Please, I need help to make debug work on ESP32S3.
Trying with "Hello World" sample
First I tried debug using Esp-IDF version 4.4.2... many Jtag errors. It was impossible to flash code. Read and tried almost every suggestion I found on Google.
Then decided to try new version, I´ve installed version release branch 5.0, improved a lot, now I can flash code using Builtin JTAG.
The problem is that when the I start Debugging (play button/F5) , the debugger doesn't stop at the app_main() statement, but debug controls are on top page (see image).
When start debugging (Play button / F5) I receive message on DEBUG_CONSOLE as you can see in "terminal_debug_console.txt" file attached.
If I press "pause", I receive message on DEBUG_CONSOLE as you can see in "terminal_debug_console_press_pause.txt" file attached.
If I press "step over", I receive message this message
1: (259542) <-1025-exec-next
1: (259544) ->1025^error,msg="Cannot find bounds of current function"
1: (259544) ->(gdb)
1: (259544) 1025: elapsed time 2
1: (259544) ->&"\n"
1: (259544) ->^done
1: (259544) ->(gdb)
1: (259548) Send Event AD7MessageEvent
ERROR: Unexpected GDB output from command "-exec-next". Cannot find bounds of current function
terminal_debug_console_press_stepover.txt" file attached.
This is my LAUNCH.JSON
"configurations": [
// "preLaunchTask": "PreRun",
"name": "ESP32 Debug",
"type": "cppdbg",
"request": "launch",
"cwd": "${workspaceFolder}/build",
"program": "${workspaceFolder}/build/${command:espIdf.getProjectName}.elf",
"miDebuggerPath": "C:\\Espressif\\tools\\xtensa-esp32s3-elf\\esp-2022r1-RC1-11.2.0\\xtensa-esp32s3-elf\\bin\\xtensa-esp32s3-elf-gdb.exe",
"setupCommands": [
{"text": "target remote 127.0.0.1:3333" },
{"text": "set remote hardware-watchpoint-limit 2"},
{"text": "monitor reset halt"},
{"text": "flushregs"}
// este código abaixo automatiza a gravação de todos os arquivos na flash
//{"text": "mon program_esp build/bootloader/bootloader.bin 0x1000 verify"},
//{"text": "mon program_esp build/partition_table/partition-table.bin 0x8000 verify"},
//{"text": "mon program_esp build/iSmartX3_IDF.bin.bin 0x10000 verify"},
//{"text": "monitor reset halt"},
//{"text": "flushregs"},
"logging": {
"engineLogging": true,
This is my "SETTINGS.JSON"
"C_Cpp.intelliSenseEngine": "Tag Parser",
"idf.adapterTargetName": "esp32s3",
"idf.customExtraPaths": "C:\\Espressif\\tools\\xtensa-esp-elf-gdb\\11.2_20220808\\xtensa-esp-elf-gdb\\bin;C:\\Espressif\\tools\\riscv32-esp-elf-gdb\\11.2_20220808\\riscv32-esp-elf-gdb\\bin;C:\\Espressif\\tools\\xtensa-esp32-elf\\esp-2022r1-RC1-11.2.0\\xtensa-esp32-elf\\bin;C:\\Espressif\\tools\\xtensa-esp32s2-elf\\esp-2022r1-RC1-11.2.0\\xtensa-esp32s2-elf\\bin;C:\\Espressif\\tools\\xtensa-esp32s3-elf\\esp-2022r1-RC1-11.2.0\\xtensa-esp32s3-elf\\bin;C:\\Espressif\\tools\\riscv32-esp-elf\\esp-2022r1-RC1-11.2.0\\riscv32-esp-elf\\bin;C:\\Espressif\\tools\\esp32ulp-elf\\2.28.51-esp-20191205\\esp32ulp-elf-binutils\\bin;C:\\Espressif\\tools\\esp32s2ulp-elf\\2.28.51-esp-20191205\\esp32s2ulp-elf-binutils\\bin;C:\\Espressif\\tools\\cmake\\3.23.1\\bin;C:\\Espressif\\tools\\openocd-esp32\\v0.11.0-esp32-20220706\\openocd-esp32\\bin;C:\\Espressif\\tools\\ninja\\1.10.2;C:\\Espressif\\tools\\idf-exe\\1.0.3;C:\\Espressif\\tools\\ccache\\4.3\\ccache-4.3-windows-64;C:\\Espressif\\tools\\dfu-util\\0.9\\dfu-util-0.9-win64",
"idf.customExtraVars": "{\"OPENOCD_SCRIPTS\":\"C:\\\\Espressif\\\\tools\\\\openocd-esp32\\\\v0.11.0-esp32-20220706/openocd-esp32/share/openocd/scripts\",\"IDF_CCACHE_ENABLE\":\"1\"}",
"idf.espIdfPathWin": "C:\\Users\\pc-linux\\esp\\esp-idf",
"idf.openOcdConfigs": [
"board/esp32s3-builtin.cfg"
"idf.portWin": "COM12",
"idf.pythonBinPathWin": "C:\\Espressif\\python_env\\idf5.0_py3.8_env\\Scripts\\python.exe",
"idf.toolsPathWin": "C:\\Espressif",
"idf.flashType": "JTAG"
if someone has already managed to connect with ESP-PROG, it would help me a lot as well, as you managed to do this, I tried several ways, but without success.
I really appreciate if anyone can help me, I have this problem for two weeks
Thank You
Help on ESP32-S3 builtin JTAG debug on VSCODE (Windows 10)
- terminal_debug_console_press_pause.txt
- (2.1 KiB) Downloaded 369 times
- terminal_debug_console.txt
- (11.15 KiB) Downloaded 381 times
- erro2.png (24.68 KiB) Viewed 7016 times
Re: Help on ESP32-S3 builtin JTAG debug on VSCODE (Windows 10)
Solved !!!
Most of my problems were the wrong documentation
Glad you solved it. But what was the corect doc's that fixed it.
Hi! Can you tell us how have you correct all? I'm still trying to find a solution to debug ESP32-S3-DevKitC-1 using the onboard USB-JTAG without any success!
Thanks!
Dario
Thanks!
Dario
Please, install ESP-IDF Versin 5.0 from VS Config IDF extension
And change your "settings.json" to this
Code: Untitled.xml Select all
"idf.customExtraPaths": "C:\\Espressif\\tools\\xtensa-esp-elf-gdb\\11.2_20220823\\xtensa-esp-elf-gdb\\bin;C:\\Espressif\\tools\\riscv32-esp-elf-gdb\\11.2_20220823\\riscv32-esp-elf-gdb\\bin;C:\\Espressif\\tools\\xtensa-esp32-elf\\esp-2022r1-11.2.0\\xtensa-esp32-elf\\bin;C:\\Espressif\\tools\\xtensa-esp32s2-elf\\esp-2022r1-11.2.0\\xtensa-esp32s2-elf\\bin;C:\\Espressif\\tools\\xtensa-esp32s3-elf\\esp-2022r1-11.2.0\\xtensa-esp32s3-elf\\bin;C:\\Espressif\\tools\\riscv32-esp-elf\\esp-2022r1-11.2.0\\riscv32-esp-elf\\bin;C:\\Espressif\\tools\\esp32ulp-elf\\2.28.51-esp-20191205\\esp32ulp-elf-binutils\\bin;C:\\Espressif\\tools\\esp32s2ulp-elf\\2.28.51-esp-20191205\\esp32s2ulp-elf-binutils\\bin;C:\\Espressif\\tools\\cmake\\3.23.1\\bin;C:\\Espressif\\tools\\openocd-esp32\\v0.11.0-esp32-20220706\\openocd-esp32\\bin;C:\\Espressif\\tools\\ninja\\1.10.2;C:\\Espressif\\tools\\idf-exe\\1.0.3;C:\\Espressif\\tools\\ccache\\4.6.2\\ccache-4.6.2-windows-x86_64;C:\\Espressif\\tools\\dfu-util\\0.9\\dfu-util-0.9-win64",
"interface/ftdi/esp32_devkitj_v1.cfg",
"target/esp32s3.cfg"
"idf.portWin": "COM23",
"idf.flashType": "UART"
}Who is online
Users browsing this forum: Bytespider, ChatGPT-User, Google [Bot], Qwantbot and 0 guests
