IDE : Arduino IDE
Module : ESP32-Woorm, 8MB
I have done release steps in flash encryption, now i need to update bootloader, app0, partition table, app in flash.
To do so i am encrypt all file manually and upload via UART but after upload device not working and not show anything in serial.
so i debug and found that the bootloader file is not encrypt correctly and it cause device not work., so please if any one face same problem then guide me.
Related to flash encryption
dvl_s_from
Re: Related to flash encryption
It would help if your post had a bit more info than 'it doesn't work'. What instructions did you follow exactly, how did you encrypt the files, do you get any logs and so which ones, why do you think the bootloader wasn't encrypted correctly?
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 3 guests
