Hi Helper,
I am using ESP32 DevKit v4 with USB Connection power supply. I am looking for the debug option for the debugging the source code. I don't have any external Module Like JTAG or Segger tools as debugger.
Does ESP32 Devkit V4 has on-board debugger option ? Can I debug thorough the USB which is used for the programming the device ?
ESP32 Source code Debug
Re: ESP32 Source code Debug
I imagine you mean the ESP32 DevKitC v4? That one does not have an USB-to-JTAG bridge onboard, sorry.
ketan vadodariya
Ok,
Noted. Thank you for your reply. I got at-least one reply from the forum.
Thank you!.
Thank you!.
ketan vadodariya
I have an question regarding the data reading from the USB port. My logging system is print through the UART0 and I have to read the data through the same UART port (That means USB ).
1. that is not a question,
2. please start a separate topic for that issue.
ketan vadodariya
Using an FT2232H or FT232H board is not that expensive and works quite well (FT2232H is used on the ESP-WROVER-KIT).I imagine you mean the ESP32 DevKitC v4? That one does not have an USB-to-JTAG bridge onboard, sorry.
Users browsing this forum: PetalBot and 2 guests
