I purchased a ESP32-DEVKITC-VE board from DigiKey. I'm having trouble getting it to work when I have it wired up on the breadboard. It works fine if all pins are disconnected and powered by the USB.
I was trying to verify the pin layout of the board but cannot find documentation. On the board itself it is marked with: ESP32-WROVER-E.
The silkscreen on the board matches the pin layout here: https://docs.espressif.com/projects/esp ... vkitc.html
Is the pin layouts detailed for the J1, J2, and Pin Layout sections in the above URL the same for the ESP32-DEVKITC-VE board?
Thank you,
-Adam
ESP32-DEVKITC-VE Pin Layout
Re: ESP32-DEVKITC-VE Pin Layout
Hi Adam,I was trying to verify the pin layout of the board but cannot find documentation. On the board itself it is marked with: ESP32-WROVER-E.
Yes.
Then I assume that Figure 3 and Table 3 in section 3 here https://www.espressif.com/sites/default ... eet_en.pdf is incorrect?
Thank you,
-Adam
Thank you,
-Adam
Nothing wrong with that table/figure. That is the pinout for the module itself which is not the same as the pinout of the devboard.
