[SDK Release] ESP31B RTOS SDK_V2.0.0_16_02_28
ESP_Luna
Postby ESP_Luna » Sun Feb 28, 2016 1:45 am
EDIT: Moderators note: despite the name, this SDK release is for ESP31B. Use esp-idf for ESP32 development.
ESP32_RTOS_SDK_V2.0.0_16_02_28 Release
Important Links
Here are the links for this SDK release (Version ESP32_RTOS_SDK_V2.0.0_16_02_28):
  1. Download ESP32_RTOS_SDK
  2. Download ESP32 Related Documentation
  3. Bug Bounty Program
Release Notes
  1. update boot.bin to v1.1.1;
  2. bin name changed (irom1.bin -> drom0.bin);
  3. add new map mode;
  4. add WPS support;
  5. add WPA2-Enterprise support;
  6. add AMPDU support;
  7. add esptool.py;
  8. update gen_appbin.py;
  9. include folder structure change;
  10. support some makefile options;
  11. add esp.conf in project_template;
  12. add LWIP source code;
  13. add CJson source code;
  14. update README.md;
  15. SSL bug fix;
  16. upgrade bug fix;
  17. many other optimizations…
Have fun!
_______________________________________________________
ESP32_RTOS_SDK_V2.0.0_16_02_28 发布
相关下载
以下是最新 SDK 的相关下载链接 (版本 ESP32_RTOS_SDK_V2.0.0_16_02_28):
  1. 下载 ESP32_RTOS_SDK
  2. 下载 ESP32 相关文档
  3. 您可以继续参与 Bug 赏金计划
发布说明
  1. 更新 boot.bin 到 V1.1.1 版本;
  2. bin 文件名更改 (irom1.bin -> drom0.bin);
  3. 增加新的映射模型;
  4. 支持 WPS 模式;
  5. 支持 WPA2-Enterprise 加密模式;
  6. 支持 AMPDU 模式;
  7. 增加 esptool.py;
  8. 更新 gen_appbin.py;
  9. 增加文件夹结构的更改;
  10. 支持 makefile 选项;
  11. 增加 esp.conf 到 project_template;
  12. 增加 LWIP 源代码;
  13. 增加 CJson 源代码;
  14. 更新 README.md 文档;
  15. 修复 SSL bug;
  16. 升级 bug 修复;
  17. 其他优化更新……
感谢您对 ESP32 的关注!
Postby rudi ;-) » Sat Jul 02, 2016 2:49 pm
ESP Flash Tool 1.2.0 now released
a newer release of ESP32 ESP Flash Tool ( 2016-06-15 ) is online on new Resource Web Side at espressif web.
ESP32 Flash Download Tool V1.2.0
1. fix result check function for ESP32
2. fix download error if address exceed 2Mbyes
more info here
[SDK Brunch ] ESP32_RTOS_SDK_V3.0.0_16_07_23
Postby rudi ;-) » Sat Jul 23, 2016 8:53 am
hi guys
just in time founded. there are updates in past ( 1 hour old )
follow and check it out directly from here
read carefull, there are update in the documents too
what is just in time new:
- update lwip to v1.5.0;
- update smartconfig to v2.5.4;
- system parameter struct changed, need to flash blank.bin to system parameter sector;
- support set phy mode for softap/station seperately;
- support Rx/Tx AMPDU;
- support 802.11 regdomain;
- support 802.11 QoS;
- optimize throughput;
- modify sdk internal framework;
- modify esp_*.h headers dependencies;
- add libphyrom.a and liblwip_dep.a;
- update documents;
- update gen_appbin.py;
- bug fix;
FYI:
can't create here a new thread in SDK partion ( only admin's )
so i create a new in the general talk for the meantime if we get official
and linked here.
3guoyangyang7
Re: [SDK Release] ESP32_RTOS_SDK_V2.0.0_16_02_28
Postby 3guoyangyang7 » Sat Oct 22, 2016 8:12 am
在使用sdk的时候,能编译通过,也得到了
boot.bin------------------>0x00000
drom0.bin----------------->0x04000
irom0_flash.bin----------->0x40000
user.ota------------------>(used for OTA)
当我用下载工具把其下载到板子上的时候,也下载完成了,但是
运行的时候出现
flash read err, 1000
Falling back to built-in command interpreter.
OK
当我执行 make flash_all的时候会出现
/cygdrive/f/ESP32/ESP31_RTOS_SDK/tools/esptool.py -c ESP32 -p /dev/ttyS13 -b 115200 write_flash -fs 4MB -fm dio -ff 40m \
0x0 /cygdrive/f/ESP32/ESP31_RTOS_SDK/bin/boot.bin \
0x04000 /cygdrive/f/ESP32/ESP31_RTOS_SDK/bin/drom0.bin 0x40000 /cygdrive/f/ESP32/ESP31_RTOS_SDK/bin/irom0_flash.bin \
0x3FE000 /cygdrive/f/ESP32/ESP31_RTOS_SDK/bin/blank.bin
Connecting...
Erasing flash...
SET FLASH PARAMS
A fatal error occurred: Failed to config flash (result "0x0, 0x0, 0x0, 0x0")
make: *** [/cygdrive/f/ESP32/ESP31_RTOS_SDK/Makefile:294: flash_all] Error 2
求解答,是不是sdk现在不能用呢
ESP_igrr
Postby ESP_igrr » Sat Oct 22, 2016 8:21 am
@3guoyangyang7 ESP31_RTOS_SDK 2.0 doesn't work with ESP32. Check https://github.com/espressif/esp-idf instead.
3guoyangyang7
Postby 3guoyangyang7 » Sat Oct 22, 2016 9:02 am
那 esp-idf 有没有API 函数说明手册呢
ESP_igrr
Postby ESP_igrr » Sun Oct 23, 2016 12:24 am
That is true, we don't have an API manual yet. However we try to document functions in header files. If there is any info you need, feel free to ask questions on the forum.
Edit:
There is a book about ESP8266/ESP32 programming by Neil Kolban: https://leanpub.com/ESP8266_ESP32, which can serve a good reference.
Postby rudi ;-) » Sun Oct 23, 2016 7:56 am
ESP_igrr wrote:That is true, we don't have an API manual yet. However we try to document functions in header files. If there is any info you need, feel free to ask questions on the forum.
@esp_igrr
found not the right info in headers just in time that can use this functional right.
can u please point, how we can check / use the temperature sensor on esp32?
the api from 31 is different too.
txs
Postby rudi ;-) » Sun Oct 23, 2016 8:01 am
3guoyangyang7 wrote:在使用sdk的时候,能编译通过,也得到了
运行的时候出现
OK
this sound is good!
try this now:
send: about
you see the Basic Rom from espressif ;-)
you now in Basic Rom of ESP32
commands:
send: help
have a look:
https://twitter.com/maker_asia/status/7 ... 3210492928
