Good afternoon,
I have tried to implement a pipe in order to decode a MP3 file on a SDCard and to sent it to an audio amplifier using I2S.
The program compiles normally, using an oscilloscope, I can see datas on the I2S_Out, so I think that the MP3 file is decoded and sent.
However, the LR_CLK and the BIT_CLK are not OK.
I would like to have a LR_CLK = 16KHz (Equal to the sample rate) but I have a LR_CLK = 1,3KHz.
The BIT_CLK is 96Khz.
So I do not ear anything on my amplifier.
Here is my config :
i2s_stream_cfg_t i2s_cfg;
i2s_cfg.type = AUDIO_STREAM_WRITER;
i2s_cfg.i2s_config.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX);
i2s_cfg.i2s_config.sample_rate = 16000;
i2s_cfg.i2s_config.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT;
i2s_cfg.i2s_config.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT;
i2s_cfg.i2s_config.communication_format = I2S_COMM_FORMAT_STAND_I2S;
i2s_cfg.i2s_config.intr_alloc_flags = ESP_INTR_FLAG_LEVEL2 | ESP_INTR_FLAG_IRAM;
i2s_cfg.i2s_config.dma_buf_count = 3;
i2s_cfg.i2s_config.dma_buf_len = 300;
i2s_cfg.i2s_config.use_apll = false;
i2s_cfg.i2s_config.tx_desc_auto_clear = true;
i2s_cfg.i2s_config.fixed_mclk = 0;
i2s_cfg.i2s_config.mclk_multiple = I2S_MCLK_MULTIPLE_384;
i2s_cfg.i2s_port = I2S_NUM_0;
i2s_cfg.use_alc = false;
i2s_cfg.volume = 0;
i2s_cfg.out_rb_size = I2S_STREAM_RINGBUFFER_SIZE;
i2s_cfg .task_stack = I2S_STREAM_TASK_STACK;
i2s_cfg.task_core = I2S_STREAM_TASK_CORE;
i2s_cfg.task_prio = I2S_STREAM_TASK_PRIO;
i2s_cfg.stack_in_ext = false;
i2s_cfg.multi_out_num = 0;
i2s_cfg.uninstall_drv = true;
i2s_cfg.need_expand = false;
i2s_cfg.expand_src_bits = I2S_BITS_PER_SAMPLE_16BIT;
i2s_stream_writer = i2s_stream_init(&i2s_cfg);
Could you please help me on the subject ?
Best regards,
Thomas TRUILHE.
ESP ADF : Pipe (SDCard - MP3Decoder - I2S) => Wrong Sample Rate
ThomasESP32
Re: ESP ADF : Pipe (SDCard - MP3Decoder - I2S) => Wrong Sample Rate
Hello ThomasESP32
at first it is recommended to initialise your config with
and then override the default config values
If you have no i2s to DAC chip you have to use the internal one
for this you have to define
SOC_I2S_SUPPORTS_ADC_DAC
you also can use
i2s_stream_set_clk(audio_element_handle_ti2s_stream, int rate, int bits, int ch)
to set the clock and bit rate
Best regards
i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();If you have no i2s to DAC chip you have to use the internal one
you also can use
Best regards
Hello Thomas
at first it is recomended to initialise your struct like this:
and then override the default values
like in the samples
if you do not have an i2s to dac then you need to define
you can also try this function to set the clock
there are also a lot of examples in esp-adf
https://github.com/espressif/esp-adf/tr ... p3_control
best regards
i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();like in the samples
SOC_I2S_SUPPORTS_ADC_DACCode: Select all
esp_err_t i2s_stream_set_clk(audio_element_handle_ti2s_stream, int rate, int bits, int ch)https://github.com/espressif/esp-adf/tr ... p3_control
best regards
