During development we have connected a bench power supply instead of a battery, in series with a voltmeter. We are using this code to acquire the voltage reading:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "esp_system.h"
#include "esp_err.h"
#include "esp_log.h"
#include "freertos/task.h"
#include "driver/gpio.h"
#include "driver/adc.h"
#include "esp_adc_cal.h"
typedef long i32;
static esp_adc_cal_characteristics_t *adc_chars;
static const adc1_channel_t channel = ADC1_CHANNEL_6;
static const adc_bits_width_t width = ADC_WIDTH_BIT_12;
static const adc_atten_t atten = ADC_ATTEN_DB_11;
static uint8 adc_configured = 0;
void adc_init() {
/* gpio config */
esp_err_t err;
gpio_config_t io_conf = {};
io_conf.intr_type = GPIO_INTR_DISABLE;
io_conf.mode = GPIO_MODE_INPUT;
io_conf.pin_bit_mask = 1ULL << GPIO_NUM_7;
io_conf.pull_down_en = 0;
io_conf.pull_up_en = 0;
err = gpio_config(&io_conf);
/* config attenuation */
adc1_config_channel_atten(channel, atten);
/* config bit width */
adc1_config_width(width);
adc_chars = calloc(1, sizeof(esp_adc_cal_characteristics_t));
esp_adc_cal_value_t val_type = esp_adc_cal_characterize(ADC_UNIT_1,
atten,
width,
1100,
adc_chars);
i32 adc_read() {
#define BATADC_SAMPLE_SZ 32
// multisampling
for (u8 i = 0; i < BATADC_SAMPLE_SZ; i++) {
i32 raw = adc1_get_raw((adc1_channel_t)channel);
adc_reading += raw;
sys_delay_us(20);
adc_reading /= (BATADC_SAMPLE_SZ);
voltage = esp_adc_cal_raw_to_voltage(adc_reading, adc_chars) * 2u;
return voltage;
void app_main(void)
adc_init();
for (;;) {
ESP_LOGI(TAG, "VBat: %ld", adc_read());
vTaskDelay(1000);
BUT when we reset the system, by pulling RST to GND, the readings suddenly get very accurate (+-4mV), the offset disappears!
We did not burn any eFuse or set Two-Point calibration values; we are using the module as it shipped.
Are we doing something wrong?
