[Documentation Release] ESP32 Technical Reference
Re: [Documentation Release] ESP32 Technical Reference
Postby rudi ;-) » Wed Feb 21, 2018 10:31 pm
The ESP32 Technical Reference Manual is now V2.9.
- Updated sections 4.2.2, 4.2.3, 4.3.2;
- Added registers I2S_FIFO_WR_REG and I2S_FIFO_RD_REG in Section I2S Registers.
PDF link to the latest (same as the link in the first post)
Also, please subscribe to our documentation updates at: http://espressif.com/en/subscribe
这里是新手的福音之地,有楼主的支持,我越加自信走出自己了!
ESP32 技术参考手册
版本 2.9
更新章节 4.2.2、4.2.3、4.3.2;
在章节 I2S 寄存器 中增加 I2S_FIFO_WR_REG 和 I2S_FIFO_RD_REG 寄
存器。
来源
用户可以通过乐鑫官网订阅技术文档变更的电子邮件通知。
值此新春佳节来临之际,rudi 给 friends 拜年拉!
感谢过去一年来的支持,祝您及您家人在新的一年里大展宏图!
狗年事业兴旺!旺!旺!行大运!发大财!幸福安康!阖家欢乐!万事如意!
新年快乐 !
Vader_Mester
Contact:
Postby Vader_Mester » Tue Aug 14, 2018 7:10 am
rudi ;-) wrote:The ESP32 Technical Reference Manual is now V2.9.
Simple question: Why did you remove the temp sensor and LNA sections from the TRM? It's still mentioned in the ESP32 datasheet.
Is there a reason for the removal? I haven't seen any other description of this periferial anywhere else, only in older version of TRM.
There are 2 types of programmer people: The Expert programmer and The Smart programmer
The Expert programmer easily writes any code from scratch.
The Smart programmer uses his google/github powers first ;)
ESP_Lvxinyue
Postby ESP_Lvxinyue » Tue Aug 14, 2018 8:51 am
Hi all, the TRM is now V3.6. The link remains the same: https://www.espressif.com/sites/default ... ual_en.pdf
mikemoy
Postby mikemoy » Fri Sep 14, 2018 5:33 pm
666 pages. This is a perfect example for the saying "The devils in the details" :roll:
Postby rudi ;-) » Sat Nov 03, 2018 1:48 am
ESP_Lvxinyue wrote:Hi all, the TRM is now V3.6. The link remains the same: https://www.espressif.com/sites/default ... ual_en.pdf
2018-OCT-12
TRM is now V3.9 and online
changes since V3.6
2018.10 V3.9
- Updated Figure 50: I2C Sequence Chart, in Chapter 11: I2C Controller.
2018.09 V3.8
- Updated the description of register TIMGn_Tx_ALARM_EN;
- Added description of ULP wakeup time in section 29.5: ULP Program Execution.
2018.08 V3.7
- Updated the description of register UART_RX_GAP_TOUT.
ESP_Lvxinyue
Postby ESP_Lvxinyue » Fri Dec 07, 2018 6:34 am
Hi all, the TRM is now V4.0. Major changes span four chapters. The link remains the same: https://www.espressif.com/sites/default ... ual_en.pdf
Remember to subscribe to our email notification at: https://www.espressif.com/en/subscribe
gautier.s
Postby gautier.s » Tue Jan 29, 2019 5:12 pm
Any chance to get the description of following RMT register. That is following member of structure rmt_dev_t in rmt_struct.h?
  1.     uint32_t status_ch[8];                              /*The status for channel0-7*/
That would help to understand the error messages from RMT driver:
  1. E (20119) rmt: RMT[0] ERR
  2. E (20119) rmt: status: 0x14000040
thanks in advance,
gautier
ESP_Angus
Postby ESP_Angus » Wed Jan 30, 2019 12:24 am
Hi gautier,
Yes, this should be included. rmt_reg.h recently added a description for these bits, but it seems like it wasn't propagated to the rmt_struct.h headers or the TRM. It should be added to both, will chase this up.
In the meantime, you can find the bit descriptions here:
https://github.com/espressif/esp-idf/bl ... reg.h#L991
