ESP-IDF v5 pre_encrypted_ota example
Our team is evaluating the example from https://github.com/espressif/esp-idf/tr ... rypted_ota, but our intention is to implement pre-encrypted binaries with OTA updates using the latest stable release from https://github.com/espressif/esp-idf/tree/v4.4.2. We found a previously closed issue from https://github.com/espressif/esp-idf/is ... 1101345156 and it directs the user to cherry pick two commits, but both are merge commits and are not valid for a straightforward git cherry-pick command. What command/options should we be running specifically? Are we supposed to be cherry picking multiple commits, a range, etc.?
Re: ESP-IDF v5 pre_encrypted_ota example
Please refer to the branch that I created on top of ESP-IDF v4.4.2 here: https://github.com/mahavirj/esp-idf/tre ... ota_v4.4.2
I have tested build for the `pre_encrypted_ota` example on this branch, it went smoothly. I have not tested the actual functionality but I think it should work too. Please let me know if this helps.
Alternatively, you can also use ESP-IDF v5.0-beta1 release which has this feature available in it.
Thank you.
Thank you.
Mahavir
Thank you. We'll try out your feature branch, since it's a priority for us to use stable releases with as little modifications as possible. Is the implementation on this feature branch equivalent to what's on v5.0-beta1?ESP_Mahavir wrote: ↑Tue Oct 04, 2022 4:40 pmHello,
Thank you.
Also, is there a schedule/timeline for the next stable release that will include this feature (stable release based on either v4.4 or v5.0)?
YesIs the implementation on this feature branch equivalent to what's on v5.0-beta1?
I do not have specific timeline but we plan to prepare v5.0-RC in next few days. Hopefully we will have official v5.0 release by end of this month.Also, is there a schedule/timeline for the next stable release that will include this feature (stable release based on either v4.4 or v5.0)?
Mahavir
Users browsing this forum: Majestic-12 [Bot] and 149 guests
