Event callback still called after deiniting it
trwel4
Postby trwel4 » Sun Feb 12, 2023 7:35 pm
I am trying to develop a mesh application where at the root node, it checks for the existence of the router. If it wasn't there after N seconds, it will make a local mesh network instead.
This is the code I wrote to restart the esp-mesh
mdf_event_loop_deinit();
mwifi_stop();
mwifi_deinit();
esp_wifi_stop();
esp_wifi_deinit();
MDF_ERROR_ASSERT(mdf_event_loop_init(event_loop_cb));
MDF_ERROR_ASSERT(wifi_init());
MDF_ERROR_ASSERT(mwifi_init(&cfg));
MDF_ERROR_ASSERT(mwifi_set_config(&config));
MDF_ERROR_ASSERT(mwifi_start());
A short time between mwifi_deinit() and esp_wifi_stop() the event callback is erroneously called again which causes a panic in my application, even though I have deinitialized it in the first line! Why is that? Here are the logs I see on the terminal before the panic
I (12712) wifi:Set ps type: 0 I (12712) mesh: 452<stop> W (12712) mesh: [mesh.c,455] <stop>vendor ie W (12716) mesh: [mesh.c,458] <stop>send block W (12720) mesh: [mesh.c,461] <stop>rx task W (12724) mesh: [mesh_schedule.c,2119] <break>tx I (12729) mesh: 1942<flush>xon(req:0, rsp:0), mgmt:0, bcast:0, down:0, donw-be:0, ps(active:0, tx:0) W (12737) mesh: [mesh_schedule.c,2525] <done>MESH_STOP_EVENT_BIT_TX W (12743) mesh: [mesh_schedule.c,2526] <stop>tx W (12748) mesh: [mesh_schedule.c,2752] <break>xon I (12752) mesh: 1974<flush>up:0, up-be:0, ps(active:0, tx:0) W (12757) mesh: [mesh_schedule.c,3253] <done>MESH_STOP_EVENT_BIT_XON W (12763) mesh: [mesh_schedule.c,3254] <stop>xon W (12768) mesh: [mesh.c,464] <stop>tx task W (12782) mesh: [mesh.c,467] <stop>nwk task W (12783) mesh: [mesh.c,472] <stop>route W (12783) mesh: [mesh.c,477] <stop>free mesh_myself_mbox W (12784) [mwifi, 1344]: <ESP_ERR_MESH_NOT_START> Node failed to receive packets W (12785) mesh: [mesh.c,415] <done>MESH_STOP_EVENT_BIT_TODS W (12798) mesh: [mesh.c,482] <stop>free mesh_tcpip_mbox W (12803) mesh: [mesh.c,486] <stop>is_receiving:0 W (12807) mesh: [mesh.c,497] <stop>free mesh_xmit_state_mbox W (12812) mesh: [mesh.c,510] <stop>nvs task I (12824) wifi:Total power save buffer number: 16 I (12827) mesh: 552<end> I (12828) [mwifi, 232]: MESH is stopped W (12828) [mdf_event_loop, 69]: <MDF_ERR_NOT_INIT> The event loop isn't initialized W (12886) wifi:age timer already deinit I (12886) wifi:mode : sta (98:cd:ac:81:63:58) W (12889) wifi:age timer already deinit I (12892) wifi:flush txq I (12893) wifi:stop sw txq I (12896) wifi:lmac stop hw txq I (12899) [router_example, 282]: Root receive, addr: 00:00:00:00:00:00, size: 0, data:
rsimpsonbusa
Re: Event callback still called after deiniting it
Postby rsimpsonbusa » Wed Jun 07, 2023 4:45 am
I believe that those two calls are not immediate, meaning they will cause EVENTS to be posted at their own pace as it seems to be your case.
The correct order will be to wait for specific events, say via EventGroupSetBits or whatever. I had similar unexpected behaviour and crashes until I went this route.
Good luck
