO Datasheet
V1.0 2020.11.03
This document introduces the specifications of ESP32-PICO-V3-ZERO hardware, including an overview, pin definitions, functional description, peripherals, electrical characteristics, etc.
ESP32-PICO-V3-ZERO 是一款基于系统级封装 (SiP) ESP32-PICO-V3 的模组,可提供完整的 Wi-Fi 和蓝牙 ® 功
能。该模组集成 1 个 4 MB 串行外围设备接口 (SPI) flash。
ESP32-PICO-V3-ZERO 的核心是 ESP32 芯片 *。ESP32 是集成 2.4 GHz Wi-Fi 和蓝牙双模的单芯片方案,采用
台积电 (TSMC) 超低功耗的 40 纳米工艺。ESP32-PICO-V3-ZERO 模组已将晶振、flash、滤波电容、RF 匹配链
路等所有外围器件无缝集成进封装内,不再需要外围元器件即可工作。此时,模组的组装和测试都在 SiP 层面
完成,因此 ESP32-PICO-V3-ZERO 可以大大降低供应链的复杂程度并提升管控效率。
ESP32-PICO-V3-ZERO 具备体积紧凑、性能强劲及功耗低等特点,适用于任何空间有限或电池供电的设备,比
如可穿戴设备、医疗设备、传感器及其他 IoT 设备。
ESP32-PICO-V3-ZERO 技术规格书
V1.0 2020年11月10日
本文档为用户提供 ESP32-PICO-V3-ZERO 硬件技术规格,包括管脚定义、功能描述、外设接口、电气特性等。
also for History here attached EN and CN Version (ACK)
Document Updates
Please always refer to the latest version on https://www.espressif.com/en/support/download/documents.
Documentation Change Notification
Espressif provides email notifications to keep customers updated on changes to technical documentation.
Please subscribe at www.espressif.com/en/subscribe
文档版本
请至乐鑫官网 https://www.espressif.com/zh-hans/suppo ... -documents 下载最新版本文档。
文档变更通知
用户可以通过乐鑫官网订阅页面 www.espressif.com/zh-hans/subscribe 订阅技术文档变更的电子邮件通
知。
rudi
edit: add document update info, add pdf files and dimensions
ESP32-PICO-V3-ZERO Datasheet | 技术规格书
- dimensions.jpg (38.5 KiB) Viewed 9785 times
Re: ESP32-PICO-V3-ZERO Datasheet | 技术规格书
The link has been updated with a different datasheet. It shares the same version - 1.0 - but is more recent, dated November 3rd.
It is now "ESP32-PICO-V3-ZERO (ACK)", but this is a very different module with just 3 GPIO led out.
Are these the same product? Different? What's the status of ESP32-PICO-V3-ZERO?
There are few further new Products, not all Documents are here in BBS linked.
Feel free to check the Ordering Information EN / 乐鑫产品订购信息
- ESP32-PICO-V3-ZERO ( ACK )
- ESP32-PICO-V3-ZERO-Devkit ( ACK )
Datasheets can be outdated here in the BBS sometimes if there news on the Company Webside.
Please have a note to:
Document Updates
文档版本
文档变更通知
用户可以通过乐鑫官网订阅页面 www.espressif.com/zh-hans/subscribe 订阅技术文档变更的电子邮件通知。
[edit] FYI, a Mini Serie example ESP32-S2-Mini also ESP32-Mini ( Sample Status - no Datasheet just in time online ) is ready.
I will update this post with links - i think have not mentioned ESP32-Mini in the Documentation Section at BBS cause no public PDF is available - will check on on ESP Product Selector..
thank you for your interest
Users browsing this forum: No registered users and 29 guests
