Wifi scan while connected to an AP
BrunoOtavio
Postby BrunoOtavio » Mon Nov 28, 2022 5:45 pm
I'm dealing with an application where I have to scan to search for some devices while the esp is connected to an AP, but when I try to do this, the function esp_wifi_scan_get_ap_num return 0, and the function esp_wifi_scan_get_ap_records do not put devices in the structure. Isn't possible to realize a scan while I'm connected to an AP? I'm using idf 4.0.4
igrr
Re: Wifi scan while connected to an AP
Postby igrr » Mon Nov 28, 2022 5:59 pm
Have you also called esp_wifi_scan_start before esp_wifi_scan_get_ap_num? If yes, could you check the return code of esp_wifi_scan_start?
BrunoOtavio
Postby BrunoOtavio » Mon Nov 28, 2022 6:05 pm
Yes, I called esp_wifi_scan_start before, it's returning 0.
diolupo
Postby diolupo » Thu Dec 01, 2022 3:07 pm
The same here.
If I try to perform AP scan while in STA mode and already connected to an AP, the esp_wifi_scan_get_ap_num() returns 0.
This is a snippet of my code
    // blocking scan
    err_code = esp_wifi_scan_start(NULL, true);
    if (err_code != ESP_OK)
        LOGE("esp_wifi_scan_start() failed, error: %d", err_code);
        goto _exit;
    // scan done
    uint16_t ap_count = 0;
    err_code = esp_wifi_scan_get_ap_num(&ap_count);
        LOGE("esp_wifi_scan_get_ap_num() failed, error: %d", err_code);
        goto _exit;
    if (ap_count > 0)
        ap_list = (wifi_ap_record_t *)malloc(ap_count * sizeof(wifi_ap_record_t));
        if (ap_list == NULL)
            goto _exit;
        memset(ap_list, 0, ap_count * sizeof(wifi_ap_record_t));
        err_code = esp_wifi_scan_get_ap_records(&ap_count, ap_list);
            LOGE("esp_wifi_scan_get_ap_records() failed, error: %d", err_code);
            goto _exit;
        for (int i = 0; i < ap_count; i++)
            // force last character of country code
            ap_list[i].country.cc[2] = '\0';
            LOGI("%d - %s [%d] (%d) %s", i, ap_list[i].ssid, ap_list[i].primary, ap_list[i].rssi, ap_list[i].country.cc);
When the device is in APSTA mode it works correctly.
I'm developing on eSP32-S3-DevKitC, using esp-idf v4.4.2 on Linux.
diolupo
Postby diolupo » Fri Dec 02, 2022 11:25 am
I understand which was my problem.
Reading the wifi documentation I have found this:
the found APs are stored in WiFi driver dynamic allocated memory and they will be
freed in esp_wifi_scan_get_ap_records, so generally, call esp_wifi_scan_get_ap_records
to cause the memory to be freed once the scan is done
Since I also have an event handler in which I was processing the ap_records, the internal ap_records list was freed when I read it inside the event handler, and when I try to read it after the blocking scan it was empty.
Users browsing this forum: Applebot and 0 guests
