CORRUPT HEAP after reconnect
marclee
Re: CORRUPT HEAP after reconnect
Postby marclee » Sat Oct 29, 2022 5:16 pm
Yes your code logs every event. It doesn't specifically handle the correct specific disconnect event however.
As the smartphone keeps staying on channel 1, in case of a channel switch a disconnect command would never reach the ESP32.
Thank you for your efforts.
pawcuq
Postby pawcuq » Wed Nov 16, 2022 6:03 pm
Did you manage to figure solution for this problem? Same here...
marclee
Postby marclee » Fri Nov 18, 2022 10:02 am
Unfortunately not.
Users browsing this forum: Baidu [Spider], Bing [Bot], Qwantbot, Semrush [Bot] and 6 guests
