I would like to attach a slide power toggle switch, reset button, RC delay & prevent floating on the EN pin.
This is what I've come up with:
Is this schematic viable?
I'm concerned about the value of the pull down resistor (R7).. If I go any lower resistance the voltage on the EN pin will drop to much. Will a 100K resistor reliably pull EN down and prevent floating?
According to a circuit simulator I use, it should be 3V on the EN pin.
Am I going about this all the wrong way? I'm learning as I go along, so I'm not sure this is the best way to go about this.
I understand that traditionally a pull up resistor would have been used.. switch attached to ground.. yada yada.
I really want to use my slide switch as I plan to use it elsewhere in the project (SP3T).
