ESP-32 unstable booting
taronghlijyan
Postby taronghlijyan » Thu Jul 07, 2022 9:04 pm
I have a problem with my custom ESP32 PCB. It's a keyboard PCB and I'm trying to set it up (schematics is attached). It has 5 main parts - li-ion charging circuit, 3.7V to 5V circuit (for LEDs), 3.3V stabilizer with ESP32 (+LEDs and switch matrix)
The problem is that whenever I turn on the board (by connecting type-c cable) ESP32 does not start (I used blink sketch to verify). But as soon as I use both on-board type-c and USB-TTL adapter it starts. After it does so, it works fine even if I am disconnecting the USB-TTL device. ESP runs until I reset it through EN pin, after which it stops booting again.
I suppose that my power circuitry is not very good and creates initial voltage spikes, thus causing such a behavior, however I might be wrong.
Can anybody help to figure out what's the issue?
Regards,
Taron
Schematic_shortcut-master_2022-07-06.pdf
(530.8 KiB) Downloaded 275 times
Re: ESP-32 unstable booting
Postby Sprite » Fri Jul 08, 2022 12:51 am
You need an RC network on your EN pin; you only have a R there. Add an 1uF capacitor from EN to ground and it should work a lot more stable. Additionally, your IO0 is connected to a fair bit of wiring; could be that that pulls it low on startup, making the chip go into download mode. Add a resistor (4.7K or so will do) from IO0 to 3.3V to fix that.
taronghlijyan
Postby taronghlijyan » Fri Jul 08, 2022 7:25 am
Thanks for the fast reply. Unfortunately it didn't help. However, I noticed another interesting thing. Whenever it "doesn't" start my program, it starts outputting this message through COM port:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13516
load:0x40080400,len:3604
csum err:0x67!=0xc2
ets_main.c 371
ets Jun 8 2016 00:22:57
I read that this is about DIO flash mode trough SPI, but why is it doing this?
Every time I connect it to USB-TTL before connecting on-board power, it runs my program instead. (my program logs at 57600, while the message is outputted with 115200).
Does this give any additional clue?
Regards,
Taron
P.S. - I'm using Arduino IDE
taronghlijyan
Postby taronghlijyan » Fri Jul 08, 2022 7:51 am
Thanks for fast reply. Unfortunately it didn't work. However, I found another clue. Every time it doesn't start my program, it starts outputting this kind of message to COM port:
load:0x00004000,len:17039360
I know that it is about DIO SPI flash mode, but how do I get it to start my program automatically.
This happens when I connect to USB-TTL after I connect on-board power. If I am connecting the USB-TTL adapter first and only then powering the board it works fine until the next reset (even if I take out USB-TTL out)
I know that my code isn't starting because it logs at 57600, while this message appears at 115200.
Is there anything else that I'm missing?
Regards,
Taron
P.S. - I am using Arduino IDE with ESP32 core and this USB-TTL (see picture attached)
Users browsing this forum: Baidu [Spider], trendictionbot and 2 guests
