I'm building and running the stock led fade example. It doesn't seem to be working correctly.
Biggest question is the two set-duty examples are supposed to set it to "0" and "test". But in both cases they do 50/50 duty cycle all the time. This is true for BOTH tests.
The other weird issue is that the fade examples go from 0 to about 50% - but never above that.
Documentation is a little unclear on what the min/maxes should be. Also - the docs don't say what "hpoint" is (though changing it didn't seem to fix).
Any advice??
LEDC (hpoint, demo issues)
Re: LEDC (hpoint, demo issues)
P.S. It seems as when I set the max duty cycle to 8192 - that made the "fade" work full scale (0% to 100% PWM).
But that actually help reveal that the following code doesn't seem to be doing anything:
printf("3. LEDC set duty = %d without fade\n", LEDC_TEST_DUTY);
for (ch = 0; ch < LEDC_TEST_CH_NUM; ch++) {
ESP_ERROR_CHECK_WITHOUT_ABORT(ledc_set_duty(ledc_channel[ch].speed_mode, ledc_channel[ch].channel, LEDC_TEST_DUTY));
ESP_ERROR_CHECK_WITHOUT_ABORT(ledc_update_duty(ledc_channel[ch].speed_mode, ledc_channel[ch].channel));
vTaskDelay(5000 / portTICK_PERIOD_MS);
printf("4. LEDC set duty = 0 without fade\n");
ESP_ERROR_CHECK_WITHOUT_ABORT(ledc_set_duty(ledc_channel[ch].speed_mode, ledc_channel[ch].channel, 0));
Users browsing this forum: Bing [Bot], meta-externalagent, PetalBot and 2 guests
