svenbieg
Postby svenbieg » Sat Jun 25, 2022 9:20 pm
Maybe this memory-manager?
http://www.github.com/svenbieg/heap
Best regards,
Sven Bieg
svenbieg
Postby svenbieg » Sat Jun 25, 2022 9:22 pm
vanBassum
Postby vanBassum » Thu Jun 30, 2022 1:37 pm
Things we use in our devices:
- Proper support for HTTPS, the encryption ESP32 is not fast enough. Other devices lack other requirements.
- Larger pin count, now we use IO expanders this cost us 1 SPI interface.
- MAC PHY, we are stuck using the ESP32 for the PHY. Using SPI is not fast enough since its shared with the IO expander
- USB
- WIFI, Zigbee and bluetooth? Ive seen problems with this due to these using the same frequency. Perhaps wifi on 5GHz?
ESP32_Arduino_user
Postby ESP32_Arduino_user » Tue Oct 11, 2022 9:31 am
my wishes would be:
- a 3-4 core version (I'm programming in Arduino IDE).
Why?
1. Core for all internal things e.g. WIFI, Bluetooth, Uart, SPI etc. -> system/event task
2. Core for fast / time-critical things like querying data from an ADC or similar -> only one task is running here, with my applications the task switching takes too long so that only one task can run
3. Core application, possibly several tasks (web server, save data on SD, UI etc.)
4th core optional from 3rd core
- a much more accurate 12bit ADC (preferably 14bit)
- DMA controller for SPI, UART etc.
- interface for graphic LCDs
Greetings and many thanks for this microcontroller
Postby Sprite » Wed Oct 12, 2022 4:31 am
Why?
Wouldn't you be able to combine the 3rd and 1st core tasks and run this on a two-core CPU?
Newer ESPs (ESP32S3 for instance) already have a much better ADC, and the S3 specifically has an interface for graphical LCDs.
That already exists from the very first ESP32. You may now know it because the APIs handle DMA details for you.
cruvus
Postby cruvus » Wed Oct 12, 2022 9:25 pm
433 MHz radio.
vanBassum
Postby vanBassum » Mon Oct 24, 2022 7:44 am
I think I forgot this in my previous post, but I would really like some always unique hardware ID.
svenbieg
Postby svenbieg » Mon Oct 24, 2022 5:36 pm
I'd like the same pin-layout very much, because i don't like to sell adapters to my customers. ;)
Best regards,
Sven Bieg
Deouss
Postby Deouss » Mon Oct 24, 2022 9:51 pm
Just make Risc-V C3 Dual core or quad core )
Maybe higher clock too - 240Mhz+
Postby Sprite » Tue Oct 25, 2022 1:56 am
You can use the MAC-address for that, it's guaranteed to be unique.
Users browsing this forum: Baidu [Spider], ChatGPT-User and 2 guests
