Configure the client port in esp_http_client request?
A6ESPF
Postby A6ESPF » Thu Jan 12, 2023 9:05 am
Is it possible to configure the client (source) port when initializing an esp_http_client? If not, what is the default client port? There is a port field in esp_http_client_config_t struct, but it defines the port to connect to (destination port).
YJM
Re: Configure the client port in esp_http_client request?
Postby YJM » Thu Jan 12, 2023 9:37 am
Sorry that esp_http_client not support set source port. The source port is a random value from 49152 to 65535.
A6ESPF
Postby A6ESPF » Thu Jan 12, 2023 9:53 am
Is the source port changed on every esp_http_client_perform or it is set during the initialization of the client? Is there a way to get the source port somehow, so I can see which port exactly is being used?
YJM
Postby YJM » Thu Jan 12, 2023 12:46 pm
The source port is allocated in https://github.com/espressif/esp-lwip/b ... cp.c#L1124, not in esp_http_client component, it is in low layer lwip. It is difficult to get the source port in esp_http_client layer. Because you have no API to get socket fd.
