Dedicated spi flash pins
kamesh
Postby kamesh » Sat Jun 17, 2017 7:30 am
Hai,
I am not able to configure dedicated spi flash pins (gpio6 to gpio11) as general purpose I/O. Suggest how it can be done and explain the functions of the corresponding pins. I am using sdk v 2.0.
Thanks,
kamesh.c
Re: Dedicated spi flash pins
Postby Sprite » Sat Jun 17, 2017 12:08 pm
Might that be because your main SPI flash is connected to these pins, and your code is stored on that?
kamesh
Postby kamesh » Sun Jun 18, 2017 4:18 pm
Yes I am flashing my code
WiFive
Postby WiFive » Sun Jun 18, 2017 6:53 pm
In general, esp32 is always using flash pins to reload the cache so you cannot use flash pins as gpio. This is different to other mcus that load the whole program to ram from flash at startup.
Users browsing this forum: Applebot, Baidu [Spider], Bing [Bot], Semrush [Bot] and 1 guest
