Obtaining the https response using esp_http_client_perform
antusystem
Postby antusystem » Sat Jan 09, 2021 8:13 pm
Hi, I'm using the ESP-IDF v.4.2. I'm using the esp_http_client example to make an HTTPS request. Guiding me from the https_with_url function I could establish a connecting with the web, but I want to know the actual content from the response. I cannot see how to do this with the function esp_http_client_perform.
Afterwards, I tried using the base of the http_native_request function, making the changes so I could connect through HTTPS. I manage to do it and also could read the content response from the server to the HTTPS request using esp_http_client_read_response.
So, because esp_http_client_perform is easier to use than all the way with the native path, I'm trying to extract this information but I could not do it. I also try adding a queue in the handler to send this data, but it didn't work, the data arrive incomplete or not even readable.
Hopefully, some of you might know this. Thanks
Note: here you can see the esp_http_client example: https://github.com/espressif/esp-idf/bl ... _example.c
Edit: reading better the esp_http_client and found that they declare a variable for the buffer and if in the config for the handler of the http you pass this variable to .user_data you, after using esp_http_client_perform you can check the response from the server there.
    char buffer[MAX_HTTP_OUTPUT_BUFFER] = {0};
        .url = "https://postman.org",
        .transport_type = HTTP_TRANSPORT_OVER_SSL,
        .event_handler = _http_event_handler,
        .user_data = buffer,        // Pass address of local buffer to get response
The thing I want to know now is how to print the https request send to the server, for both GET and POST cases.
eliasorggro
Re: Obtaining the https response using esp_http_client_perform
Postby eliasorggro » Sun Jul 17, 2022 7:12 pm
I have the same issue :(
any progress ?
pablomartinez
Postby pablomartinez » Thu Jul 28, 2022 2:48 pm
You need to capture HTTP_EVENT_ON_DATA event and copy the received data chunks to your user_data buffer.
I defined the event handler:
esp_err_t client_event_get_handler(esp_http_client_event_handle_t evt)
    static char *output_buffer;  // Buffer to store response of http request from event handler
    static int output_len;       // Stores number of bytes read
    switch (evt->event_id)
    case HTTP_EVENT_ON_DATA:
        ESP_LOGD(TAG, "HTTP_EVENT_ON_DATA, len=%d", evt->data_len);
         *  Check for chunked encoding is added as the URL for chunked encoding used in this example returns binary data.
         *  However, event handler can also be used in case chunked encoding is used.
        if (!esp_http_client_is_chunked_response(evt->client)) {
            // If user_data buffer is configured, copy the response into the buffer
            if (evt->user_data) {
                memcpy(evt->user_data + output_len, evt->data, evt->data_len);
            } else {
                if (output_buffer == NULL) {
                    output_buffer = (char *) malloc(esp_http_client_get_content_length(evt->client));
                    output_len = 0;
                        ESP_LOGE(TAG, "Failed to allocate memory for output buffer");
                        return ESP_FAIL;
                memcpy(output_buffer + output_len, evt->data, evt->data_len);
            output_len += evt->data_len;
        break;
    case HTTP_EVENT_ON_FINISH:
        ESP_LOGD(TAG, "HTTP_EVENT_ON_FINISH");
        if (output_buffer != NULL) {
            // Response is accumulated in output_buffer. Uncomment the below line to print the accumulated response
            // ESP_LOG_BUFFER_HEX(TAG, output_buffer, output_len);
            free(output_buffer);
            output_buffer = NULL;
        output_len = 0;
        break;
    case HTTP_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "HTTP_EVENT_DISCONNECTED");
        int mbedtls_err = 0;
        esp_err_t err = esp_tls_get_and_clear_last_error(evt->data, &mbedtls_err, NULL);
        if (err != 0) {
            ESP_LOGI(TAG, "Last esp error code: 0x%x", err);
            ESP_LOGI(TAG, "Last mbedtls failure: 0x%x", mbedtls_err);
        output_len = 0;
        break;
    default:
        break;
    return ESP_OK;
And then add your user_data and event_handler to the esp_http_client_config:
   char responseBuffer[MAX_HTTP_OUTPUT_BUFFER];
        .url = url,
        .crt_bundle_attach = esp_crt_bundle_attach,
        .user_data = responseBuffer,
        .event_handler = client_event_get_handler,
After performing esp_http_client_perform(client) successfully, responseBuffer will contain the response.
This worked for me!
Users browsing this forum: Baidu [Spider], Google [Bot], YisouSpider and 1 guest
