ESP32-C3 Flash error
tonico2
Postby tonico2 » Wed Jan 11, 2023 7:07 am
I have customized the ESP32-C3 Lolin mini and I have the following the error of attached picture, when I try to flash.
In boot mode I have GPIO2, GPIO8 high and GPI09 low, as indicated in the ESP32-C3 datasheet.
As you can see, the USB port can communicate with Esptool, but when it has to flash the data, it causes the error.
I have disconnected everything from the GPIO and the error continues.
On the original Lolin ESP32-C3 mini board the program loads perfectly, but on my custom PCB it causes the error.
Can you help me?
Thanks you.
Minatel
Re: ESP32-C3 Flash error
Postby Minatel » Wed Jan 11, 2023 11:18 am
Have you tried using a lower baudrate for flashing? Can you share more details about your hardware? Schematics, PCB, pictures...?
tonico2
Postby tonico2 » Wed Jan 11, 2023 2:54 pm
Yes, I have tried all baudrate speeds, low and high.
I have tried with external power supply 3.3V and the there is the same problem.
Attached TOP, BOTTOM and schematic.
I don't know why have I this error. :(
PCB TOP
PCB BOTTOM
SCHEMATIC
tonico2
Postby tonico2 » Thu Jan 12, 2023 7:23 am
Attached with --trace option:
esptool.py v4.2.1
Serial port COM1
Connecting...TRACE +0.000 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
0707122055555555 5555555555555555 | ... UUUUUUUUUUUU
5555555555555555 5555555555555555 | UUUUUUUUUUUUUUUU
55555555 | UUUU
TRACE +0.004 Write 46 bytes:
c000082400000000 0007071220555555 | ...$........ UUU
5555555555555555 5555555555c0 | UUUUUUUUUUUUU.
TRACE +0.106 No serial data received.
.TRACE +0.056 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
55555555 | UUUU
TRACE +0.005 Write 46 bytes:
TRACE +0.012 Read 1 bytes: c0
TRACE +0.001 Read 25 bytes:
0108040007071220 00000000c0c00108 | ....... ........
0400070712200000 00 | ..... ...
TRACE +0.006 Received full packet: 010804000707122000000000
TRACE +0.014 Read 1 bytes: 00
TRACE +0.000 Read 85 bytes:
c0c0010804000707 122000000000c0c0 | ......... ......
0400070712200000 0000c0c001080400 | ..... ..........
0707122000000000 c0c0010804000707 | ... ............
122000000000c0c0 0108040007071220 | . .............
00000000c0 | .....
TRACE +0.004 Received full packet: 010804000707122000000000
TRACE +0.003 Received full packet: 010804000707122000000000
TRACE +0.002 Received full packet: 010804000707122000000000
TRACE +0.003 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=00100040
TRACE +0.000 Write 14 bytes: c0000a04000000000000100040c0
TRACE +0.007 Read 1 bytes: c0
TRACE +0.000 Read 13 bytes: 010a04006f50311b00000000c0
TRACE +0.001 Received full packet: 010a04006f50311b00000000
TRACE +0.002 command op=0x14 data len=0 wait_response=1 timeout=3.000 data=
TRACE +0.000 Write 10 bytes: c00014000000000000c0
TRACE +0.013 Read 1 bytes: c0
TRACE +0.000 Read 33 bytes:
011418006f50311b 0000000000000000 | ....oP1.........
0000000c05000000 0300000000000000 | ................
c0 | .
TRACE +0.003 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=50880060
TRACE +0.000 Write 14 bytes: c0000a04000000000050880060c0
TRACE +0.011 Read 1 bytes: c0
TRACE +0.000 Read 13 bytes: 010a040000000c0100000000c0
TRACE +0.001 Received full packet: 010a040000000c0100000000
TRACE +0.002 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=50880060
TRACE +0.000 Received full packet: 010a040000000c0100000000
Chip is ESP32-C3 (revision 3)
Features: Wi-Fi
Crystal is 40MHz
TRACE +0.004 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=44880060
TRACE +0.001 Write 14 bytes: c0000a04000000000044880060c0
TRACE +0.000 Read 14 bytes: 010a0400dbdcefb7a100000000c0
TRACE +0.000 Received full packet: 010a0400c0efb7a100000000
TRACE +0.003 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=48880060
TRACE +0.000 Write 14 bytes: c0000a04000000000048880060c0
TRACE +0.000 Read 13 bytes: 010a0400df7c000000000000c0
TRACE +0.001 Received full packet: 010a0400df7c000000000000
MAC: 7c:df:a1:b7:ef:c0
Uploading stub...
TRACE +0.004 command op=0x05 data len=16 wait_response=1 timeout=3.000 data=280e0000010000000018000000003840
TRACE +0.000 Write 26 bytes:
c000051000000000 00280e0000010000 | .........(......
0000180000000038 40c0 | .......8@.
TRACE +0.000 Read 13 bytes: 01050400df7c000000000000c0
TRACE +0.000 Received full packet: 01050400df7c000000000000
TRACE +0.003 command op=0x07 data len=3640 wait_response=1 timeout=3.000 data=
280e000000000000 0000000000000000 | (...............
411122c426c206c6 b73704601147d8cb | A.".&....7.`.G..
37340460b744c83f 5c40918b91e7b240 | 74.`.D.?\@.....@
2244924441018280 084083a704001375 | "D.DA....@.....u
f50f8297d5b70111 b70700604ac803a9 | ...........`J...
870026ca4ec652c4 06ce22ccb7040060 | ..&.N.R..."....`
fd59374ac83fc04c 1374f43f0de0f240 | .Y7J.?.L.t.?...@
624423a82401b249 d2444249224a0561 | bD#.$..I.DBI"J.a
8280884083270a00 1375f50f82977d14 | ...@.'...u....}.
e31934ffc9bf3727 00607c4b9d8bf5ff | ..4...7'.`|K....
373700607c4b9d8b f5ff8280411106c6 | 77.`|K......A...
dd37b727006023a6 07023707000898c3 | .7.'.`#...7.....
98437dffc857b240 1345f5ff05894101 | .C}..W.@.E....A.
8280411106c6d93f 7ddd37070040b727 | ..A....?}.7..@.'
006098c337270060 1c43fdffb2404101 | .`..7'.`.C...@A.
8280411122c43744 c93f9307c4099c4b | ..A.".7D.?.....K
06c626c2a1cf5d37 31c91304c4091848 | ..&...]71......H
bd47814463d6e700 0444bd8893b41400 | .G.Dc....D......
4d3f953f1c443707 00011396c700637f | M?.?.D7.......c.
e600b706800099e0 b706000137270060 | ............7'.`
50c314c3b7260060 98427dff414791e0 | P....&.`.B}.AG..
05471448ba971cc4 998e14c8b2402244 | .G.H.........@"D
9244410182801307 000c9c41631be500 | .DA........Ac...
81e785479cc121a8 23a00500f9573e85 | ...G..!.#....W>.
828005476387e700 8946638dd700fd57 | ...Gc....Fc....W
fdb7931705011307 b00dc187e311e5fe | ................
8947c9bf9307c00d 6316f50098c19307 | .G......c.......
000cf1b79306d00d fd57e312d5fc98c1 | .........W......
9307b00d6dbfb745 c93f411193854509 | ....m..E.?A...E.
06c6513f63490506 b747c93f9387c700 | ..Q?cI...G.?....
83a6070803d74708 1375f50f42074183 | ......G..u..B.A.
1306170042064182 2392c70836972300 | ....B.A.#...6.#.
a70003d747089167 9387070442074183 | ....G..g....B.A.
631ef70237c7c83f 1307c700a167ba97 | c...7..?.....g..
03a60708b706c93f b747c93f9387c700 | .......?.G.?....
9386c604631fe600 23a6c70823a0d708 | ....c...#...#...
2392070821a0f957 e306f5fcb2404101 | #...!..W.....@A.
828023a6d70823a0 e708ddb7411106c6 | ..#...#.....A...
9700c8ffe78000e6 03458501b2407515 | .........E...@u.
1335150041018280 411106c6c53711c1 | .5..A...A....7..
0d45b24041011703 c8ff6700a3e04111 | .E.@A.....g...A.
06c69700c8ffe780 60dec93701c5b240 | ........`..7...@
4101d9bfb2404101 8280411106c61307 | A....@A...A.....
000c631ae5001305 b00dd13f1305c00d | ..c........?....
b2404101e9b71307 b00de31be5fec137 | .@A............7
1305d00df5b74111 22c426c206c62a84 | ......A.".&...*.
b304b50063179400 b240224492444101 | ....c....@"D.DA.
8280034504000504 4d3fedb71305000c | ...E....M?......
79b7011122cc3744 c93f9307c40926ca | y...".7D.?....&.
c44706ce4ac84ec6 1304c40963f39500 | .G..J.N.....c...
ae84b9c003294400 aa8926991359c900 | .....)D...&..Y..
1c486355f0001c44 635ff902853b7ddd | .HcU...Dc_...;}.
48402686ce859700 c8ffe78060df1375 | H@&.........`..u
f50f01c59307400c 5cc85c40a6975cc0 | ......@.\.\@..\.
5c44b384974044c4 f2406244d2444249 | \D...@D..@bD.DBI
b24905618280b53b 65bf011106ce22cc | .I.a...;e.....".
193b3704ce3f6c00 130544ff9700c8ff | .;7..?l...D.....
e78000de854715e5 b24793f707203ec6 | .....G...G... >.
0d3b372700601c47 b7064000130544ff | .;7'.`.G..@...D.
d58f1cc7b2459700 c8ffe780a0dbb337 | .....E.........7
a000f24062443e85 056182804111b747 | ...@bD>..a..A..G
c93f054706c6238e e7089387c70913d7 | .?.G..#.........
c50098c705677d17 ccc3c8c7f98d3a95 | .....g}.......:.
aa95b1818ccb23aa 0700413719c11305 | ......#...A7....
500cb24041018280 75714ac17d730569 | P..@A...uqJ.}s.i
22c526c3ceded2dc d6da06c77d741a91 | ".&.........}t..
930709078a971304 84fa3e94aa892285 | ..........>...".
ae849700c8ffe780 201f93070907056a | ........ ......j
8a97b38a4741b9e0 0567930707077d74 | ....GA...g....}t
930584fa8a971304 84f93e9493070707 | ..........>.....
8a97be9522859700 c8ffe780601c2285 | ....".......`.".
c145953501450563 1a91ba402a449a44 | .E.5.E.c...@*D.D
0a49f659665ad65a 4961828026896373 | .I.YfZ.ZIa..&.cs
9a0005694a86d685 4e859700c8ffe780 | ...iJ...N.......
60ca1375f50f01ed 4a86d68522859700 | `..u....J..."...
c8ffe780a017ca99 b384244169b71305 | ..........$Ai...
300655bf31717d73 56d35ad15ecf62cd | 0.U.1q}sV.Z.^.b.
06df22dd26db4ad9 4ed752d566cb6ac9 | ..".&.J.N.R.f.j.
6ec705671a91368c 1307070714083697 | n..g..6.......6.
fd77ba973ec623aa 07f8aa8a2e8bb28b | .w..>.#.........
b13b9307000219c1 b70702003e859700 | .;..........>...
c8ffe780a0108567 63e3771585641808 | .......gc.w..d..
7d7493870407ba97 130484fa33898700 | }t..........3...
4a859700c8ffe780 200f7d7a18089387 | J....... .}z....
0407ba97930c3af9 be9c93870407130d | ......:.........
8af9ba9781493e9d 8567938707071808 | .....I>..g......
ba9733844701832d 44f963f66d0b63f1 | ..3.G..-D.c.m.c.
b90355a06133a685 2285b13b41332686 | ..U.a3.."..;A3&.
a2854a859700c8ff e780400aa69aa699 | ..J.......@.....
63f66903b387b941 63f28703b3073b41 | c.i....Ac.....;A
de8463f37701be84 2686a28556859700 | ..c.w...&...V...
c8ffe78020b91375 f50f4ddd85679387 | .... ..u..M..g..
07071808ba973384 4701232c04f88144 | ......3.G.#,...D
8d4da30904f86685 9700c8ffe78080aa | .M....f.........
7df9034534f9ea85 bd3e63400502e3e2 | }..E4....>c@....
9dfe856718089387 0707ba9733879700 | ...g........3...
5297230aa7f88504 e9b7f957e313f5fc | R.#........W....
1147e383e4f40567 1408930707077d74 | .G.....g......}t
b697930584fa1304 84f93e9493070707 | ..........>.....
b697be9522859700 c8ffe78060ff7d39 | ....".......`.}9
c145228549395d39 1139b707020019e1 | .E".I9]9.9......
930700023e859700 c8ffe78060fc0563 | ....>.......`..c
1a91fa506a54da54 4a59ba592a5a9a5a | ...PjT.TJY.Y*Z.Z
0a5bfa4b6a4cda4c 4a4dba4d29618280 | .[.KjL.LJM.M)a..
b757414919719387 f78401453ece86de | .WAI.q.....E>...
a2dca6dacad8ced6 d2d4d6d2dad0dece | ................
e2cce6caeac8eec6 9700c8ffe78040a2 | ..............@.
b747c83f3777c93f 93870700130787ba | .G.?7w.?........
63eae71425399145 680831310539b7c7 | c...%9.Eh.11.9..
c83f9387c7002167 3e972320f708b707 | .?....!g>.# ....
3840374ac83f9387 671b2320fa00b74a | 8@7J.?..g.# ...J
c93fad36938aca00 130a0a0063000512 | .?.6........c...
b7270c604547b8d7 854545459700c8ff | .'.`EG...EEE....
e78040eeb7053840 0146938505004545 | ..@...8@.F....EE
9700c8ffe78040ef 373704601c4b3705 | ......@.77.`.K7.
020093e747001ccb 9700c8ffe78040ee | ....G.........@.
9700c8ffe780c0fe b74700609c5f11e5 | .........G.`._..
13f5c70161151335 150081459700c8ff | ....a..5...E....
e78080a1c167374b c93ffd1713070010 | .....g7K.?......
85664166b7050001 01459309cb098d6b | .fAf.....E.....k
374cc83f9700c8ff e780009cce9b930c | 7L.?............
cc0083a7ca08f5df 83a4ca08854723a6 | .............G#.
0a082302f10283c7 140009472313e102 | ..#........G#...
a302f10202d44d47 6385e70851476383 | ......MGc...QGc.
e7082947639ee700 83c7340003c72400 | ..)Gc.....4...$.
a207d98f11476395 e7009c449c433ed4 | .....Gc....D.C>.
313ea1454810c53c 03c7340083c72400 | 1>.EH..<..4...$.
916622075d8f9387 060163f8e7041305 | .f".].....c.....
b00d71341305c00d 59341305e00e4134 | ..q4....Y4....A4
f53441b723a00700 91075db5b7053840 | .4A.#.....]...8@
0146938565031545 9700c8ffe780c0de | .F..e..E........
370700605c471305 000293e717105cc7 | 7..`\G........\.
e5bdc9472313f102 61bf83c714003546 | ...G#...a.....5F
638dc72c636ef60e 1946638cc7366362 | c..,cn...Fc..6cb
f6080d466382c718 636cf6040946638e | ...Fc...cl...Fc.
c72601491304f00f 1375f40f3d341375 | .&.I.....u..=4.u
f90f2534a53ce316 04f083c714003d47 | ..%4.<........=G
6389e744636bf736 11476382e7541947 | c..Dck.6.Gc..T.G
6380e7560d47e396 e7ee83c5340083c7 | c..V.G......4...
240013858401a205 dd8dc1159934d1bd | $............4..
91466386d7249546 e395d7fac1470545 | .Fc..$.F.....G.E
6312f7109c44d848 2324fa002322ea00 | c....D.H#$..#"..
65a2a546638ed724 63ecf6029d46638a | e..Fc..$c....Fc.
d728a146e39fd7f6 930740026311f71e | .(.F......@.c...
02d41d4401456132 01454532c53afd32 | ...D.Ea2.EE2.:.2
a14548107d14c132 75f401490144a9bf | .EH.}..2u..I.D..
a946638ed724ad46 e395d7f4e147631b | .Fc..$.F.....Gc.
f71edc4c984cd448 9048cc4488449700 | ...L.L.H.H.D.D..
c8ffe78060802a89 3335a0002a842db7 | ....`.*.35..*.-.
d1466380d70e63ed f604c5466386d708 | .Fc...c....Fc...
63eaf602bd466389 d716c146e393d7f0 | c....Fc....F....
0544631ff70c9c48 1167636cf726c044 | .Dc....H.gcl.&.D
cc48884433848702 913423ac090023a4 | .H.D3....4#...#.
8bb0f9a0c946638c d716cd46e39bd7ec | .....Fc....F....
c14705446316f70a cc448844b13c4da8 | .G.Dc....D.D.<M.
9306200d6389d712 63e0f6029306000d | .. .c...c.......
638ad7089306100d e395d7eaa147630c | c............Gc.
f70805452a84ada8 9306300d638fd742 | ...E*.....0.c..B
9306400de397d7e8 8347cb096380071a | ..@......G..c...
9c44411703a44901 6384e7001304000c | .DA...I.c.......
81479306f00e63cd e70e03c7540083c7 | .G....c.....T...
4400014922075d8f 83c76400c2075d8f | D..I".]...d...].
83c77400e207d98f e388f6e41304100c | ..t.............
a1b5054411ef7010 8145014597b0ccff | ...D..p..E.E....
e780e0fa11e5d145 6810eff0df880144 | .......Eh......D
01491db505446dff 97f0c7ffe780806d | .I...Dm........m
3334a000f5b703ad 8400c044b3678d00 | 34.........D.g..
1397470139ff1132 29fd4169229d7d19 | ..G.9..2).Ai".}.
fd7d33058d4019e8 0145a9b7318197f0 | .}3..@...E..1...
c7ffe780a06a15fd 6e94e5b7b3772501 | .....j..n....w%.
f5f7416933058d40 636e89007d793305 | ..Ai3..@cn..}y3.
8d4079d8318197f0 c7ffe780206811f9 | .@y.1....... h..
4a94f5b7418197f0 c7ffe780e066e312 | J...A........f..
05f033042441f9b7 a147e300f7e40149 | ..3.$A...G.....I
1304000c51bbc147 cdbfc1470544e311 | ....Q..G...G.D..
f7f69c4863eff60e cc488844c1388db7 | ...Hc....H.D.8..
3386f40003468601 8507b18eedbd8347 | 3....F.........G
cb09adcf83a7c900 ede3230e0b0803a4 | ..........#.....
49013db701490545 15b591470545e313 | I.=..I.E...G.E..
f7ea8844814597f0 c7ffe780e063a9b7 | ...D.E.......c..
9377f700c9ff135d 4700138484000149 | .w.....]G......I
fd5de374a9dd4844 97f0c7ffe7808050 | .].t..HD.......P
1c44584014407d8f 6387b701904293c7 | .DX@.@}.c....B..
f7fff18f5d8f98c2 05094104d9bf9147 | ....].....A....G
a9bf83254a004117 91e501cf01491304 | ...%J.A......I..
600cddb183278a00 63e5e70693773700 | `....'..c....w7.
9dff03288a000146 81473305f840b386 | ...(...F.G3..@..
f50063e9e700e302 06d62322da002324 | ..c.......#"..#$
aa00a1bb3386f400 104e910790c20546 | ....3....N.....F
e9bfa1470545e31f f7de03248a0019c0 | ...G.E.....$....
1304800c23240a00 23220a0033358000 | ....#$..#"..35..
d5b301491304200c 41b101491304800c | ...I.. .A..I....
a5b901491304900c 85b949476389e71c | ...I......IGc...
6362f7044547e39e e7b683c7340003c7 | cb..EG......4...
240013848401a207 d98f938d07ff0549 | $..............I
83a7c90063850d00 99c3634420116357 | ....c.....cD .cW
09181307700c23aa e900e39407b49307 | ....p.#.........
900c59a21307200d 638be70c1307400d | ..Y... .c.....@.
e399e7b203c43400 83c7240022045d8c | ......4...$.".].
97f0c7ffe780804b 03a9c90041146373 | .......K....A.cs
24012289e30709b0 03a449004a943180 | $.".......I.J.1.
83a709016356f000 83a789006350f40a | ....cV......cP..
eff0cfc075dd03a5 49004a8693858401 | ....u...I.J.....
97f0c7ffe7800047 09c59307400c23aa | .......G....@.#.
f90083a74900ca97 23a2f90083a7c900 | ....I...#.......
3389274123a62901 97f0c7ffe7804045 | 3.'A#.).......@E
4dbc096513050571 03a9c400804497f0 | M..e...q.....D..
c7ffe7802037b707 0060d84bb7060001 | .... 7...`.K....
c116935747011207 758fbd8bd98fb387 | ...WG...u.......
27030145b3d58702 97f0c7ffe7800038 | '..E...........8
1305803e97f0c7ff e780c0339db4d448 | ...>.......3...H
9048cc448844eff0 eff8a1bceff06fbb | .H.D.D........o.
81bfb776c93f03a7 86bab7c7c83f9387 | ...v.?.......?..
c700998f3ed683a7 8bb0377dc93f6ed0 | ....>.....7}.?n.
130dcd09938486ba 054863f3fd000d48 | .........Hc....H
42c63ac4eff0efb7 224732483745c93f | B.:....."G2H7E.?
a2857c109306cc00 10101305450b97f0 | ..|.........E...
c7ffe78060378257 03278db08c40b38d | ....`7.W.'...@..
fd401d8f3e94b257 2324edb02a89be95 | .@..>..W#$..*...
8cc09307cc009d8d 01c5a167e39af5e6 | ...........g....
6685eff00fd423a0 94019db5e31f09e6 | f.....#.........
e381079c9307800c 23aaf9005dba9c44 | ........#...]..D
e399079aeff04fc9 09651305057197f0 | ......O..e...q..
c7ffe780202797f0 c7ffe780a02a51ba | .... '.......*Q.
c044e3080498eff0 2fc71305803e97f0 | .D....../....>..
c7ffe78020250294 adbaf6506654d654 | .... %.....PfT.T
4659b659265a965a 065bf64b664cd64c | FY.Y&Z.Z.[.KfL.L
464db64d09618280 | FM.M.a..
TRACE +0.013 Write 3667 bytes:
c00007380e930000 00280e0000000000 | ...8.....(......
0000000000000000 00411122c426c206 | .........A.".&..
c6b73704601147d8 cb37340460b744c8 | ..7.`.G..74.`.D.
3f5c40918b91e7b2 4022449244410182 | ?\@.....@"D.DA..
80084083a7040013 75f50f8297d5b701 | ..@.....u.......
11b70700604ac803 a9870026ca4ec652 | ....`J.....&.N.R
c406ce22ccb70400 60fd59374ac83fdb | ..."....`.Y7J.?.
dc4c1374f43f0de0 f240624423a82401 | .L.t.?...@bD#.$.
b249d2444249224a 0561828088408327 | .I.DBI"J.a...@.'
0a001375f50f8297 7d14e31934ffc9bf | ...u....}...4...
372700607c4b9d8b f5ff373700607c4b | 7'.`|K....77.`|K
9d8bf5ff82804111 06c6dd37b7270060 | ......A....7.'.`
23a6070237070008 98c398437dffc857 | #...7......C}..W
b2401345f5ff0589 41018280411106c6 | .@.E....A...A...
d93f7ddd37070040 b727006098c33727 | .?}.7..@.'.`..7'
00601c43fdffb240 41018280411122c4 | .`.C...@A...A.".
3744c93f9307c409 9c4b06c626c2a1cf | 7D.?.....K..&...
5d3731c91304c409 1848bd47814463d6 | ]71......H.G.Dc.
e7000444bd8893b4 14004d3f953f1c44 | ...D......M?.?.D
370700011396c700 637fe600b7068000 | 7.......c.......
99e0b70600013727 006050c314c3b726 | ......7'.`P....&
006098427dff4147 91e005471448ba97 | .`.B}.AG...G.H..
1cc4998e14c8b240 2244924441018280 | .......@"D.DA...
1307000c9c41631b e50081e785479cc1 | .....Ac......G..
21a823a00500f957 3e85828005476387 | !.#....W>....Gc.
e7008946638dd700 fd57fdb793170501 | ...Fc....W......
1307b00dc187e311 e5fe8947c9bf9307 | ...........G....
dbdc0d6316f50098 c19307000cf1b793 | ...c............
06d00dfd57e312d5 fc98c19307b00d6d | ....W..........m
bfb745c93f411193 85450906c6513f63 | ..E.?A...E...Q?c
490506b747c93f93 87c70083a6070803 | I...G.?.........
d747081375f50f42 0741831306170042 | .G..u..B.A.....B
0641822392c70836 972300a70003d747 | .A.#...6.#.....G
0891679387070442 074183631ef70237 | ..g....B.A.c...7
c7c83f1307c700a1 67ba9703a60708b7 | ..?.....g.......
06c93fb747c93f93 87c7009386c60463 | ..?.G.?........c
1fe60023a6c70823 a0d7082392070821 | ...#...#...#...!
a0f957e306f5fcb2 404101828023a6d7 | ..W.....@A...#..
0823a0e708ddb741 1106c69700c8ffe7 | .#.....A........
8000e603458501b2 4075151335150041 | ....E...@u..5..A
018280411106c6c5 3711c10d45b24041 | ...A....7...E.@A
011703c8ff6700a3 e0411106c69700c8 | .....g...A......
ffe78060dec93701 c5b2404101d9bfb2 | ...`..7...@A....
4041018280411106 c61307000c631ae5 | @A...A.......c..
001305b00dd13f13 05dbdc0db2404101 | ......?......@A.
e9b71307b00de31b e5fec1371305d00d | ...........7....
f5b7411122c426c2 06c62a84b304b500 | ..A.".&...*.....
63179400b2402244 9244410182800345 | c....@"D.DA....E
040005044d3fedb7 1305000c79b70111 | ....M?......y...
22cc3744c93f9307 c40926cac44706ce | ".7D.?....&..G..
4ac84ec61304c409 63f39500ae84b9db | J.N.....c.......
dc03294400aa8926 991359c9001c4863 | ..)D...&..Y...Hc
55f0001c44635ff9 02853b7ddd484026 | U...Dc_...;}.H@&
86ce859700c8ffe7 8060df1375f50f01 | .........`..u...
c59307400c5cc85c 40a6975cdbdc5c44 | ...@.\.\@..\..\D
b384974044c4f240 6244d2444249b249 | ...@D..@bD.DBI.I
05618280b53b65bf 011106ce22cc193b | .a...;e....."..;
3704ce3f6c001305 44ff9700c8ffe780 | 7..?l...D.......
00de854715e5b247 93f707203ec60d3b | ...G...G... >..;
372700601c47b706 4000130544ffd58f | 7'.`.G..@...D...
1cc7b2459700c8ff e780a0dbddb337a0 | ...E..........7.
00f24062443e8505 6182804111b747c9 | ..@bD>..a..A..G.
3f054706c6238ee7 089387c70913d7c5 | ?.G..#..........
0098c705677d17cc c3c8c7f98d3a95aa | ....g}.......:..
95b1818ccb23aa07 00413719c1130550 | .....#...A7....P
0cb2404101828075 714ac17d73056922 | ..@A...uqJ.}s.i"
c526c3ceded2dcd6 da06c77d741a9193 | .&.........}t...
0709078a97130484 fa3e94aa892285ae | .........>..."..
849700c8ffe78020 1f93070907056a8a | ....... ......j.
97b38a4741b9e005 67930707077d7493 | ...GA...g....}t.
0584fa8a97130484 f93e94930707078a | .........>......
97be9522859700c8 ffe780601c2285c1 | ...".......`."..
459535014505631a 91ba402a449a440a | E.5.E.c...@*D.D.
49f659665ad65a49 618280268963739a | I.YfZ.ZIa..&.cs.
0005694a86d6854e 859700c8ffe78060 | ..iJ...N.......`
ca1375f50f01ed4a 86d68522859700c8 | ..u....J..."....
ffe780a017ca99b3 84244169b7130530 | .........$Ai...0
0655bf31717d7356 d35ad15ecf62cd06 | .U.1q}sV.Z.^.b..
df22dd26dbdd4ad9 4ed752d566cb6ac9 | .".&..J.N.R.f.j.
9700c8ffe780dbdc feb74700609c5f11 | ..........G.`._.
e513f5c701611513 35150081459700c8 | .....a..5...E...
ffe78080a1c16737 4bc93ffd17130700 | ......g7K.?.....
1085664166b70500 0101459309cb098d | ..fAf.....E.....
6b374cc83f9700c8 ffe780009cce9b93 | k7L.?...........
0ccc0083a7ca08f5 df83a4ca08854723 | ..............G#
a60a082302f10283 c7140009472313e1 | ...#........G#..
02a302f10202d44d 476385e708514763 | .......MGc...QGc
83e7082947639ee7 0083c7340003c724 | ...)Gc.....4...$
00a207d98f114763 95e7009c449c433e | ......Gc....D.C>
d4313ea1454810c5 3c03c7340083c724 | .1>.EH..<..4...$
00916622075d8f93 87060163f8e70413 | ..f".].....c....
05b00d71341305db dc0d59341305e00e | ...q4.....Y4....
4134f53441b723a0 070091075db5b705 | A4.4A.#.....]...
3840014693856503 15459700c8ffe780 | 8@.F..e..E......
dbdcde370700605c 471305000293e717 | ...7..`\G.......
105cc7e5bdc94723 13f10261bf83c714 | .\....G#...a....
003546638dc72c63 6ef60e1946638cc7 | .5Fc..,cn...Fc..
366362f6080d4663 82c718636cf60409 | 6cb...Fc...cl...
46638ec726014913 04f00f1375f40f3d | Fc..&.I.....u..=
341375f90f2534a5 3ce31604f083c714 | 4.u..%4.<.......
003d476389e74463 6bf73611476382e7 | .=Gc..Dck.6.Gc..
5419476380e7560d 47e396e7ee83c534 | T.Gc..V.G......4
0083c72400138584 01a205dd8dc11599 | ...$............
34d1bd91466386d7 249546e395d7fac1 | 4...Fc..$.F.....
4705456312f7109c 44d8482324fa0023 | G.Ec....D.H#$..#
22ea0065a2a54663 8ed72463ecf6029d | "..e..Fc..$c....
46638ad728a146e3 9fd7f69307400263 | Fc..(.F......@.c
11f71e02d41d4401 45613201454532c5 | ......D.Ea2.EE2.
3afd32a14548107d 14c13275f4014901 | :.2.EH.}..2u..I.
44a9bfa946638ed7 24ad46e395d7f4e1 | D...Fc..$.F.....
47631bf71edc4c98 4cd4489048cc4488 | Gc....L.L.H.H.D.
449700c8ffe78060 802a893335a0002a | D......`.*.35..*
842db7d1466380d7 0e63edf604c54663 | .-..Fc...c....Fc
86d70863eaf602bd 466389d716c146e3 | ...c....Fc....F.
93d7f00544631ff7 0c9c481167636cf7 | ....Dc....H.gcl.
26dbdc44cc488844 33848702913423ac | &..D.H.D3....4#.
090023a48bb0f9a0 c946638cd716cd46 | ..#......Fc....F
e39bd7ecc1470544 6316f70acc448844 | .....G.Dc....D.D
b13c4da89306200d 6389d71263e0f602 | .<M... .c...c...
9306000d638ad708 9306100de395d7ea | ....c...........
a147630cf7080545 2a84ada89306300d | .Gc....E*.....0.
638fd7429306400d e397d7e88347cb09 | c..B..@......G..
6380071a9c444117 03a449016384e700 | c....DA...I.c...
1304000c81479306 f00e63cde70e03c7 | .....G....c.....
540083c744000149 22075d8f83c76400 | T...D..I".]...d.
c2075d8f83c77400 e207d98fe388f6e4 | ..]...t.........
1304100ca1b50544 11ef701081450145 | .......D..p..E.E
97b0ccffe780e0fa 11e5d1456810eff0 | ...........Eh...
df88014401491db5 05446dff97f0c7ff | ...D.I...Dm.....
e780806d3334a000 f5b703ad8400dbdc | ...m34..........
44b3678d00139747 0139ff113229fd41 | D.g....G.9..2).A
69229d7d19fd7d33 058d4019e80145a9 | i".}..}3..@...E.
b7318197f0c7ffe7 80a06a15fd6e94e5 | .1........j..n..
b7b3772501f5f741 6933058d40636e89 | ..w%...Ai3..@cn.
007d7933058d4079 d8318197f0c7ffe7 | .}y3..@y.1......
80206811f94a94f5 b7418197f0c7ffe7 | . h..J...A......
80e066e31205f033 042441f9b7a147e3 | ..f....3.$A...G.
00f7e40149130400 0c51bbc147cdbfc1 | ....I....Q..G...
470544e311f7f69c 4863eff60ecc4888 | G.D.....Hc....H.
44c1388db73386f4 00034686018507b1 | D.8..3....F.....
8eedbd8347cb09ad cf83a7c900ede323 | ....G..........#
0e0b0803a449013d b70149054515b591 | .....I.=..I.E...
470545e313f7ea88 44814597f0c7ffe7 | G.E.....D.E.....
80e063a9b79377f7 00c9ff135d470013 | ..c...w.....]G..
8484000149fd5de3 74a9dd484497f0c7 | ....I.].t..HD...
ffe78080501c4458 4014407d8f6387b7 | ....P.DX@.@}.c..
01904293c7f7fff1 8f5d8f98c2050941 | ..B......].....A
04d9bf9147a9bf83 254a00411791e501 | ....G...%J.A....
cf01491304600cdd b183278a0063e5e7 | ..I..`....'..c..
06937737009dff03 288a000146814733 | ..w7....(...F.G3
05f840b386f50063 e9e700e30206d623 | ..@....c.......#
22da002324aa00a1 bb3386f400104e91 | "..#$....3....N.
0790c20546e9bfa1 470545e31ff7de03 | ....F...G.E.....
248a0019dbdc1304 800c23240a002322 | $.........#$..#"
0a0033358000d5b3 01491304200c41b1 | ..35.....I.. .A.
01491304800ca5b9 01491304900c85b9 | .I.......I......
49476389e71c6362 f7044547e39ee7b6 | IGc...cb..EG....
83c7340003c72400 13848401a207d98f | ..4...$.........
938d07ff054983a7 c90063850d0099c3 | .....I....c.....
6344201163570918 1307700c23aae900 | cD .cW....p.#...
e39407b49307900c 59a21307200d638b | ........Y... .c.
e70c1307400de399 e7b203c4340083c7 | ....@.......4...
240022045d8c97f0 c7ffe780804b03a9 | $.".]........K..
c900411463732401 2289e30709b003a4 | ..A.cs$.".......
49004a94318083a7 09016356f00083a7 | I.J.1.....cV....
89006350f40aeff0 cfdbdc75dd03a549 | ..cP.......u...I
004a869385840197 f0c7ffe780004709 | .J............G.
c59307400c23aaf9 0083a74900ca9723 | ...@.#.....I...#
a2f90083a7c90033 89274123a6290197 | .......3.'A#.)..
f0c7ffe78040454d bc09651305057103 | .....@EM..e...q.
a9c400804497f0c7 ffe7802037b70700 | ....D...... 7...
60d84bb7060001c1 1693574701120775 | `.K.......WG...u
8fbd8bd98fb38727 030145b3d5870297 | .......'..E.....
f0c7ffe780003813 05803e97f0c7ffe7 | ......8...>.....
80dbdc339db4d448 9048cc448844eff0 | ...3...H.H.D.D..
eff8a1bceff06fbb 81bfb776c93f03a7 | ......o....v.?..
86bab7c7c83f9387 c700998f3ed683a7 | .....?......>...
8bb0377dc93f6ed0 130dcd09938486ba | ..7}.?n.........
054863f3fd000d48 42c63ac4eff0efb7 | .Hc....HB.:.....
224732483745c93f a2857c109306cc00 | "G2H7E.?..|.....
10101305450b97f0 c7ffe78060378257 | ....E.......`7.W
03278db08c40b38d fd401d8f3e94b257 | .'...@...@..>..W
2324edb02a89be95 8cdbdc9307cc009d | #$..*...........
8d01c5a167e39af5 e66685eff00fd423 | ....g....f.....#
a094019db5e31f09 e6e381079c930780 | ................
0c23aaf9005dba9c 44e399079aeff04f | .#...]..D......O
c909651305057197 f0c7ffe780202797 | ..e...q...... '.
f0c7ffe780a02a51 badbdc44e3080498 | ......*Q...D....
eff02fc71305803e 97f0c7ffe7802025 | ../....>...... %
0294adbaf6506654 d6544659b659265a | .....PfT.TFY.Y&Z
965a065bf64b664c d64c464db64d0961 | .Z.[.KfL.LFM.M.a
8280c0 | ...
TRACE +0.336 Read 1 bytes: c0
TRACE +0.001 Read 13 bytes: 01070400df7c000000000000c0
TRACE +0.003 Received full packet: 01070400df7c000000000000
TRACE +0.007 command op=0x05 data len=16 wait_response=1 timeout=3.000 data=040000000100000000180000a86bc93f
TRACE +0.001 Write 26 bytes:
c000051000000000 0004000000010000 | ................
0000180000a86bc9 3fc0 | ......k.?.
TRACE +0.020 Read 1 bytes: c0
TRACE +0.001 Read 13 bytes: 01050400df7c000000000000c0
TRACE +0.003 Received full packet: 01050400df7c000000000000
TRACE +0.007 command op=0x07 data len=20 wait_response=1 timeout=3.000 data=
0400000000000000 0000000000000000 | ................
0c40c83f | .@.?
TRACE +0.004 Write 30 bytes:
c000071400540000 0004000000000000 | .....T..........
0000000000000000 000c40c83fc0 | ..........@.?.
TRACE +0.016 Read 1 bytes: c0
TRACE +0.002 Received full packet: 01070400df7c000000000000
Running stub...
TRACE +0.005 command op=0x06 data len=8 wait_response=1 timeout=0.050 data=0000000070063840
TRACE +0.000 Write 18 bytes:
c000060800000000 0000000000700638 | .............p.8
40c0 | @.
TRACE +0.009 Read 1 bytes: c0
TRACE +0.000 Read 13 bytes: 01060400df7c000000000000c0
TRACE +0.001 Received full packet: 01060400df7c000000000000
TRACE +0.014 Read 1 bytes: c0
TRACE +0.001 Read 5 bytes: 4f484149c0
TRACE +0.002 Received full packet: 4f484149
Stub running...
Changing baud rate to 921600
TRACE +0.000 command op=0x0f data len=8 wait_response=1 timeout=3.000 data=00100e0000c20100
c0000f0800000000 0000100e0000c201 | ................
00c0 | ..
TRACE +0.008 Read 1 bytes: c0
TRACE +0.001 Read 11 bytes: 010f0200000000000000c0
TRACE +0.001 Received full packet: 010f0200000000000000
Changed.
TRACE +0.056 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=18200060
TRACE +0.000 Write 14 bytes: c0000a04000000000018200060c0
TRACE +0.005 Read 1 bytes: c0
TRACE +0.001 Read 11 bytes: 010a0200000000800000c0
TRACE +0.001 Received full packet: 010a0200000000800000
TRACE +0.004 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=20200060
TRACE +0.001 Write 14 bytes: c0000a04000000000020200060c0
TRACE +0.001 Read 11 bytes: 010a0200000000700000c0
TRACE +0.001 Received full packet: 010a0200000000700000
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2820006017000000ffffffff00000000
c000091000000000 0028200060170000 | .........( .`...
00ffffffff000000 00c0 | ..........
TRACE +0.000 Read 11 bytes: 01090200000000000000c0
TRACE +0.001 Received full packet: 01090200000000000000
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1820006000000090ffffffff00000000
c000091000000000 0018200060000000 | .......... .`...
90ffffffff000000 00c0 | ..........
TRACE +0.010 Read 1 bytes: c0
TRACE +0.001 Read 11 bytes: 01090200000000000000c0
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=202000609f000070ffffffff00000000
c000091000000000 00202000609f0000 | ......... .`...
70ffffffff000000 00c0 | p.........
TRACE +0.002 Received full packet: 01090200000000000000
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=5820006000000000ffffffff00000000
c000091000000000 0058200060000000 | .........X .`...
TRACE +0.006 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=0020006000000400ffffffff00000000
c000091000000000 0000200060000004 | .......... .`...
TRACE +0.005 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=00200060
TRACE +0.001 Write 14 bytes: c0000a04000000000000200060c0
TRACE +0.001 Read 11 bytes: 010a0200000000000000c0
TRACE +0.001 Received full packet: 010a0200000000000000
TRACE +0.004 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=58200060
TRACE +0.001 Write 14 bytes: c0000a04000000000058200060c0
TRACE +0.000 Read 11 bytes: 010a0200ffffff000000c0
TRACE +0.001 Received full packet: 010a0200ffffff000000
TRACE +0.005 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1820006000000080ffffffff00000000
80ffffffff000000 00c0 | ..........
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2020006000000070ffffffff00000000
c000091000000000 0020200060000000 | ......... .`...
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
TRACE +0.005 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=18200060
TRACE +0.001 Write 14 bytes: c0000a04000000000018200060c0
TRACE +0.002 Received full packet: 010a0200000000800000
TRACE +0.002 Write 14 bytes: c0000a04000000000020200060c0
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=0020006000000400ffffffff00000000
TRACE +0.004 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=00200060
TRACE +0.000 Write 14 bytes: c0000a04000000000000200060c0
TRACE +0.002 Received full packet: 010a0200000000000000
TRACE +0.003 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1820006000000080ffffffff00000000
TRACE +0.004 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=18200060
TRACE +0.000 Read 11 bytes: 010a0200000000700000c0
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2820006007000000ffffffff00000000
c000091000000000 0028200060070000 | .........( .`...
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1c2000600700005cffffffff00000000
c000091000000000 001c200060070000 | .......... .`...
5cffffffff000000 00c0 | \.........
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=18200060000000f0ffffffff00000000
f0ffffffff000000 00c0 | ..........
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=202000605a000070ffffffff00000000
c000091000000000 00202000605a0000 | ......... .`Z..
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=0420006010000000ffffffff00000000
c000091000000000 0004200060100000 | .......... .`...
TRACE +0.002 Read 11 bytes: 01090200000000000000c0
TRACE +0.003 Received full packet: 01090200000000000000
TRACE +0.007 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=00200060
TRACE +0.002 Write 14 bytes: c0000a04000000000000200060c0
TRACE +0.006 Read 1 bytes: c0
TRACE +0.000 Read 11 bytes: 010a0200000000000000c0
TRACE +0.005 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=58200060
TRACE +0.000 Write 14 bytes: c0000a04000000000058200060c0
TRACE +0.000 Read 11 bytes: 010a0200ff0000000000c0
TRACE +0.002 Received full packet: 010a0200ff0000000000
TRACE +0.004 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1820006000000080ffffffff00000000
TRACE +0.005 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2020006000000070ffffffff00000000
Configuring flash size...
TRACE +0.004 command op=0x0b data len=24 wait_response=1 timeout=3.000 data=
0000000000004000 0000010000100000 | ......@.........
00010000ffff0000 | ........
TRACE +0.004 Write 34 bytes:
c0000b1800000000 0000000000000040 | ...............@
0000000100001000 0000010000ffff00 | ................
00c0 | ..
TRACE +0.001 Read 11 bytes: 010b0200000000000000c0
TRACE +0.001 Received full packet: 010b0200000000000000
TRACE +0.005 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=38880060
TRACE +0.000 Write 14 bytes: c0000a04000000000038880060c0
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00010000 to 0x000bdfff...
Compressed 12944 bytes to 9310...
TRACE +0.008 command op=0x10 data len=16 wait_response=1 timeout=3.000 data=90320000010000000040000000000000
TRACE +0.002 Write 26 bytes:
c000101000000000 0090320000010000 | ..........2.....
0000400000000000 00c0 | ..@.......
TRACE +0.001 Read 8 bytes: 0110020000000000
TRACE +3.001 Packet content transfer stopped (received 8 bytes)
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
Please, can anybody help me?
tonico2
Postby tonico2 » Thu Jan 12, 2023 8:09 am
Attached the differences between original module and customized module (with error load).
The differences begin after "Configuring flash size...". Data len right is 24 and data len no right is 4.
I don't know why I can't uoload the firmware (Arduino ide) to customized module. I proved with some boards and the error is the same.
