BLE Gatts Write Event
Gitprodenv
Postby Gitprodenv » Fri Aug 05, 2022 12:42 pm
Hi guys,
I just went through the "Gatt_Server_Example_Walkthrough.md file" provided in the ESP IDF's example folder.
My question is based around this code snippet:
case ESP_GATTS_WRITE_EVT: {
     ESP_LOGI(GATTS_TAG, "GATT_WRITE_EVT, conn_id %d, trans_id %d, handle %d\n", param->write.conn_id, param->write.trans_id, param->write.handle);
     if (!param->write.is_prep){
        ESP_LOGI(GATTS_TAG, "GATT_WRITE_EVT, value len %d, value :", param->write.len);
        esp_log_buffer_hex(GATTS_TAG, param->write.value, param->write.len);
        if (gl_profile_tab[PROFILE_B_APP_ID].descr_handle == param->write.handle && param->write.len == 2){
            uint16_t descr_value= param->write.value[1]<<8 | param->write.value[0];
            if (descr_value == 0x0001){
                if (b_property & ESP_GATT_CHAR_PROP_BIT_NOTIFY){
                    ESP_LOGI(GATTS_TAG, "notify enable");
                    uint8_t notify_data[15];
                    for (int i = 0; i < sizeof(notify_data); ++i)
                         notify_data[i] = i%0xff;
                     //the size of notify_data[] need less than MTU size
                     esp_ble_gatts_send_indicate(gatts_if, param->write.conn_id,
                                                 gl_profile_tab[PROFILE_B_APP_ID].char_handle,
                                                 sizeof(notify_data),
                                                 notify_data, false);
            }else if (descr_value == 0x0002){
                 if (b_property & ESP_GATT_CHAR_PROP_BIT_INDICATE){
                     ESP_LOGI(GATTS_TAG, "indicate enable");
                     uint8_t indicate_data[15];
                     for (int i = 0; i < sizeof(indicate_data); ++i)
                         indicate_data[i] = i % 0xff;
                      //the size of indicate_data[] need less than MTU size
                                                 sizeof(indicate_data),
                                                 indicate_data, true);
             else if (descr_value == 0x0000){
                 ESP_LOGI(GATTS_TAG, "notify/indicate disable ");
             }else{
                 ESP_LOGE(GATTS_TAG, "unknown value");
    example_write_event_env(gatts_if, &a_prepare_write_env, param);
    break;
what does
mean? Which values can param->write.value[0] and param->write.value[1] by left shifting and or'ing take such that you will get 0x0001, 0x0002 and 0x0000.
I know that param->write.value is a pointer to uint8_t, but I'm unaware how to receive those 0x0001, 0x0002 or 0x0000 values. Why do we cast to uint16_t (uint16_t descr_value)?
Thanks a lot for clarification
Users browsing this forum: Bing [Bot], Google [Bot], PetalBot, trendictionbot and 6 guests
