Hello!
I need to use hardware timers of ESP32 simultaneously with esp_timer.
Is it correct, that esp_timer always uses first timer of timer group defined by LACT_MODULE (i.e. LACT_MODULE=0 - first timer of group 0, LACT_MODULE=1 - first timer of group 1)?
As for GPTimer - i found, that this module starts to use timers from first time of 0 group.
So, as I understand, threre no automatic (by IDF code) distribution of hardware timers between esp_timer and GPTimer modules?
Those, if use LACT_MODULE=0 and add GPTimer, they will both use first timer of 0 group? or is it not?
Using of ESP IDF esp_timer and GPTimer simultaneously
IvanFedotov
Users browsing this forum: Applebot, PerplexityBot, Qwantbot, Semrush [Bot] and 1 guest
