Help with ESP32 OTA Rollback Option
helpwithesp32
Postby helpwithesp32 » Thu Jan 19, 2023 4:10 am
On the ESP32 (micropython, not Arduino) for OTA updates, do rollbacks occur by default, or does the CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE need to be set in the menuconfig for this to happen? Also, does any manual code need to be added to the firmware for rollback to occur?
Mahavir
Re: Help with ESP32 OTA Rollback Option
Postby Mahavir » Sun Jan 22, 2023 2:10 pm
Yes, rollback feature has following 2 requirements:
1. Enable `CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE` option in the project
2. Use following APIs in the application to set correct rollback status
// Mark firmware as valid and cancel rollback process
esp_ota_mark_app_valid_cancel_rollback();
// Mark firmware as invalid and rollback to previous firmware
esp_ota_mark_app_invalid_rollback_and_reboot();
Please refer to https://blog.espressif.com/ota-updates- ... 5438e30c12 for more information.
helpwithesp32
Postby helpwithesp32 » Sun Jan 22, 2023 8:14 pm
@ESP_Mahavir
Thank you for the response. Where should I put these lines of code in my program?
Also, I don't understand how I could use the invalid line. It seems invalid should be assumed if the valid line is never run?
Mahavir
Postby Mahavir » Mon Jan 23, 2023 3:36 am
This you will have to decide on when you can safely consider the new image as valid and cancel the rollback process. In some case, a new firmware connecting to Wi-Fi network or a cloud endpoint is considered to be a good checkpoint. Please see the blog post I linked in my earlier comment.
Calling the API `esp_ota_mark_app_invalid_rollback_and_reboot` is optional and can be based on some diagnostic runs on the new firmware image. Please have a look at the examples under `examples/system/ota/` from IDF and how you can use different APIs.
helpwithesp32
Postby helpwithesp32 » Thu Jan 26, 2023 2:01 am
Thank you. So if I enable the option, the minimum I need to do is add this line to my code?
How quickly after startup do I need to call this function before it auto rolls back to the previous version? Assuming that is what happens.
helpwithesp32
Postby helpwithesp32 » Thu Feb 09, 2023 11:50 pm
Hi @ESP_Mahavir,
Did you see my last post?
Robert
Users browsing this forum: Bing [Bot], Semrush [Bot], YisouSpider and 1 guest
