adding an external flash for data storage
finha29
Postby finha29 » Mon Jul 11, 2022 3:57 pm
Hi, I'd like to know if its possible to use the flash API to connect an external flash(not shared with main flash) in dual mode and not use WP and HOLD, I have left only 4 pins and I don't wanna use an SD card beacuse of the vibration environment.
thanks
ESP_igrr
Re: adding an external flash for data storage
Postby ESP_igrr » Thu Jul 14, 2022 7:27 am
This should be possible, you can connect unused pins (WP and HD) according to the datasheet of the flash chip.
To see how to set this up in ESP-IDF, please check this example: https://github.com/espressif/esp-idf/tr ... lash_fatfs
Users browsing this forum: Bing [Bot] and 4 guests
